Yêu cầu: 2.1+ Hướng dẫn sử dụng: 1. Start Hidden Lock service 2. Move around the lock/unlock icon anywhere on your screen. 3. Use the progress bar to change the icon size. 4. Press FINISH ! 5. Your are done! (Remember the unlock icon position when you'll come back from the Android lock-screen) Features: *Enable/Disable default system lock : If you remove system lock, the trackball and volume keys (not all phones) can be used to wake your device from the lock-screen mode. Disabling system lock may not work properly on some phones : Security policies forces lock-screen pin or password. *Hidden Lock widget option. *Hidden Lock on boot option. *Long press on search key to activate "Hidden Lock" * Active "Hidden Lock" after -Immediately -30 sec. -1 min -5 min -10 min -15 min Many Lockscreen : - None : No lockscreen if you disable the default system lock. - Hidden Lock : Only remember the unlock icon position to unlock your device. - Hidden PIN : Only enter you PIN to unlock your device. Xem thêm: Mã: https://market.android.com/details?id=tv.marinelli.android.HiddenLockPro&feature=search_result Tải về: http://appstore.vn/a/index.php/home/app/2272
Xóa gì vậy bạn ? Thứ nhất, link tải vẫn tổt, thứ hai, tôi bận nên chưa xóa thời gian dịch, mang phần mềm mới đến cho các bạn là tốt lắm rồi. Chẳng xóa 4rum nào ở Việt Nam cập nhật nhanh như đây đâu !
What's in this version: 2011-09-13 - Version 1.7 Add HiddenLock in Shortcut list Lock action on application start (Change settings) Add an option to show Emergency Call button in lock screen Fix layout for low resolution Set the unlock icon default size to 72 Add option to customize lock message (title, icon, message)
What's in this version: 2011-09-17 - Version 1.8 Fix the vibration on unlock icon Add an option to set screen orientation in lock mode Add an option to show / hide status bar in lock mode Add an option to turn off screen when active Hidden Lock with widget, shortcut, long press search.
What's in this version: 2011-09-30 - Version 1.10 Improve On alarm Alert Fix On device startup action Fix the disable lockscreen method after reboot. Add an option to allow volume key in lock mode. Add an option to change lock dialog transparency. Increase unlock icon size for tablet Add an option to change the unlock shape (Circle) 2011-09-30 - Version 1.10.1 Fix strings in xml resource
