Hướng dẫn format application for s60
Thảo luận trong 'S60/S80/S90: KIẾN THỨC & KINH NGHIỆM' bắt đầu bởi davidnguyen, 22 Tháng sáu 2006.
  1. davidnguyen Thành viên
    How to Format ur s60 nokia phone
    Its important to read through this topic before you proceed with formatting, you will need to charge your phone at least half full to enable a successful format.
    Soft Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) - Hard Reset *#7370# : This reformats the C: drive completely and all applications and files stored on this drive will be lost. *
    With *#7370# and *#7780# the lock code will be asked before formatting the phone so be sure to remember your code, the DEFAULT CODE by nokia is 12345. *
    Firstly you might want to make a back up of all your important bookmarks, calender, notes and contacts, Using file manager go to c:/system/data find bookmarks.db for bookmarks, calendar for calendar, notepad.dat for notes, and Contacts.cdb for contacts. *
    Contacts can only be copied when phone is in offline mode/flight mode, use Psiloc System Tools for flight mode, not needed on 6630 or later. Or you can use Contact Manager app *
    Ok so 7650, 3650, 3660, ngage and ngage qd can only be formatted using *#7370# Before your format, be sure that the problem is on phone, remove mmc and see if problem still exists. *
    Also try starting in safe mode (press and hold pencil/abc key while turning on till op logo comes up). You can solve an apparent problem with simple solution
    6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up. *
    Fonts and Formatting. If you have any fonts installed be sure to remove them using Font Remover app or go to c/ or e/ system/ fonts/ and rename it to whatever and delete it now reboot phone before you attempt format. *
    and above all,this is very important,don't mess with file explorers (delete,rename,alter files) if you don't know what your doing. *
    and yes,formating phone (soft/hard) can screw some app's on mmc. Some will work fine,others don't coz they share files on both drives (c:/e: ) *
    OPERA - to copy opera bookmarks before formatting mmc, assuming opera is installed on e-drive. e/system/data/opera/bookmarks
    MÌNH LANG THANG TRÊN NET NÊN TÌM ĐƯỢC NẾU BÁC NÀO BIẾT RỒI THÌ ĐỪNG NÓI LÀ "XƯA" QUÁ NHA !!
    NẾU MÀ BIẾT RỒI THÌ DÀNH CHO MẤY ANH EM CHƯA BIẾT THAM KHẢO NHA !!
    MÌNH CHƯA DỊCH RA TIẾNG VIỆT MONG CÁC BẠN THÔNG CẢM
    doremon2005 thích bài này.
  2. sarstuthan
    sarstuthan Thành viên
    Thank bác, em muốn reset máy mà chẳng biết hỏi ai, chẳng nhẽ chạy lên Nokia hỏi ! Cũng may có bác
  3. tanthanh2009
    tanthanh2009 Thành viên
    Cái này là formate fone chứ fải format application mô!!!
  4. thanhthuytnn
    thanhthuytnn Thành viên
    cho minh hoi co ai biet cach cai dat cua nokia 3660 ? thi cho minh biet voi thanks
  5. kieu_phong
    kieu_phong Thành viên
    hic..hic..hic..
    pác viết tinh có tiếng ANH
    em ngừoi việt nam..chỉ quen nói tiếng việt thôi...để em xung phong dịch hộ các pác trên GSM này nhé..hic..hic..hic..đây là bài hứong dẫn Hướng dẫn format máy ..chứ có phải là application đâu
    http://www.gsm.com.vn/forum/main/showthread.php?t=3854&page=3
    còn đây là bài viết hứong dẫn của pác Daywalker
    Moderator
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    từ ngày 16-07-2004, 06:21 PM
    còn để xóa application thì chỉ có 2 cách:1 là vào E:\ system\ apps \ xóa các folde của nó đi
    2 *Nếu có 1 chương trình hay games mà bạn không muốn sử dụng thì cũng có thể vào Manager-- Options--Remove.
