Thảo luận HOT! E71 (rm346) ra fw mới ver 510.21.9 tiếng Việt
Thảo luận trong 'S60 3rd: FIRMWARE - SIGN - HACKPHONE & HACK APP' bắt đầu bởi Khỉ Con, 12 Tháng năm 2011.
  1. Khỉ Con interista
    Khỏi phải nói nhiều, anh em xem hình để chứng thực:
    Bản này thay đổi gì thì chưa rõ
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/11/--FID--A0A22SDWDAVAI/--LID--FiRe1259075910313/0AFBA3F1_hwc_size_Leevi_PI101_0561926_v1.0.bin
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/4/--FID--A0A22JBNTJJBO/--LID--FiRe1239786880161/3DB4D961_leevi_erase_y_drive.fpsx
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2010/6/--FID--A0A22PTGXPIDU/--LID--FiRe1277395650697/05D51BC6_CardVerRef_E71_5.0_040-063064.xml
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/11/--FID--A0A22GKSREBIF/--LID--FiRe1259075909027/5021C1D2_ccc_size_Leevi_PI101_0561926_v1.0.bin
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/10/--FID--A0A22HFCJXSOL/--LID--FiRe1254402298823/Inactive_sim_bb5.bin
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/4/--FID--A0A22QVPFEFAS/--LID--FiRe1303222061510/B02DFB94_RM346_0561926_510.21.009_001_signature.bin
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/2/--FID--A0A22TJXAUXJI/--LID--FiRe1235374930124/RM-346_TypeLabel_002.xml
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/4/--FID--A0A22LGGSTFSN/--LID--FiRe1303222060230/99308D12_RM346_0561926_510.21.009_001.spr
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/10/--FID--A0A22LBPMBLKO/--LID--FiRe1254402293312/RM_346_data_block
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/4/--FID--A0A22LDHDEXVN/--LID--FiRe1303222057856/4C74D438_RM346_0561926_510.21.009_001.vpl
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/4/--FID--A0A22SXJYXHUE/--LID--FiRe1303222058992/4FBF30ED_RM346_0561926_510.21.009_001.dcp
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2009/2/--FID--A0A22KMUYDTBM/--LID--FiRe1235374988245/062704v2.pcx
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/3/--FID--A0A22KNGICXDE/--LID--FiRe1300971930303/rm346_510.21.009.01U
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/3/--FID--A0A22NMEOUYBE/--LID--FiRe1301029449168/rm346_510.21.009_prd.v29
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2011/3/--FID--A0A22LKBWVQUB/--LID--FiRe1300971729685/rm346_510.21.009_prd.c00
    http://nds2.fds-fire.nokia.com/fdp/interface/FiRe/2010/6/--FID--A0A22ORCSRNJV/--LID--FiRe1277395652017/1D1404DF_E71_SW_040-063064_APACRegionMemoryCard_2G_5.0.fpsx
  2. yaiba
    yaiba Thành viên
    510 à? sao cái dãy số đằng sau giống ver cũ 500.21.009 nhỉ :)
    tối về thử liền.
  3. Khỉ Con
    Ver này vẫn hack tốt bằng hellox nhé !
    bluechatvn thích bài này.
  4. tinhcaydang
    tinhcaydang Thành viên
    Mình đã hack được bằng hellox.
    Cảm nhận của mình với ver mới là vào menu nhanh hơn,koo còn cảm giác bị treo như ver cũ
  5. verylove
    verylove Staff Member
    e71 lâu rồi mà nokia vẫn up fw đều đều nhỉ :D đang chờ xem e52 có ko :( ( thằng này bạn e72 nên chắc 2 thằng ra 1 lần :D )
  6. onelove2711
    onelove2711 Thành viên
    Up thiếu file hay có lỗi gì rồi.Up nó thông báo ko tìm thấy data bị thiếu file j rồi thì phải bạn check lại hộ với
  7. Khỉ Con
    vừa check, bạn thử lại xem sao nhé :d
  8. onelove2711
    Lần trước thì thiếu file DP.02[​IMG][/IMG]. lần này thiếu file DP.01
    File cuối là gì mà tận 600Mb vậy.Bạn up lun file .exe được ko?
  9. Khỉ Con
  10. khanhtinli
    khanhtinli Thành viên
    cho mình hỏi HOT FW E71 ( RM 346) ver 510.21.9 apac có tiếng việt không vậy mấy bác
