hic, cho em xin crack của vNes for Java
Thảo luận trong 'S60/S80/S90: GAMES - TRÒ CHƠI' bắt đầu bởi michealdao, 3 Tháng mười 2005.
  1. michealdao Thành viên
  2. huydinh83
    huydinh83 Thành viên
    là sao? ý tui là vnes for Java là cái giống gì? nếu ý bạn là vnes thì dùng chức năng tìm kiếm của diễn đàn sẽ thấy ngay
  3. babygoat
    babygoat Thành viên
  4. tacaza
    tacaza Thành viên
    Sao ko có full, tại ko bit crack đó thôi. Nó đây nè, bác làm theo hướng dẫn để crack, có gì ko hiu thì bác hỏi.
    Hướng dẫn:
    1. Extract the vNES.zip into a folder. Open WinRar
    2. Click File -> Open Archive
    3. Browse through the folder and open vnes.jar
    4. You should see a list of files in WinRar.
    5. Find the file INES Demo.nes and delete it (This removes the demo ROM to save space)
    6. Click Commands -> Add Files to Archive
    7. Browse and select the rom you want to play and click add.
    NOTE: It must have a .nes extension and the extension MUST be in lower case! Ensure you do not have "Save Full Path" selected under the Files Tab in the Add Archive dialog box.
    8. Find and open the file named 2.txt it will open in Notepad.
    9. Delete the line that says INES Demo (since you deleted it in step 5)
    10. Enter the name of the rom you added in step 7 without the .nes extension.
    NOTE: It is case sensitive. You MUST leave a blank line on the bottom of the page.
    11. Click File -> Save
    12. Click File -> Exit. WinRar will ask you if you want to update the file. Click Yes
    13. Exit WinRar.
    All that remains now is to update the .jad with the new filesize of the .jar
    14. Right click on vnes.jar and click Properties
    15. Note down the Size in bytes (Not the size on disk!)
    16. Click OK.
    17. Open Notepad
    18. Click File -> Open
    19. Browse to and open vnes.jad
    20. Change the MIDlet-Jar-Size: to the number you noted downin step 15 without the comma!
    21. Click File -> Save
    Thats it. You can now transfer using Nokia Applications Installer, MobiMB or similar program.
    Final Note: You can add more than one ROM to the vNes.jar file and you just need to add all the .nes roms to the vnes.jar file and type all the game names into the 2.txt file with each game on a seperate line.
    NOTE: This is a Java Version for MIDP2.0 phones, e.g. 6230, and you should not expect good framerates. The tested speed for a Nokia 6230 was less than 30 FPS.
    However, the best results are archived with one ROM loaded at a time and the total size not exceeding 128kb. (Theo iphone-forum.org)
    • vnes.zip
      Kích thước:
      199 KB
    phoenixxvm8 thích bài này.
  5. huydinh83
    symbian giả lập snes còn mệt nữa huống chi là java,
