Hiển thị Đồng Hồ chờ cho L7()!
Thảo luận trong 'Điện Thoại Phổ Thông' bắt đầu bởi trung dung, 2 Tháng sáu 2007.
  1. trung dung Thành viên
  2. trung dung
    Dưới Đây là Tổng hợp Seem map của L7 mình biết dc!
    Pictures for caller identification from transflash card:
    seem 0032_0001 and go to offset 8C and at bit 2 check the bit to enable caller id pictures from TF.
    Enable idle Clock
    Seem 0032_0001 offset 7C-bit 2(check)
    use your phone without the sim card:
    SEEM 004a_0001 offset 4D bit 0: (set off)
    enable PTT setting & PTT key (discovered by Yuet)
    SEEM 0032-0001 offset 66 bit 6: (set off)
    SEEM 0032-0001 offset 7D bit 1: (set on)
    SEEM 0032-0001 offset 83 bit 0: (set on)
    SEEM 0032-0001 offset 8c bit 7: (set on)
    SEEM 005B-0001 offset 17 (set value to 40 to set smart key = PTT key)
    option to switch storage device (discovered by Yuet)
    SEEM 0032-0001 offset 9F bit 3:
    on = switch to phone memory/memory card directly in list, java apps will be installed in card when "install new apps"
    off = press menu key to see "switch storage device" option, will prompt to select storage device when "install new apps"
    enable/disable USB charging
    SEEM 004a_0001 offset 0207 bit 0: (1 enable, 0 disable)
    enable quadband (850/1900 & 900/1800)
    SEEM 0025_0001 offset 00 bits 0, 1, and 3 (all set on)
    SEEM 0025_0001 offset 00 bit 2 (set off)
    SEEM 0032_0001 offset 50 bit 0: (set on)
    unlimited video (Flash dependent) (Make video recording longer than 1.5 minutes, up to about 30 minutes.)
    SEEM 004E_0001 offsets 412, 413, 41E, 41F: (set all values to FF)
    video type
    SEEM 004a_0001 offset 1D1 (01 = 3gp, 03 = mp4)
    enable video styles (B&W/Bluish/Antique/Reddish/Greenish/Negative)
    SEEM 0032_0001 offset 82 bit 0: (set on)
    SEEM 0032_0001 offset 81 bit 2: (set on)
    SEEM 0032_0001 offset 81 bit 3: (set on)
    SEEM 0032_0001 offset 81 bit 4: (set on)
    SEEM 0032_0001 offset 81 bit 5: (set on)
    SEEM 0032_0001 offset 81 bit 6: (set on)
    SEEM 0032_0001 offset 81 bit 7: (set on)
    Operator name
    SEEM 0032_0001 offset 40 bit 4: (off = show operator name stored in plmn_text_table.bin, on = show operator name stored in sim card)
    Fix problem of showing "cingular" when using "T-mobile" SIM and get rid of the Roam triangle icon
    SEEM 0032_0001 offset 4B bit 6 (set on)
    SEEM 0032_0001 offset 34 bit 3: Roaming triangle icon (set off)
    Voice Message Indicator, instead of receiving SMS notification
    SEEM 0032_0001 offset 02 bit 1 (set on)
    enable autoupdate of Time & Date
    SEEM 0032_0001 offset 00 bit 0: (set on)
    SEEM 0032_0001 offset 55 bit 2: (set on)
    enable GPRS auto-attach at power-on
    SEEM 010a_0001 offset 00 bit 0: (set on)
    SEEM 010a_0001 offset 00 bit 1: (set off)
    enable GPRS auto-detach after GPRS session
    SEEM 010a_0001 offset 00 bit 1: (set on)
    Menu items (flash-dependent. require menu code to be in mma file)
    SEEM 0032_0001 offset 65 bit 1: IM Instant Messenger (1 enable, 0 disable)
    SEEM 0032_0001 offset 52 bit 6: AIM (1 enable, 0 disable)
    SEEM 0032_0001 offset 54 bit 2: Mobile QQ (1 enable, 0 disable)
    General setting
    SMS storage location: SEEM 0032_0001 offset 40 bit 6: (0 = phone, 1 = SIM)
    Java splash screen display: SEEM 0032_0001 offset 71 bit 6: (1 on, 0 off)
    Swap Softkeys function: SEEM 0032-0001 offset 89 bit 5 (1 on, 0 off)
    Dashes in phone number: SEEM 004a_0001 offset 80 (set value to 01 for "no dash", 00 for "with dashes")
    Match name in phonebook with caller ID number: SEEM 0032_0001 offset 3E bit 4 (0 = partial match, 1 = exact match)
    General option
    SMS Setup - Store To: (SIM/Phone): SEEM 0032_0001 offset 9A bit 1: (1 on, 0 off)
    Initial Setup - Auto Redial: SEEM 0032_0001 offset 00 bit 2: (1 on, 0 off)
    Initial Setup - Battery Save: SEEM 0032_0001 offset 1D bit 6: (1 on, 0 off)
    Initial Setup - TTY Setup: SEEM 0032_0001 offset 47 bit 3: (1 on, 0 off)
    Initial Setup - Vibe sync: SEEM 0032_0001 offset 68 bit 0: (1 on, 0 off)
    enable custome startup/shutdown sound & animation
    SEEM 004a_0001 offset 22 (Set value to 01 for custom startup sound stored in /a/mobile/audio/Cust_Start~up.mp3. In some branded firmwares, it can be .mid file or located at /c/mobile/audio/)
    SEEM 004a_0001 offset 23 (Set value to 01 for custom startup/shutdown animation stored in seems 0206/0208, usually "/a/custwakeup.gif" and "/a/custgoodbye.gif")
    SEEM 004a_0001 offset 24 (Set value to 01 for custom shutdown sound stored in /a/mobile/audio/Power~down.mp3. In some branded firmwares, it can be .mid file or /c/mobile/audio/)
    SEEM 0032_0001 offset 1D bit 3: Moto Startup Animation (Set off)
    SEEM 0032_0001 offset 24 bit 3: Custom Startup/shutdown Sound (Set on)
    Custom Outer LCD Text
    SEEM 004a_001 offset 27: set value to "01".
    SEEM 0061_0001 & 0062_0001: store your custom text.
    (there must be a hex value of "00" in between each character in 0061/0062 SEEM. At the end of the text, you must put hex values of "00 00" and the rest after "00 00" is filled with hex values of "FF". This requires restart to see the change.)
    Custom Outer LCD image
    SEEM 004a_001 offset 27: set value to "00".
    SEEM 0061_0001 & 0062_0001: store the path to the custom gif file, for example /a/cl.gif
    Recent Calls option
    SEEM 0126_0001 offset 03 bit 5: to same number in Dialed Calls (1 = list only most recent call, 0 = list all calls)
    SEEM 0126_0001 offset 03 bit 6: from same number in Received Calls (1 = list only most recent call, 0 = list all calls)
    Increase number of stored received calls
    SEEM 0050_0001 offset 8F
    SEEM 0051_0001 offset 8F
    (set value to hex value of the number, for example, "32" = 50 numbers; "63" = 99 numbers)
    Increase number of stored dialed calls
    SEEM 0050_0001 offset 93
    SEEM 0051_0001 offset 93
    enable phonebook photo from TF card
    SEEM 0032_0001 offset 8C bit 2: (set on)
    to what ring style to swap when press & hold # key
    SEEM 004a_0001 offset 1ED:
    set value to 01 = soft
    set value to 02 = vibrate
    set value to 03 = vibe then ring
    set value to 04 = silent
    set value to 05 = vibe&ring
    use the phone without a SIM card
    enable 300K MMS download limit
    SEEM 0032-0001 offset 7F bit 0: (set on)
    SEEM 004e-0001 offset 2e1 bit 2: (set on)
    SEEM 004e-0001 offset 2e2 bit 4, 5 & 7: (all set on)
    SEEM 004f-0001 offset 2e1 bit 2: (set on)
    SEEM 004f-0001 offset 2e2 bit 4, 5 & 7: (all set on)
    Fix white-balancing problem of second photo
    SEEM 0032-0001 offset 6c bit 5: (set on)
    Bro nào Update với mình nhé!
    awp1323 thích bài này.
  3. secret1711
    secret1711 Thành viên
    Đồng hồ chờ của L7 có cũng như không thui, màn hình đen ngòm, khó nhìn lắm8-}
  4. thuycuong2007
    thuycuong2007 Thành viên
    alo! xin cho hoi SEEM dung lam gi?
  5. anhvu2875
    anhvu2875 Thành viên
    thuycuong2007
    seem dùng để quản lý các chức năng ẩn trên phone .
  6. lamthetoan
    lamthetoan Thành viên
    Phiền bạn hãy nói rõ hơn về cách cài đồng hồ chờ nhé. Ví dụ như là dùng chương trình gì? Các bước tiến hành, có trở ngại gì ko?/:)
  7. awp1323
    awp1323 Thành viên
    cái này chỉ làm cho điện thoại nhanh hết pin thôi, mà làm edit seem làm j cho mệt, flash luôn 1 bản mp là có ngay. nhưng đồng hồ chờ này khó nhìn lắm... tối om om, trừ khi đi ngoài trời nắng:-w
