FExplorer Pro
Thảo luận trong 'ỨNG DỤNG HỆ THỐNG' bắt đầu bởi dung1291985, 23 Tháng năm 2009.
  1. tichau
    tichau Guest
    Bản này không bị đếm 123 ha bà con \m/.
  2. Liemlovevn
    Liemlovevn Ex-Mod
    FExplorer Pro v2.00 S60v3 S60v5 Symbian9 VH
    Một FExplorer Pro đã được việt hoá ko bao giờ đếm 1 2 3. Kiểm tra và sữ dụng đã làm việc tốt trên E63 của tôi.
  3. Liemlovevn
    Liemlovevn Ex-Mod
    Bạn có cài FExplorer Pro bảng tiếng Anh phải ko?
    Có vài lý do báo lỗi :
    - Tải ko đủ dung lượng
    - Cài đè
    - Xóa chưa hết còn dính đuôi cũ
    Khắc phục :
    - Dùng xplore tìm tên FExplorer Pro xóa hết
    - Hay chờ vài ngày rồi cài lại.
  4. tichau
    tichau Guest
    SBSH FExplorer Pro v2.01 S60v3 S60v5 SymbianOS9.x-Symbian
    What is FExplorer Pro
    FExplorer Pro (FEP) is a utility suite for S60 phones and supports 3rd and 5th edition phones. The main feature is of course the astonishing file browser alongside various tools and options that you can use to better manage your phone in general.
    File Browser
    The file browser is very very extensive to give you complete control over your phone's file system.
    It includes everything you will ever need from a file browser similar to Windows File Explorer or Total Commander (for Desktop).
    Features include (but are not limited to):
    * Searching for files on your phone.
    * Creation/Renaming/Deletion of files and folders.
    * Enter folders that can't be seen on the Nokia phone browser.
    * Three types of file editors (Hex, Binary and Text)
    * Attributes changes on files.
    * Zip(!)
    * Image viewer
    And much, much more!
    You will only grasp the myriad of options and features in this quaint application once you really start using it on a regular basis.
    In addition to the file browser, there are two additional tabs in FExplorer Pro (which can be toggled on/off using the "5" key):
    Tools
    With these tools, you can have a lot of your favorite tools all in one place, and it replaces the need to use other 3rd party applications for each of the functions (for instance Screenshot)
    I will give a short overview of what each of these tools does:
    Screenshot- Similar to the Antony Pranata's Screenshot for S60, this tool allows you to create screenshots of your phone from anywhere on the phone with various options to handle file saving etc...
    Backlight - This will turn your e-mail notification light on/off similar to Best Torch for S60. Very handy as it can turn your phone into a flashlight whenyou most need it Posted Image
    Bluetooth manager - This is VERY handy also. It will turn your Bluetooth on/off with a click of a button.
    Compress memory - de-fragments memory. You receive the memory available before and after the call to the function too.
    Installed applications- more for developers - it generates a file (C:\INSTAPP.TXT) which contains all of the installed applications (by the application manager), their UID and their path.
    Dump file list -generates a file (C:\FILESLST.TXT) containing the list of the files and the directory starting at the current position (current directory)
    As I mentioned above, now that FExplorer Pro is modulated in this fashion,we will be adding more tools to this list as time passes, which will continuously enhance your FExplorer Pro Posted Image
    Phone
    More options that you have for your phone in FExplorer Pro are shown above.
    Here is a short overview of what each function does:
    Phone info - this will give you all of the details that can be obtained about your phone like firmware version, IMEI etc...
    Restart - restarts the phone.
    Network info - gives you all available information that can be obtained about your network like area id, cell id, network name etc...
    Media info - gives you full stats on the installed memory card
    Change log :
    New: added the 'white' color in the settings for the lists.
    New: In the settings, the softkeys have now the following values :
    Right key : save : goes to the main list and SAVE the modifications.
    Left key : cancel : goes to the main list and DISCARD the modifications.
    New:in the (old) 'Phone tab', under 'phone info', added the version number& date of the firmware (ex: V 12.0.026 / 31-08-2009).
    New:in the (old) 'Phone tab', added a new entry 'System info' which gives details about the platform & hardware : os version, os edition,device name & uid, family, cpu type & speed, MAC address, total& free ram, total rom., screen resolution, number of colors,elapsed time since last power on (days/hours/minutes/seconds).
    New: in the (old)'Phone tab', added a new entry 'Fonts info' which gives the list of all installed fonts.
    Update: There start function has been moved from the (old)'Phone tab' to the 'tools tab'; the 'phone tab' contains mainly (and only) different information.
    Update:In the tools menu, the bluetooth manager calls now the build-in BT settings, this is the quickest way to use the bt function directly from FEP.
    Update: The 'Phone tab' has been changed into 'Info tab'
    Update: In the tools tab, for the files dump & installed applications, it'snow possible to define the drive where the files ( FILESLST.TXT,INSTAPP.TXT )will be genrated in the root (in the previous vrs, the files were generated on the C: drive).
    Update: If the memory compression is un-necessary, a message is displayed instead of the same number before and after.
    Bug Fix: the screenshot works now on the 5th edition : key used : 'c' (backspace) in 3rd edition and camera key in the 5th edition.
    Bug Fix: when the screenshot is active, the return to the tools tab, switches the screenshot off, the 'off' is correctly displayed in the listbox –previously, it stays on.
    Bug Fix: in the settings, the target of the screenshots can now be correctly defined (internal memory or memory card).
    Bug Fix: the screenshots are saved either in 'c:\images\fe_scr' (internal memory) or'e:\images\fe_scr' (memory card), no more fe_img directory is created.
    Bug Fix:the password works now, if a password is set in the settings, it's requested when FE starts, to reset the password, simply leave the field blank.
    Bug Fix: the restart/reboot works on the 5th ed (N97), restart has done at your own risks, all applications must be closed by the user to avoid lost of data.
    Bug Fix: cosmetic : the tabs in the status pane are now correctly displayed with their background in the 3rd ed (2, activated with '5') and 4 tabs in the 5th edition (always available).
    Bug Fix: deleting the last file in a folder crashed FEP.
    Bug Fix: deleting an empty directory crashed FEP.
    Bug Fix: at the root level, the 'edit' function in the menu is suppressed (this function had no sense at this level).
    Esp Thanks to Omar
    toiyeuv and Pham Hoai Nam like this.
  5. minhtue
    SBSH FExplorer Pro v2.10 S60v3/v5 SymbianOS9.x Unsigned Cr*cked-FoXPDA/N0ePDA
    Last update: 09/02/2010
    FExplorer Pro
    Powerful set of utilities that are missing with S60 phones for advanced users. Including the most robust file explorer with file searching, ZIP files management, image viewer and more! Screen capture utility, flashlight, memory defragment, advanced phone and network info tools and much more!
    NEW RELEASE - FExplorer Pro 2.1 released! New version introduce new toolbar designed for use with 5th edition touch screen devices, media free memory space gauge, new powerful task management features and much more!
    Utilities Package
    FExplorer Pro is a set of essential tools that are missing with the S60 platform. FExplorer Pro tools set is designed to complement your S60 phone in the best possible way! FExplorer Pro utilities are divided to sections: Robust File Explorer, Tools and Phone Utilities.
    File Explorer
    • NEW! Send files through bluetooth, email or any additional transmission hardware available on your phone model
    • NEW! Direct access to files located in your inbox
    • Robust File Explorer tool to easily browse and manage your phone files!
    • ZIP files support. Compress and extract ZIP files with your mobile phone
    • File management: create, delete, rename files and folders
    • Manage file attributes
    • File searching
    • Image viewer
    • File editor (Hex, Binary, ASCII Text and Unicode Text)
    NEW! Tasks Manager
    • View a complete list of all currently running tasks (processes) on your phone
    • Get full information about each running task
      Use robust task management utilities: switch to, close process and kill running tasks
      Tools
    • NEW! Use Restart utility to easily restart your phone (supporting majority of S60 phones)
    • NEW! Monitor used memory with a special popup box visible at the foreground of any application!
    • Offers a set of useful tools that enhance your phone's functionality
    • Screenshot utility used to take screen captures of your phone screen
    • Use the Backlight utility to transform your phone to a flash light when you need it the most!
    • Activate/disable the Bluetooth connection
    • Defrag your phone's memory using the Compress Memory utility to improve your phone's performance
    • Developers and advanced users can use the Installed applications utility to generate a list of all installed apps on the device, including their path and application UID
    • Dump file list is another tool for advanced users to dump all files and folders within the phone to a text file.
    Phone Utilities
    • NEW! Fonts Info utility provides a full list of all fonts installed on your phone
    • Phone related utilities including system details about your phone, network and more
    • Phone Info utility providing you system information about your phone, such as firmware version, IMEI number and more
    • Network Info utility for advanced network details. This brings details such as network area ID, connected cell ID, network information and more
    • Media Info utility providing you with technical details and system information about the memory card currently used, when available.
    Version History
    Ver 2.1, 09/02/2010
    • BUG FIX: when the screenshot is activated (FEP is running in background), the screenshot taken after switching between landscape<>portrait is correct.
    • BUG FIX: when renaming a file, the filename of the previous file was proposed instead of the current file.
    • BUG FIX: when getting the files properties, the title of the box contained the filename of the previous file (or directory) although the information were correct for the current file.
    • BUG FIX: when getting the directories properties, the title of the box contained the name of the previous file (or directory) although the information were correct for the current directory.
    • NEW: added the .sisx file type for the icon in front of a file.6. NEW: at the root level, added an entry before the [processes] : [inbox] which gives access to the files in attachment of the messages.
    • NEW: the attached files in the inbox are now accessible from the main screen.
    • NEW: a toolbar is activated in the 5th edition with the following buttons:
    • Left : marks/un-marks the current item in the list.
    • Middle : displays the toolbar extension with the following buttons: copy / cut / paste.
    • Right : deletes the current item in the list.
    • NEW: a blue left arrow (icon) has been placed in front of the ".." (go one level up) in the lists.
    • BUG FIX: on the N97 (5th ed), when an item containing a size was highlighted, the font size of all the items browsed became smaller until the app was re-started.
    • NEW: in the settings, it's now possible to define the color of the second column in the lists (the file size).
    • NEW: the main screen (the root) has been modified, each drive comes now with a gradient gauge (from red to green) showing graphically the used/free disk space.
    • NEW: on big drives, the capacity can be displayed in GB (instead of 9999MB).
    • NEW: the format of the drives capacity is now displayed with a decimal value.
    • NEW: the number of inbox attachments, processes & tasks running is now displayed on the main screen (root).
    • the restart function has been removed when installed on a samsung device.
    • NEW: the task manager has been completely re-written with the possibility to close or kill a task, to view tasks information such as : windows group name, uid, code size, attributes, capabilities.
    • NEW: added the SVG in the build-in files types.
    • NEW: in the tools tabs, added a function which can constantly monitor the free available ram, this ram is displayed at the top left corner and stays in foreground (until it's turned off).
    • the format of the files FILESLST.TXT (dump files list) and INSTAPP.TXT (installed applications) are now in Unicode to be read directly from the build-in notepad.
    • the 2 editions (3rd & 5th) have their specific exe (and functionnalities) which are embedded into one .sis and installed according to the target.
    • minor cosmetics & bugs fixed.
    • BUG FIX: on ".." (go to one level up), the "File/Make dir" is now activated and it's now possible to create a directory into an empty one.
    • NEW: added 'send' in the file menu which allows to send the current highlighted file via Bluetooth, infrared or email.
    • BUG FIX: Corrected the display of some alphabets from right to left like Hebrew.
    duc2012 thích bài này.
  6. duc2012
    duc2012 Thành viên
    cái này cra.ck oy hả bác.E71 chắc dùng đc chứ hả bác
  7. tichau
    tichau Guest
    SBSH FExplorer Pro v2.10 S60v3/v5 SymbianOS9.x Signed Retial by Poryia
    FExplorer Pro
    Utilities Package
    File Explorer
    * NEW! Send files through bluetooth, email or any additional transmission hardware available on your phone model
    * NEW! Direct access to files located in your inbox
    * Robust File Explorer tool to easily browse and manage your phone files!
    * ZIP files support. Compress and extract ZIP files with your mobile phone
    * File management: create, delete, rename files and folders
    * Manage file attributes
    * File searching
    * Image viewer
    * File editor (Hex, Binary, ASCII Text and Unicode Text)
    NEW! Tasks Manager
    * View a complete list of all currently running tasks (processes) on your phone
    * Get full information about each running task
    * Use robust task management utilities: switch to, close process and kill running tasks
    Ver 2.1, 02/09/2010
    * BUG FIX: when the screenshot is activated (FEP is running in background), the screenshot taken after switching between landscape<>portrait is correct.
    * BUG FIX: when renaming a file, the filename of the previous file was proposed instead of the current file.
    * BUG FIX: when getting the files properties, the title of the box contained the filename of the previous file (or directory) although the information were correct for the current file.
    * BUG FIX: when getting the directories properties, the title of the box contained the name of the previous file (or directory) although the information were correct for the current directory.
    * NEW: added the .sisx file type for the icon in front of a file.6. NEW: at the root level, added an entry before the [processes] : [inbox] which gives access to the files in attachment of the messages.
    * NEW: the attached files in the inbox are now accessible from the main screen.
    * NEW: a toolbar is activated in the 5th edition with the following buttons:
    o Left : marks/un-marks the current item in the list.
    o Middle : displays the toolbar extension with the following buttons: copy / cut / paste.
    o Right : deletes the current item in the list.
    * NEW: a blue left arrow (icon) has been placed in front of the ".." (go one level up) in the lists.[/font]
    * BUG FIX: on the N97 (5th ed), when an item containing a size was highlighted, the font size of all the items browsed became smaller until the app was re-started.[/font]
    * NEW: in the settings, it's now possible to define the color of the second column in the lists (the file size).[/font]
    * NEW: the main screen (the root) has been modified, each drive comes now with a gradient gauge (from red to green) showing graphically the used/free disk space.[/font]
    * NEW: on big drives, the capacity can be displayed in GB (instead of 9999MB).[/font]
    * NEW: the format of the drives capacity is now displayed with a decimal value.[/font]
    * NEW: the number of inbox attachments, processes & tasks running is now displayed on the main screen (root).[/font]
    * the restart function has been removed when installed on a samsung device.[/font]
    * NEW: the task manager has been completely re-written with the possibility to close or kill a task, to view tasks information such as : windows group name, uid, code size, attributes, capabilities.[/font]
    * NEW: added the SVG in the build-in files types.[/font]
    * NEW: in the tools tabs, added a function which can constantly monitor the free available ram, this ram is displayed at the top left corner and stays in foreground (until it's turned off).[/font]
    * the format of the files FILESLST.TXT (dump files list) and INSTAPP.TXT (installed applications) are now in Unicode to be read directly from the build-in notepad.[/font]
    * the 2 editions (3rd & 5th) have their specific exe (and functionnalities) which are embedded into one .sis and installed according to the target.[/font]
    * minor cosmetics & bugs fixed.
    * BUG FIX: on ".." (go to one level up), the "File/Make dir" is now activated and it's now possible to create a directory into an empty one.
    * NEW: added 'send' in the file menu which allows to send the current highlighted file via Bluetooth, infrared or email.
    * BUG FIX: Corrected the display of some alphabets from right to left like Hebrew.
    darkdemon85 and Pham Hoai Nam like this.
  8. tichau
    tichau Guest
    FExplorer PRO v2.10 MODDED Touch Skin
    [​IMG][​IMG]
    darkdemon85 and hoangvu9292 like this.
  9. duc2012
    duc2012 Thành viên
    bác cho em hỏi cái phần backlight ở phần tools trong FEX dùng để làm gì vậy?em thấy bật On lên mà chẳng thấy gì cả
  10. tichau
    tichau Guest
    Chắc là dùng để lấy đèn màn hình sáng liên tục kiểu như đèn pin quá :D.Không biết đúng hay sai nữa :032:.
