Handy Safe Pro- Quản lý, mã hoá các thông tin nhạy cảm và riêng tư.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi minhtue, 6 Tháng ba 2010.
  1. minhtue Super Moderator
    Handy Safe Pro v1.03(3) Cr*cked By N0ePDA
    [​IMG] [​IMG]
    Handy Safe Pro features
    * Store passwords, credit cards details, user names, codes, accounts (email, Internet, shopping, bank), web pages, addresses, travel info, insurance policies, software keys and much more.
    * 35 unique information forms to store everything on your smartphone.
    * Custom templates to store specific information according to your needs.
    * Strong 448-bit data encryption (Blowfish) keeps your data private and secure. There is no effective codebreaking on Blowfish known publicly as of now.
    * New! URLs are treated as hyperlinks
    * New! Subfolders support
    * New! Possibility to restore items in case of accidental deleting
    * New! Autolock when Handy Safe is in background or if you don’t use Handy Safe for a certain period of time
    vanmaichoem thích bài này.
  2. tichau
    tichau Guest
    Paragon Handy Safe Pro v1.03.3 Incl Desktop S60v3 SymbianOS9.x Unsigned Proper -FoXPDA
  3. ola2682
    ola2682 Thành viên
    ban nao co the chi cho minh su dung phan mem nay voi.. Minh
    xin cam on!
    Gõ tiếng Việt có dấu khi tham gia forum.Tái phạm là lên bảng phong thần nhé.
  4. Khỉ Con
    Handy SafePro.v2.00(586).S60v3.SymbianOS9.x.Unsigned.Cr@ cKeD-By-R@me$h
    a new level of usability comes to data management applications with unbeatable security functionality. Customized graphical cards represent all your confidential information in an easy-to-use interface, and 448-bit Blowfish encryption guarantees absolute security. Keep your mind free of countless numbers and letters. Your important information is now in one place - safe, easy to access, and always with you.
    * New! New graphical card representation.
    * New! Set of 65+ preinstalled graphical templates and icons.
    * New! Card customization.
    * Sync with desktop client to ensure database integrity.
    * Strong 448-bit Blowfish data encryption guarantees absolute safety of your confidential information. There is no effective code breaking method currently known.
    * 35 unique information forms to store passwords, credit card details, codes, accounts (banking, email, Internet, shopping), web pages, addresses, travel info, insurance policies, software keys and much more.
    * URLs are treated as hyperlinks.
    * Subfolder support.
    * Autolock when Handy Safe Pro is in background or not used for a certain period of time.
    PC:-
    Handy Safe Desktop Professional 2.0 – easily store, edit, share and sync your private information. Redesigned and powerful, this app is ready to become your #1 personal data manager. Uncompromised security is guaranteed.
    Handy Safe Desktop Professional 2.0 features
    * Easy access to your private information on a PC.
    * New! New graphical card representation with set of 65+ preinstalled templates and icons.
    * New! Windows Vista and Windows 7 support.
    * New! Sync with Android devices (Handy Safe Pro for Android required).
    * New! Improved sync mechanism.
    * 448-bit Blowfish data encryption technology.
    * Quick search within your entire database.
    * Fast navigation to necessary web pages with open URL function.
    * Create encrypted backups to restore your private data in case of any hardware or software problems.
    * Share your information via email.
    * User defined database location.
    * Show\hide password function.
    * Import database from SpashID, eWallet, FlexWallet, CodeWallet Pro.
    Note:-
    • [*]All Full Version Setting Are unlocked No Need to Register..!
      [*]And Constant Trial Period ...
    trinhvanhai165 thích bài này.
  5. xitrum08
    xitrum08 Thành viên
    Sao key không sử dụng được vậy bạn ơi !
  6. tichau
    tichau Guest
    Bản này đã bẻ khóa rồi mà bạn.Nhập ADGJMPTW-WTPMJGDA là xong thôi mà.
  7. xitrum08
    xitrum08 Thành viên
    Mình nhập serial ADGJMPTW-WTPMJGDA vào chương trình "Handy Safe Desktop Professional" thì nó báo là "Wrong serial number" , bản trên Mobile thì OK
  8. Khỉ Con
    bản trên desktop thì dùng làm gì hả bạn trẻ @_@, phần mềm ở pc thông minh gấp tỉ lần ở mobile, sao phải dùng phần mềm của mobile trên desktop làm gì
  9. xitrum08
    xitrum08 Thành viên
    Đó là tùy nhu cầu ý mà, mình quản lý 1 đống mật khẩu, lưu trên cái mobile qua chương trình này, lỡ mất cái mobile là tiêu à! Vì thế mình sử dụng bản cài trên PC (bản Handy Safe Desktop) để đồng bộ dữ liệu với cái mobile. Không biết bạn có sử dụng chương trình này chưa vậy ?! Mình xài chương trình này (vesion cũ) trên Windows mobile & PC lâu rùi, sau này chuyển qua Symbian.
  10. tichau
    tichau Guest
    Epocware Handy Safe Desktop Professional v1.00.14 S60v3 SymbianOS9.x Regged-takashiro
    Bạn dùng thử bản destop này xem sao nhé.
    Register code: 43919450-81745117
    Muốn cám ơn thì chỉ cần click vào nút thanks ở cuối bài viết thôi nhé.Không cần nói lời cám ơn đâu =)).
    xitrum08 thích bài này.
