HongDi Technology DuDu-Phần mềm ghi âm cuộc gọi (ver 5.60 - 27/7)
Thảo luận trong 'ỨNG DỤNG QUẢN LÝ CUỘC GỌI, TIN NHẮN' bắt đầu bởi nhuhienltd, 17 Tháng hai 2009.
  1. huybee
    huybee Thành viên
    Mình cài trên E72 thì có tiếng beep khi ghi âm, rất khó chịu, mong được hướng dẫn cách khắc phục, xin cảm ơn các bạn .
  2. minhchau
    minhchau
  3. minhchau
    minhchau
    HongDi Tech DuDu Recorder v4.90 S60v3 S60v5 SymbianOS9.x Signed Read NFO Regged-FoXPDA
    DuDu is a Call Recorder for Symbian S60 phones. This application is easy to
    use, while retaining all of the features you'll ever need. DuDu uses super memory light AMR format, so you can literally record thousands of hours of
    calls on memory cards. You can browse, sort, delete and transfer all the
    phone calls with ease.​
    Features :
    * Automatic recording of phone calls.
    * Unlimited Recording Time.
    * Support recording in AMR formats.
    * Support recording to internal memory or directly to memory card.
    * Operate in background mode or/and user interactive mode.
    * Always ready to accept hotkeys.
    * Easy to manage/browse the details of all recorded clips such as caller id, duration, timestamp.
    * Sort recorded clip by timestamp, phone number or person's name.
    * Protects important conversations.
    * Easy to retrieve the recorded voice clips using Nokia PC suite.
    * Automatic startup upon phone power on. You can enable/disable this through the application settings.​
    Whats New :
    - Improved sound quality.​
    Register Keys
    24228518
    57101818
    23091818 ​
    yangexp thích bài này.
  4. Khỉ Con
    HongDi Tech DuDu Recorder v5.00 S60v3 S60v5 SymbianOS9.x Signed Regged FoxPDA
    Features :
    Compatibility:
    3250,5320,5500,5630,5700,5710,5730,6 110,6120,6121, 6122,6124, 6210,6220,6290,6650,6700slid,6710,6720 ,6730,6760,6 790,6788,6788i;
    C5,E5,E50,E51,E52,E55,E60,E61,E61i ,E62,E63,E65,E66 ,E70,E71,E71x,E72,E75,E90;
    N71,N73,N75,N76,N77,N78,N79,N80,N8 1,N82,
    N83,N85,N86,N91,N92,N93,N93i,N95,N 96;
    5800XM,N97,N97 mini,X6,5230,5235,5530XM,C6
    Changelog:
    - Fix the bug that can't start on 6788i.
    - Support recorded clips saving to F: disk(such as N97 ​
    MightyHeart thích bài này.
  5. cuti1910
    cuti1910 Thành viên
    Đã có phiên bản cho Symbian^3 chưa bác.
    E cài V5.00 trên con C7 của E nó báo lỗi " Error config -18" và không ghi âm đuợc. Nản quá!!! Đang cần ....
  6. Khỉ Con
    chưa có đâu bạn, mới có trên v3 vs v5 thôi :D
  7. lienhong75
    lienhong75 Thành viên
    HongDi Tech DuDu Recorder v5.00 tải về giải nén bị lỗi nhờ anh xem lại
    xin cám ơn !
  8. Khỉ Con
    đây nhé ^^
    [URL="http://www.mediafire.com/?t3sem8u4r9vcege"]http://www.mediafire.com/?t3sem8u4r9vcege[/URL]
    lienhong75 thích bài này.
  9. cuti1910
    cuti1910 Thành viên
    Bạn có biết trang chủ của thằng Hongdi tech dudu này không:D
  10. Khỉ Con
    đây nhé bạn :D. bạn định làm gì thế :))
    [URL="http://www.getdudu.com"]http://www.getdudu.com[/URL]
