Gif Tailor - Tạo ảnh động trên điện thoại.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi minhchau, 16 Tháng tám 2010.
  1. GifTailor v2.11 S60v3/v5 SymbianOS9.x Unsigned Freeware by Luomao2000
    Gif Tailor allows you create cool glitter frame gif images with your own photos or screenshots on your handsets.
    Features
    1, * support for screen shot
    2, * to import jpg / gif / png / bmp / mbm picture
    3, * to save a single picture to a jpg / gif / png / bmp / mbm files (you can achieve the image format conversion)
    4, * adjust animation speed can be a unified, single frame can be adjusted
    5, * can be very convenient to adjust the location of the frame all gif
    6, * Support watermark, transparent color to pure white (255, 255, 255), can be used to support the picture as a watermark
    7, * Support for touch screen, you can drag images to the designated location
    8, * adjustable output image quality
    9, * GIF picture can be split
    List of shortcuts:
    0 to delete all the pictures
    1 position in the current insert picture
    3 additional one picture to the last
    4 forward a current picture location
    5 Save the current selected picture
    6 after the current picture of a position shift
    * Set the current selected picture of the delay
    Preview GIF animation OK.
    Change Log :
    1, additional drawings quality settings, capture lower quality, the smaller the generated temporary files may be recorded in the animation longer;
    2, additional support for the firmware on DIY;
    3 additional hotkeys: volume increase and volume reduction (some models may only be used in the software interface)
    4, MBM watermark can be set using the mask of anti-Israel;
    5, amended the file extension and file format can not decode the file does not match the bug;
    6, the amendment will not mask the picture as a watermark, pure white (255,255,255) is not transparent color bug.
    Download
    qweewq thích bài này.
  2. tichau
    tichau Guest
    GifTailor v2.12 S60v3/v5/S^3 SymbianOS9.x Unsigned Freeware
    Tailor the use of GIF can easily create animated GIF files, with the following
    Features
    List of shortcuts:
    Change-log
    1, the fixed part of the phone can not use the volume keys to capture the bug
    2, revised some of the phone can not properly use the file dialog bug (mainly Symbian 3 handsets)
    3, to increase support for symbian ^ 3 models
    Download
