Yêu cầu phiên bản Android từ: 1.3 Ảnh chụp màn hình: A multi-launcher theme with white icons on a bordered transparent background. 1. QUICK INFO --------------------- - The theme works with GO Launcher, ADW Launcher and LauncherPro. - Folder Organizer or Better Cut allows icons to be individually picked and used in most launchers. - Widget skins are included for all LauncherPro widgets (requires LauncerPro Plus). - The theme currently contains 282 different icons, a matching wallpaper and docks. - All icons are available in both HDPI and XHDPI resolution. This ensures natively crisp HD icons for the majority of modern phones (HTC Desire, Samsung Galaxy S / S2 / Nexus etc.). Check out my other themes as well by pressing the "more by markomega" link. If you have any requests for icons or the like, do not hesitate to contact me. Your input helps me improve the quality of the pack. 2. DESCRIPTION ------------------------ This is a simple black and white theme and icon pack that adds a minimalistic and sleek look to your phone. It features a semitransparent design with neutral primary colours, which makes it blend in with almost any wallpaper you may choose (images, solid colours etc.). 3. NOTICE (READ THIS) ---------------------------------- When using LauncherPro, the docks and dock text icons cannot currently be selected directly from the theme. I have therefore included both docks and dock text icons on my website, so they can be downloaded and applied from the gallery instead. The wallpaper is likewise not automatically added when using LauncherPro and it is therefore also available on my website. If you have GO Launcher EX installed simultaneously, the wallpaper is available by pressing MENU > WALLPAPER > GO WALLPAPER. Notice that some of the screenshots are specific to a given launcher type and may differ a bit if you are not using that specific launcher. Better Cut is no longer available in the market, so do not spend time looking for it there. A list of all the apps that the pack includes icons for can be found on my website. If there is an issue with an icon in the list, then send me an email and I will fix it. 4. FEEDBACK -------------------- If you have ideas, requests, feedback or the like, please send me an email. The comments are not well suited for conversations. If you like my themes, please take a minute to drop a rating and a comment. They are the ultimate motivation for the further progress of my themes and I re-read the comments very often. 5. INSTALLATION ------------------------- The installation instructions explain how to apply the theme and/or some of its elements (icons, widget skins etc.). Instructions for other applications than the launchers are on my website, as characters are limited here. :: 5.1. LauncherPro (widget skins) 1) Go to MENU > PREFERENCES > LP WIDGET SETTINGS. 2) Select the widget you wish to apply the skin to. 3) Press SELECT SKIN and select FRAMED SIMPLICITY WIDGET SKINS. 4) Press YES to restart the launcher. :: 5.2. LauncherPro (icons) 1) Go to MENU > PREFERENCES > THEME SETTINGS > ICON PACK. 2) Select FRAMED SIMPLICITY. 3) Press YES to restart the launcher. :: 5.3. GO Launcher EX 1) Go to MENU > THEMES. 2) Scroll sideways if necessary, and select FRAMED SIMPLICITY. 3) Press APPLY to apply the theme. :: 5.4. ADW / ADW EX 1) Go to MENU > MORE > ADWSETTINGS > THEMES PREFERENCES. 2) Scroll sideways if necessary, and select FRAMED SIMPLICITY. 3) Press APPLY THEME to apply the theme. 4) In the MAIN DOCK drop down, choose CUSTOM > FRAMED SIMPLICITY DOCKS and select a dock. Xem thêm trên Play Store: Mã: [url] https://play.google.com/store/apps/details?id=com.markomega.framedsimplicity[/url] Tải về: Mã: [url]http://appstore.vn/a/index.php/home/app/10483 [/url]
