[Khác] FPse for android v0.11.57 - giả lập psx cho Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 17 Tháng chín 2012.
  1. Khỉ Con interista
  2. Khỉ Con
    FPse 0.11.42 changes:
    - Fixed crash on Jelly bean when "Do not keep activities" option set
    - Experimental Analog Pad support for Xperia Play, work only in OpenGL-ES 2.0 Blitting mode. All Psx games do not support Analog pad, so switch on Analog Pad from gamepad menu and try. Buttons L2/R2 L3/R3 are mapped to the 4 corners of the screen now as invisible.
    - Fixed Forcelandscape
    - Fixed Screenfilter
    - New Opengl plugin!
  3. Khỉ Con
    FPse 0.11.46 changes:
    - Software drawing mode Faster and smoother, and new frameskipping is perfect now.
    - Fixed Sound engine, far better now.
    - Exclusive New Cheat codes menu which try to get automatically Cheat codes from internet.
    - new Menu, very easy to play with fpse now...
    - Dpad overlap support (better gameplay)
    - Updated documentation which include now new FAQs.
    - many bugs fixed...
    See more here:
    http://www.fpsece.net/forum2/viewtopic.php?p=24904#p24904
  4. Khỉ Con
    0.11.49
    FPse 0.11.49 changes:
    - New Crash bug fixed
  5. Khỉ Con
    cập nhật
    FPse 0.11.57:
    - Fixed Enhanced 3D and Boost high res games options .
    Boost high res games is necessary for 1ghz proc or less and games like Tekken3, Medievil etc...
    - Fixed shortcut image uneeded cropping.
    FPse 0.11.56:
    - Sound fixed when SPUSYNC is on
    FPse 0.11.55:
    - OpenGL plugin Fixed
    See more here:
  6. vundt
    vundt Thành viên
    cái này dùng khá ổn . thank bạn .
