Hướng dẫn và thảo luận cách tạo font cho dòng Os 9.1(sưu tầm bằng tiếng Anh) Needed Software: CreaFont.zip FontCreator Nokia SDK for the 3rd edition Active Perl 5.6.1 Java Runtime 1.4.2 Start HERE: 1. First of all you will need to have all this necessary il.Socio package called CreaFont.zip. The package have all the necessary files to begin your fonts creation. 2. Begin modified 5 fonts include in the package aSans.ttf, aSansB.ttf, aSansSB.ttf, aSansTSB.ttf and aDigi.ttf. I recommend using FontCreator from http://www.high-logic.com 3. Using Font Creator you can begin open up the template font and the new font to begin the modification toward template 4. Copy and paste the new font to the replace the old aSans.ttf with the new font (repeat to the rest of the template fonts) Off course you also need to save it. 5. At this point you will have to complete the Symbian S60 3rd edition SDK package in order to run CreaFont.bat 6. Should all run well. You should create a new font.sis files and ready to installed them for your new S60 3rd edition phone. Special thanks for il.Socio for making this guides. ***Những font này ko dùng cho N91
