HongDi Technology DuDu - ghi âm cuộc gọi hoàn hảo
Thảo luận trong 'ỨNG DỤNG QUẢN LÝ CUỘC GỌI - TIN NHẮN' bắt đầu bởi Khỉ Con, 17 Tháng mười hai 2010.
  1. Khỉ Con interista
    HongDi Technology DuDu v4.30 S60v3 S60v5 S^3 SymbianOS9.x UnSigned Cr@cked & InclKey By R@me$h
    DuDu is a Call Recorder for Symbian S60 phones. This application is easy to
    use, while retaining all of the features you'll ever need. DuDu uses super memory light AMR format, so you can literally record thousands of hours of
    calls on memory cards. You can browse, sort, delete and transfer all the
    phone calls with ease.
    Features :
    Automatic recording of phone calls.
    Unlimited Recording Time.
    Support recording in AMR formats.
    Support recording to internal memory or directly to memory card.
    Operate in background mode or/and user interactive mode.
    Always ready to accept hotkeys.
    Easy to manage/browse the details of all recorded clips such as caller id, duration, timestamp.
    Sort recorded clip by timestamp, phone number or person's name.
    Protects important conversations.
    Easy to retrieve the recorded voice clips using Nokia PC suite.
    Automatic startup upon phone power on. You can enable/disable this through the application settings.
    Compatibility:
    3250,5320,5500,5630,5700,5710,5730,6 110,6120,6121, 6122,6124, 6210,6220,6290,6650,6700slid,6710,6720 ,6730,6760,6 790,6788,6788i;
    C5,E5,E50,E51,E52,E55,E60,E61,E61i ,E62,E63,E65,E66 ,E70,E71,E71x,E72,E75,E90;
    N71,N73,N75,N76,N77,N78,N79,N80,N8 1,N82,
    N83,N85,N86,N91,N92,N93,N93i,N95,N 96;
    5800XM,N97,N97 mini,X6,5230,5235,5530XM,C6,N8
    Change-log:
    Some Minor Bugs Are Fixed For S60v3 & S60v5
    About Cr@cK:-
    No Need To Register..!
    ELSE
    IF it Asks for Key Then Register with Key.gen..!
    [URL="http://www.mediafire.com/?5k5b0p9daauaj38"]http://www.mediafire.com/?5k5b0p9daauaj38[/URL]
  2. p950q
    p950q Thành viên
    Úi giời hơi, thằng này cài vào khi gọi ghi âm thì nó kêp bip bip điếc cả tai mình lẫn tai người đối diện đừng hỏi, gỡ khẩn cấp.
  3. Khỉ Con
    HongDi Technology DuDu.v5.20 S60v3 S60v5 SymbianOS9.x UnSigned Cr@cKeD & Incl....... -By- R@me$h
    Features :
    Compatibility:
    Change-log:
    - Supprt Symbian^3: N8,C6,C7,E7.
    - Improve the speed to delete multi recorded clips.
    Attention: Don't UNINSTALL old version of DuDu Recorder, otherwise the recorded clips will be lost.
    About Cr@cK:-
    IF it Asks for Key Then Register with ........!
    [url=http://www.box.net/shared/u6py13sa5u]HongDi Technology DuDu.v5.20 S60v3 S60v5 SymbianOS9.x UnSigned Cr@cKeD & Incl.Keygen -By- R@me$.rar - File Shared from Box.net - Free Online File Storage[/url]
  4. tichau
    tichau Guest
    dangngockhanh thích bài này.
