Glow Go Launcher Ex Theme v1.3
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 28 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.0
    Ảnh chụp màn hình:
    Thông tin chi tiết:
    A ultra-detailed Tron Legacy inspired Go Launcher EX Theme**NEEDS GO LAUNCHER EX - TO APPLY THEME, READ THE "HOW TO USE" DESCRIPTION BELOW**
    *This is the Go Launcher Ex version of the 1st Best Seller theme in Android Market!
    A ultra-detailed Neon Glow Go Launcher EX Theme.
    TONS of ICONS totally reskinned for this theme, a lot of new icons coming!
    HUGE ICON PACK: 350+ icons included!
    Multiple wallpapers included, more coming next!
    *SKIN FOR BETTER KEYBOARD AVAILABLE ON MARKET! CHECK IT OUT NOW! GLOW LEGACY KEYBOARD SKIN!*
    *NOW HOME WIDGETS AVAILABLE ON MARKET: Glow Legacy Widgets Pro - Get the Ultimate Glow Legacy experience on Android!*
    **LIVE WALLPAPER NOW AVAILABLE! GLOW LEGACY LIVE WALLPAPER! CHECK IT OUT!**
    For ICONS SUGGESTIONS, send an e-mail and suggest the icons you want see included in next theme update. I will make the
    updates available as soon as new icons are created.
    Designed for ALL RESOLUTIONS!!!
    WALLPAPERS SPECIFICALLY CREATED FOR HIS THEME AT: http://bit.ly/hnnP6S
    Requirements
    This is a GO LAUNCHER EX Theme and requires "GO LAUNCHER EX" app to use it.
    HOW TO USE:
    Search for GO LAUNCHER EX on Market.
    Install/Run GO LAUNCHER EX, press Menu-Preferences-Themes Preferences.
    Select "Glow Legacy Theme" and Apply Theme!
    *AFTER THEME UPDATE, RE-APPLY THE THEME TO SEE THE CHANGES!
    HOW TO APPLY CUSOM ICONS FROM ICON PACK:
    Tap an icon on your homescreen
    Click "Replace"
    Click "Theme's icon"
    On "selected theme" at the top, check Glow Legacy theme, if unchecked.
    Scroll the list and select the desired icon.
    Xem thêm trên Android Market:
     [URL]https://market.android.com/details?id=mx.golauncherex.tron&feature=search_result[/URL]
    Tải về:
    [URL]http://appstore.vn/a/index.php/home/app/783[/URL]
