[h=2]App Screenshots[/h] [h=2]Description[/h]Extended version of GO Launcher, one of the most popular home application.=About GO Launcher= GO Launcher is the most popular home app in Android Market. It allows users to customize home screen, change themes, use smooth transition animation as well as various widgets and screen locks. It brings you a fresh and extraordinary mobile operation experience. =Features= - Thousands of personalized themes - Various widgets and screen locks (weather, switcher, calendar…) - Extremely smooth transition animation - Smooth flipping operation - User-defined folder to easily categorize apps Many options in preferences to help you customize you phone! =Tips= 1. How to get themes, widgets and lockers? a) Search ‘go launcher theme’, ‘go widget’ or ‘go locker’ in Android Market. b) Use GO Store via menu button in GO Launcher. 2. How to set transition animation? Use ‘Effects settings’ via button in GO Launcher. 3. Icons are too small? Use ‘Icon Size’ option in ‘Preferences->Visual settings->Icons’ to make icons bigger. 3. Long press the app icon to enter editing mode on home screen and app drawer. 4. Glide up to open menu and glide down to pull down notification. 5. The widgets in the screenshots belong to GO Widget, attainable from Android Market or GO Store. =Important= 1. GO Launcher is a totally free app without any charge. 2. If you cannot set ‘GO Launcher’ as the default home app, download ‘Home Manager’ to fix it. 3. ‘DIRECTLY CALL PHONE NUMBERS’ permission? It's required by the feature to create shortcuts of ‘person’ and ‘direct dial’. GO Launcher won't make unattended phone call and cost your money. 5. ‘READ CONTACT DATA’ permission? It's required by the feature to create 'person' shortcut as well as to add contact folder. Our commitments are respecting user privacy and delivering cool experience. Please help us by rating this app and recommending to the others. Want an extreme makeover to your phone? Try it out! Follow Us on Facebook: http://www.facebook.com/pages/GO-Launcher-EX/110639522355878 Twitter: https://twitter.com/#!/golauncher Owned by and Visit 3G.cn Through Your Mobile. Copyright 2004-2011 All Rights Reserved. Download link PC Mã: https://play.google.com/store/apps/details?id=com.gau.go.launcherex&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5nYXUuZ28ubGF1bmNoZXJleCJd Download link APK --> Update ...
