FreeAir-Tìm kiếm wlan(wifi).
Thảo luận trong 'ỨNG DỤNG CHẠY TRÊN NỀN PYTHON' bắt đầu bởi tichau, 11 Tháng bảy 2009.
  1. tichau Guest
    FreeAir v1.3 by KloNom
    [​IMG] [​IMG] [​IMG]
    FreeAir is a very usefull program for your phone with built-in wlan (wifi). Often you need to find an unsecured wlan for fast internet connection[​IMG] and many programs dont really help you because they alert you every time any new wlan appears. Thats the moment when FreeAir can help you. You start searching "FreeAir" and it will alert you only when an unsecured/open wlan appears.
    You even can adjust FreeAir to you. Do you need to be really precise or want to save your battery charge? Adjust the time interval between the searches as you want it or adjust none and take the default.
    Or personalize your alert sound. Just replace C:\FreeAir\alert.wav with any sound you want.
    Now in Version 1.3 FreeAir is much more adjustable and even usefuller!
    ~ search a Wlan with specific protection or SSID
    ~ switch alert sound on/off
    ~ enable "Show Wlan-Scans" and you'll see everytime a scan has been executed and see the total number of scans
    ~Memory of your Settings
    Changelog from 1.2 to 1.3:
    ~FreeAir saves your preferences, so you don't need to set it up everytime
    ~Notes added
    ~Bug fixes
    Installation Notes:
    ~ before installing FreeAir, install the right version of wlantools, included in this pack
    ~ have python installed
    ~remove previous versions
    kiengcanno1 and vanmaidoicho like this.
  2. huahaonam
    huahaonam Thành viên
    tìm kiếm Wifi có giồng viking prada không?
