HongDi Technology DuDu-Phần mềm ghi âm cuộc gọi (ver 5.60 - 27/7)
Thảo luận trong 'ỨNG DỤNG QUẢN LÝ CUỘC GỌI, TIN NHẮN' bắt đầu bởi nhuhienltd, 17 Tháng hai 2009.
  1. tichau
    tichau Guest
    HongDi Technology DuDu v3.30 S60v3 SymbianOS9.1 Unsigned-ErESPDA
    This application is easy to use, while retaining all of the features you'll ever need. DuDu use super memory light AMR format, so you can literally record thousands of hours of calls on memory cards.You can browse, sort, delete and transfer all the phone calls with ease.
    The application is a Symbian Signed application backed by the industrial standard Quality Assurance testing procedure.
    Features:
    Automatic recording of phone calls.
    Unlimited Recording Time.
    Support recording in AMR formats .
    Support recording to internal memory or directly to memory card.
    Operate in background mode or/and user interactive mode .
    Always ready to accept hotkeys .
    Easy to manage/browse the details of all recorded clips such as caller id, duration, timestamp.
    Sort recorded clip by timestamp, phone number or person’s name.
    Protects important conversion .
    Easy to retrieve the recorded voice clips using Nokia PC suite.
    Automatic startup upon phone power on. You can enable/disable this through the application settings.
    FREE Updates for the Life of your phone.
    What's new:
    - Fix bug: password protection error.
    - Add menu: play.
    - Add the identification: the software is running in the background.
    Attention: When install DuDu recorder, if smartphone pop message "Update error", please UNINSTALL old version of DuDu recorded first.
    lina, odessa and amax like this.
  2. lina
    lina Thành viên
    Các bác cho biết, vậy chứ sử dụng Hotkey cho phần mềm này là phím nào cho Nokia E71, xin chỉ giáo
  3. tichau
    tichau Guest
    HongDi Technology DuDu.v3.40 S60v3 S60v5 SymbianOS9.x Unsigned-mEnPDA
    Features:
    3250,5320,5500,5630,5700,5710,5730,6110,6120,
    6121,6122,6124,6210,6220,6290,6650,6710,6720;E50,E51,E55,E60,E61,E61i,E62,E63,E65,E66,
    E70,E71,E75,E90;N71,N73,N75,N76,N77,N78,N79,N80,N81,N82,
    N83,N85,N86,N91,N92,N93,N93i,N95,N96;5800XM,N97
    July 7,2009 DuDu Recorder 3.40 Release.
    What's new:
    - Improve the recording quality.
    - Add settings: Background Mode.
    - Add menu: Upgrade Notification.
    - New features: mobile phones less when the remaining space for alarm prompts (prompts the user to clean up in time).
    amax thích bài này.
  4. tichau
    tichau Guest
    HongDi Technology DuDu.v3.50 S60v3 S60v5 SymbianOS9.x Unsigned-mEnPDA/TgSPDA
    Features:
    Aug 3,2009 DuDu Recorder 3.50 Release.
    What's new:
    - Add settings: Custom recording shortcuts.
    - Fix the bug: Some times not recording calls.
  5. tichau
    tichau Guest
    HongDi Technology DuDu.v4.00 S60v3 S60v5 SymbianOS9.x Unsigned-mEnPDA
    Sep 12, 2009 DuDu Recorder 4.0 Released!
    Features:
  6. tichau
    tichau Guest
    HongDi Technology DuDu.v4.11 S60v3 S60v5 SymbianOS9.x Unsigned-mEnPDA
    Features:
    Oct 13, 2009 DuDu Recorder 4.11 Released!
    What's new:
    - Add settings: Record Mode.
    - Fix some bugs.
    mr.fjt thích bài này.
  7. tichau
    tichau Guest
    HongDi Tech DuDu v4.11 S60v3 SymbianOS9.1 Unsigned -ErESPDA
    Features:
    change log :
    - Fix some bugs.
    3250,5320,5500,5630,5700,5710,5730,6 110,6120,
    6121,6122,6124,6210,6220,6290,6650,6 710,6720;E50,E51,E55,E60,E61,E61i, E62,E63,E65,E66,
    E70,E71,E75,E90;N71,N73,N75,N76,N7 7,N78,N79,N80,N81,N82,
    N83,N85,N86,N91,N92,N93,N93i,N95,N 96;5800XM,N97
  8. Be Yeu
    HongDi Tech.DuDu v4.11 S60v3.v5 SymbianOS9.x Unsigned ******* Icon Modded-Ueshiba69
    [​IMG] [​IMG]
    Features:
    change log :
    - Fix some bugs.
    toiyeuv thích bài này.
  9. nguyenthong2501
    nguyenthong2501 Thành viên
    Sao toàn là tiếng a ko. không có hd sử dụng vầy nà! :(
    Giống như là khi ghi âm có kêu bíp bíp ko? Chất lượng ghi âm ra sao...
  10. Be Yeu
    Automatic recording of phone calls. Ghi âm tự động.
    Unlimited Recording Time. Không giới hạn thời gian ghi âm.
    Support recording in AMR formats . Hỗ trợ định dạng AMR.
    Support recording to internal memory or directly to memory card.Hỗ trợ save file ghi âm trên bộ nhớ phone hoặc bộ nhớ thẻ .
    Operate in background mode or/and user interactive mode . Chế độ Chạy ẩn hoặc tuỳ chọn .
    Always ready to accept hotkeys . Luôn sẵn sàng với các phím tắt.
    Easy to manage/browse the details of all recorded clips such as caller id, duration, timestamp.Quản lý dễ dàng theo chi tiết .
    Protects important conversion . Sắp xếp theo thời gian , số máy gọi, tên. Bảo mật file cá nhân .
    Automatic startup upon phone power on. You can enable/disable this through the application settings. Tự khởi động chương trình hoặc không khi bật máy.
