sau khi up xong thì bạn Hải Phạm bên vietfones có hướng dẫn làm như sau để cài ứng dụng ======***======= These are step by step instructions on how to unlock your 1.1.4, 3.9BL iPhone using ZiPhone and Installer. This will work with a 4.6BL iPhone which has been downloaded to 3.9BL. To do this follow these instructions: Step One Restore your iPhone to 1.1.4 using iTunes. Do this by plugging your iPhone into the computer and pressing the Restore button in iTunes. Step Two Download the modified version of ZiPhone here (mirror). Thanks to JBLP for modding this! Step Three Double click the downloaded zip file to extract a folder called ZiPhone onto your desktop. Step Four Open a new Terminal window by launching it from the Applications:Utilities folder Step Five Navigate to the ZiPhone directory by typing this into Terminal: cd ~/Desktop/ZiPhone. Step Six Now to activate and jailbreak your iPhone type this into the Terminal windows: ./ziphone -a -j. Step Seven ZiPhone will put your iPhone into recovery mode and then tell you to wait 45s for the jailbreak and activate. Step Eight Once the jailbreak and activate is complete you must install BSD Subsystem on your iPhone __________________
Step Nine Once BSD Subsystem is installed you must add iClarified to your list of sources... add andress:http://installer.iClarified.com Step Ten Press to launch Installer from your SpringBoard. Step Eleven Press to select the Install Step Twelve Press to select iClarified from the list of Categories. Step Thirteen Press to select Unlock (1.1.4) from the list of Packages Step Fourteen Press the Install button After about 3-5 minutes you will get another notice saying that Your iPhone is now unlocked
nhưng đến bước thứ 4-5 thì mình pó tay vì khi mình vào Term thì nó chỉ báo password và không cho gõ vào như thế nào. Dtube có thể chỉ giúp mình được không
@namtuyen, Cách hướng dẫn này không phải cho iPlus. Mình sẽ dời ra để bà con không nhầm lẫn. Nên chú ý là cách hướng dẫn ở trên là cho phone đã có bootloader 3.9; và để chạy trên máy Mac chứ không phải PC. Cách unlock là dùng 114unlock của Crackn (nguồn gốc là từ gunlock). Cách này dùng ziphone nhưng file zibri.dat đã được sửa đổi bởi George Zhu. Chú ý thứ nhì là cách này chạy thẳng trên iphone. Hướng dẫn gốc ở đây - cho MAC Hướng dẫn cho PC ở đây Nên sử dụng iPlus hơn vì nó có cài thêm nhiều chương trình khác.
