[ROM] [Galaxy Nexus] Android Open Kang Project
Thảo luận trong 'SAMSUNG' bắt đầu bởi Khỉ Con, 25 Tháng chín 2012.
  1. Khỉ Con interista
    Tính năng của ROM:
    • Android 4.0.3 -- ITL41F
    • Unsecure boot.img (stock AOSP kernel)
    • Superuser & Busybox preinstalled
    • Deodexed
    • 180 Degree rotation
    • Built in performance/init.d configuration (Thanks Kejar & company)
    • CM Launcher/ Power Menu
    • CM Brightness slider
    • Custom color for anything in RC
    • Clock Color/Location: Right, Center, Disable
    • Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
    • Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
    • Nav Bar Transparency
    • Nav Bar Button Reorder: Back-Home-Search-Menu
    • Nav Bar Color Picker
    • Nav Bar Button Glow Duration: Off, Fast, Slow
    • Nav Bar: Long press to Search button
    • Nav Bar Hide on Lockscreen
    • Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
    • LCD Density (Careful with this)
    • Menu Button location: Right, Left, both, Remove
    • Menu Button Visability: Always show, Always show Invisible Icons
    • Lockscreen Style: Quad, Octo, Stock
    • Lockscreen SMS customizable shortcut
    • Lockscreen Horizontal Option
    • Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
    • Unlock Sceen with Legacy Menu Icon
    • Volume Key to Wake Screen
    • Volume Key to Skip Tracks
    • Long-press back button to kill process
    • Disable CRT off animation
    • LED pulse settings (time on/off)
    • ICS ringtones/notification sounds
    • Customize carrier text to whatever.
    • Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
    • Facebook contact sync integration (must wipe to get this)
    • Disable Boot animation
    • Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
    • Long press home for recent apps (thanks brucekey)
    Hướng dẫn cài đặt:
    • Reboot Recovery
    • Wipe data/Factory Reset
    • Cài ROM và gapps
    • Khởi động lại
    Link tải:
    Bản ổn định nhất (4.0.4)
    Bản mới nhất (4.1.1)
    Gapps
  2. kieuminhvp
    kieuminhvp Thành viên
    máy đẹp. cấu hình khủng...=D>=D>=D>
