Giao diện (CFW) Nokia 5233 v21.1.004 Revenge^1/2/3/4
Thảo luận trong 'S60 5th: FIRMWARE - SIGN - HACKPHONE' bắt đầu bởi Be Yeu, 25 Tháng tám 2010.
  1. Be Yeu Super Moderator
    (CFW) Nokia 5233 v21.1.004 Revenge^1/2/3/4 by iwalkwithshadow
    DISCLAIMER- Khuyến cáo:
    Use this cfw at your own risk. Use only J.A.F to flash phone. I am not responsible for any loss or damage it may cost to your phone. Sử dụng giao diện này có thể gây nguy hại cho bạn . Chỉ sử JAF để flash điện thoại . Từ chối trách nhiệm về bất kỳ tổn hại nào gây ra cho điện thoại của bạn .
    REVENGE^1 FEATURES
    __________________________________________________ ___
    UI acceleration patch enabled
    Conversations Application integrated in Ui and option available in Messaging
    Gaming and various apps fps increased to 72
    Processor Timing increased to 100%
    default light timeout decreased to get better battery efficiency.
    Default file manager can send sis,sisx,java[​IMG] etc protected files
    You can install any unsigned application without signing.
    The uninstall bug fixed and you can uninstall applications
    Default effects changed to ATLANTIS effects along with super turbo manifest.
    8 Homescreens added without any bugs.
    Oratsu homescreen got the N97 look.
    super fast screen rotation added.
    Heap size increased to get even more acceleration.
    Browser cache moved to E:
    Music player now reads only E:\Sounds\my music
    Camera sounds get disabled when you select Silent profile.
    Voice recording default quality set to high (records in mp4)
    Default ringtones sound changed to maximum.
    keypad lights enabled
    Sending sms to nokia after Hard reset disabled
    Startup applications disabled
    Camera will not eat ram after closing it.
    default themes
    default bootscreens.
    Call Timer Display during call enabled as default.
    Sent message limit increased to 500 as default.
    FOTA server reserved space reduced to gain 5 mb space on C drive
    Empty UDA file used to get most space out of C drive
    Around 80 MB available after Hard reset on C drive.
    During call if you use headphone the lights used to glow permanently but now They will switch off automatically.
    Roller Coaster Game Removed to Gain even More Space in C drive.
    Light Sensor Switched On
    Camera Quality Increased
    Sony Sketch Fonts Used Instead of Default Ones.
    Rompatcher+ Autostart + Autoapply (Patches On Z:\) 25 patches.
    Bluetooth name changed to "Revenge^1".
    Effects changed to Atlantis.
    QT 4.7 Beta and QT webkit Integrated .
    Hãy xem Google dịch .... thế nào :
    UI cho phép tăng tốc miếng vá
    Conversations ứng dụng tích hợp trong Ui và tùy chọn có sẵn trong Messaging
    Chơi game và các ứng dụng khác nhau tăng lên đến 72 fps
    Thời điểm xử lý tăng lên 100%
    giảm thời gian chờ mặc định ánh sáng để có được hiệu quả pin tốt hơn.
    Quản lý tập tin mặc định có thể gửi sis, sisx, java vv bảo vệ tập tin
    Bạn có thể cài đặt bất kỳ ứng dụng unsigned mà không cần ký.
    Các lỗi gỡ bỏ cài đặt cố định và bạn có thể gỡ bỏ cài đặt các ứng dụng
    Mặc định hiệu ứng thay đổi để Atlantis hiệu ứng cùng với siêu turbo manifest.
    8 Homescreens thêm vào mà không có bất kỳ lỗi.
    Oratsu màn hình có những cái nhìn N97.
    siêu xoay màn hình nhanh nhất.
    Heap kích thước tăng lên để có được tăng tốc hơn nữa.
    Bộ nhớ cache của trình duyệt chuyển đến E:
    Máy nghe nhạc bây giờ đọc chỉ E: \ Sounds \ âm nhạc của tôi
    Camera nhận được vô hiệu hóa âm thanh khi bạn chọn Silent profile.
    Voice chất lượng ghi âm mặc định đến cao (tại mp4)
    nhạc chuông âm thanh mặc định thay đổi để tối đa.
    bật đèn bàn phím
    Gửi tin nhắn cho nokia sau khi Hard reset tàn tật
    Ứng dụng khởi động tàn tật
    Camera sẽ không ăn ram sau khi đóng nó.
    mặc định các chủ đề
    bootscreens mặc định.
    Thơi gian cuộc gọi trong khi gọi hiển thị được kích hoạt mặc định.
    Gửi tin nhắn giới hạn tăng lên đến 500 là mặc định.
    FOTA máy chủ dành riêng không gian để đạt được giảm 5 mb không gian trên ổ đĩa C
    UDA trống tập tin được dùng để nhận ra không gian nhất của ổ đĩa C
    Khoảng 80 MB có sẵn sau khi thiết lập lại cứng trên ổ đĩa C.
    Trong khi gọi nếu bạn sử dụng tai nghe đèn được sử dụng để phát sáng vĩnh viễn nhưng bây giờ Họ sẽ tự động tắt.
    Roller Coaster Game gỡ bỏ để tăng thêm ngay cả không gian trong ổ C.
    Cảm biến ánh sáng Switched On
    Camera chất lượng tăng
    Sketch Sony Fonts sử dụng Thay vì Ones mặc định.
    RomPatcher + Autostart + Autoapply (Patches Ngày Z: \) 25 bản vá lỗi.
    Bluetooth tên đổi thành "Revenge ^ 1".
    Hiệu ứng thay đổi để Atlantis.
    QT 4,7 Beta và WebKit QT tích hợp
    __________________________________________________ _____
    REVENGE^1 CAPS
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    __________________________________________________ ______________________________________
    REVENGE^2 FEATURES
    Kinetic Scrolling optimized.
    Default file manager can send sis,sisx,java etc protected files
    Default effects changed to GLIDE effects along with super turbo manifest.
    9 Homescreens added With symbian^3 HS.
    Oratsu homescreen got the Windows 7 look.
    default themes
    Bluetooth name changed to "Revenge^2".
    Startup Tone changed to that of N97
    Keypad Unlock/lock Vibration disabled
    Widget Settings from the menu removed.
    Samsung Bottom Toolbar removed to Perfectly use Symbian^3 HS(Flash Live).
    Some new Ringtones added.
    Nokia Black Splashscreen + Shutdown Screen.
    Symbian^3 Homescreen Changed to N97 lookalike Screen
    Long Pressing 0 from dialler Opens Kill me Instead of browser
    Patches Now Automatically get transfered to E:\patches so you can easily use C2Z
    Autoapply patches - Open4all+, Installserver+, Shortdoublttap .
    Oratsu Changed to Windows 7 Style .
    Light themes + dark themes so firmware will look good on both white + black cellphones.
    Mail for exchange removed
    VOLUME BUG PARTIALLY FIXED IN FLASH LIVE HS NOW WHEN U OPEN MUSIC PLAYER[​IMG] AND EVEN WHEN ON HOMESCREEN THERE WONT BE ANY VOLUME BUG THOUGH WHEN PLAYER IS SWITCHED OFF THERE WILL BE FLASH VOLUME BAR
    but you cant view flash files on phone through file manager
    Note- Hard reset once after Flashing Or the n97 FLASH HS will be blank[/b]
    REVENGE^2 CAPS
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    REVENGE^3 FEATURES
    Default effects changed to Custom GLIDE effects along with super turbo manifest.
    9 Homescreens added With Andre's BlueSpectrum HS.
    Oratsu homescreen got the HTC look.
    default themes
    79.3 MB available after Hard reset on C drive.
    Bluetooth name changed to "Revenge^3".
    Widget Settings and Widgets Added
    Samsung Bottom Toolbar Added
    25 Patches Now Automatically get transfered to E:\patches so you can easily use C2Z
    Touch Vibration by default disabled
    Buggy and unsupported patches removed
    lags in the menus removed
    Custom Improved kinetic scrolling
    Volume Bug removed thanks to Andre
    Navigation Bar and Fullpage HS now Having Dialler and Contacts
    Camera Click sound changed to N8 default sound .
    Andre's HS Modded - Btswitch changed to Bluetooth , Default samsung menu bar added , Nokia Maps Icon changed to Music Player
    Everything like gadget.swf + patches + icons get copied to E:\ when you hard reset the phone so its necessary to hard reset.
    UPDATE:
    Screen Brightness bug Fixed
    Mini qwerty removed
    BLuetooth Name changed to Revenge^3
    Profile General Renamed to "Revenge"
    Note- Hard reset once after Flashing Or the Many Features will not work properly
    REVENGE^3 CAPS
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    REVENGE^4 FEATURES
    Kinetic Scrolling optimized and customised.
    Processor Timing Vary acording to various versions
    default themes
    78.6 MB available after Hard reset on C drive.
    Default FOnts used
    No rompatcher needed as firmware uses installserver mod from PNHT
    Bluetooth name changed to "Revenge^4".
    Everything like gadget.swf + icons get copied to E:\ when you hard reset the phone so its necessary to hard reset.
    Lags in the pop-up menus removed
    THERE IS NO QT IN ANY REVENGE^4 cfw
    Light sensor Settings Removed to Fix Brightness Bug
    Revenge^4 (MODERATE USE) :
    9 HS including Omnia widgets Original quality with 0 Redbug + No volume bug
    100% CPU time
    60 FPS
    Revenge^4.1 (MUCH USE) :
    50% CPU time
    Device fps 11.
    Revenge^4.2 (LESS USE):
    100% CPU time
    Device FPS 60
    CPU MOD added to give You incredible performance
    fastest Revenge ever .
    Revenge^4.3 (Less USE):
    8 HS with no FLASH HS
    100% CPU time
    Device fps 60
    CPU MOD to Give Incredible performance.
    No volume bug , No red bug , No browser bug
    100% bug free firmware.
    Revenge^4.4 (Moderate USE):
    100% CPU time
    Device fps 60
    No volume Bug , No red bug , no Browser bug
    100% bug free
    Revenge^4.5 (HEAVY USE) :
    50% CPU Time
    device fps 11
    No volume , red or browser bug.
    100% bug free
    REVENGE^4 CAPS (ONLY 9 HS version CAPS)
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    DOWNLOAD
    REVENGE^1:
    WITH BLACK THEMES(BLACK PHONES) :
    Code:
    http://www.mediafire.com/file/or6744csqsddjs9/Revenge^1 Black.rar
    WITH WHITE THEMES(WHITE PHONES):
    Code:
    http://www.mediafire.com/file/3q3b055351ya3dv/Revenge^1white.rar
    REVENGE^2:
    FOR BOTH BLACK AND WHITE PHONES :
    Code:
    http://www.mediafire.com/file/7dt6naaygf5fdkr/Revenge^2.rar
    REVENGE^3:
    Code:
    [URL]http://www.mediafire.com/file/akccmavaa7ljma3/Revenge%5E3.rar[/URL]
    Revenge^4:
    9HS , No CPU mod , 100% CPU time
    Code:
    [URL]http://www.mediafire.com/file/27hwqfe0502r0lo/Revenge%5E4%20100%20time%20no%20CPU.rar[/URL]
    Revenge^4.1:
    9HS , NO CPU mod , 50% CPU time
    Code:
    [URL]http://www.mediafire.com/file/4e5j8ro777g6pkr/Revenge%5E4.150%20time.rar[/URL]
    Revenge^4.2:
    9HS, CPU MOD , 100% CPU time
    Code:
    [URL]http://www.mediafire.com/file/j2k3ahhb2c65hiu/Revenge%5E4.2%20CPU%20MOD%20100%20time.rar[/URL]
    Revenge^4.3:
    8HS , CPU MOD , 100% CPU time
    Code:
    [URL]http://www.mediafire.com/file/w6j7h0277aa2dfu/Revenge%5E4.3%208HS%20CPU%20MOD%20100%20TIME.rar[/URL][URL="http://www.mediafire.com/file/w6j7h0277aa2dfu/Revenge%5E4.3%208HS%20CPU%20MOD%20100%20TIME.rar"]
    [/URL]
    Revenge^4.4:
    8HS , No CPU mod, 100% CPU time
    Code:
    [URL]http://www.mediafire.com/file/48txg62844xrwm9/Revenge%5E4.4%208HS%20100%20time%20no%20CPU%20mod.rar[/URL]
    Revenge^4.5:
    8HS , No CPu mod , 50% CPU time.
    Code:
    [URL]http://www.mediafire.com/file/vay7dog5hak59uk/Revenge%5E4.5%208HS%2050%20time%20no%20CPu.rar[/URL][URL="http://www.mediafire.com/file/vay7dog5hak59uk/Revenge%5E4.5%208HS%2050%20time%20no%20CPu.rar"]
    [/URL]
  2. vode_vovo
    vode_vovo Thành viên
    help
    hướng dẫn cách làm đi bạn
  3. Còm.
    Còm. Giả Vờ Hết Staff Member
    Bạn tìm cho mình 1 bản COOK thích hợp nhất rồi chép đè vào FW gốc sau đó tiến hành FLASH với công cụ là JAF hoặc Phoenix thôi :)
    quynhhvqy and symbian 9.x like this.
  4. quynhhvqy
    quynhhvqy Thành viên
    Mình thử thay nhưng khi flash nó toàn báo lỗi,ma không biết là nên thay fille nao nữa. Bạn có thể up một bộ FW chuẩn của 5233 lên không. Mình down về mà không dùng được..hichic
  5. Còm.
    thế này nhé bạn! có thể chọn lấy 1 bản CFW ở trên hặoc down cái này về đổi tên thành RM-625_21.1.004_C02_prd.rofs3
    rồi chép đè vào FW gốc( bạn down bằng NaviFirm về trước đó) rồi tiến hành Flash thôi!
    có lỗi gì cứ post lên đây ae giải quyết giùm bạn ! :)
    [URL]http://www.mediafire.com/?znienmdfm2itini[/URL]
  6. quynhhvqy
    copy cả hai file trong đó hay chỉ cần cóp file RM-625_21.1.004_C02_prd.rofs3 vậy. em cóp ca hai file thi cứ báo lỗi file RM-625_21.1.004_prd.rofs2.v20..
    Em muốn cài giao diện Revenge^2 o trên nhưng ma không cài được,khi flash nó báo lỗi các file trong mục Revenge^2,mạc dù em đã đôit tên như hướng dẫn..hic
    [​IMG][/IMG]
  7. Còm.
    bạn down FW 20 hay 21 về vậy? nó báo lỗi update FW 20 kia mà? có lẽ đang có sự nhầm lẫn về FW COOK với FW gốc rồi :)
    Bản CFW trên với cái mình post là của FW 21 bạn nhé!
  8. quynhhvqy
    EM down đúng bản 21 ma,tất ca fw của 5233 đều có 1file tên như vậy ,kể ca ban 12 cũng thế. em thử mấy cái mà không được,die ca phone luôn..hic
  9. Còm.
    vạy thì đến lúc chuyển qua JAF để làm rồi bạn nhé! PHoenix khi up các FW mới này hay lỗi quá =.="
  10. quynhhvqy
    thuọiEm tthu tat ca may cai tren nhung ma khong co cai HS flash live,chi dc 8 HS thoi.
