Thảo luận Hướng dẫn Up Rom 4.4.2 bản Remix( Fix nhac chuong thanh cong )
Thảo luận trong 'M110S GALAXY S' bắt đầu bởi skynostar, 17 Tháng hai 2014.
  1. skynostar Thành viên
    File * http://www.mediafire.com/download/ricij41r95beta7/Fix+Ringtone.zip
    * http://www.mediafire.com/download/7r92ix19kgi2tq1/m110s-EFS_Backup-recovery.tar
    * http://www.mediafire.com/download/su0vd89giisyy8y/m110s-format-system.zip
    * http://www.mediafire.com/download/f61t7ppzeg9pgs6/m110s-installation-recovery.tar
    * http://www.mediafire.com/download/4grueva3kmcffbk/M110S_EFSBackupTool.zip
    * http://www.mediafire.com/download/1iqgfd0ccqy60i6/M110S_PatchTool.zip
    * http://www.mediafire.com/download/psg9ig982b09xp3/Resurrection_Remix_KK_v5.0.2.1-CoreGapps-i9000.zip
    * http://www.mediafire.com/download/cr6uvddqt9k1jsl/Resurrection_Remix_KK_v5.0.4-CoreGapps-i9000.zip
    * http://www.mediafire.com/download/cz3kco19rkdh14y/m110s-format-data.zip
    Cach download : copy link roi paste vao New Tab( Trang moi ) .... dung co click link truc tiep nhe !!!!!!!!!!!!!
    lỗi duy nhất : không ghi âm được
    Huong dan up Rom :
    => Phuc Hoi Movinand truoc khi tien hanh duoi( Lam may cua ban cang muot va Up dc thanh cong)....
    - Download tat ca file tren
    - Copy file ( M110S_EFSBackupTool, M110S_PatchTool, m110s-format-data, m110s-format-system , Resurrection_Remix_KK_v5.0.2.1-CoreGapps-i9000 hoac Resurrection_Remix_KK_v5.0.4-CoreGapps-i9000) vao bo nho trong .
    -Dùng odin up m110s-EFS-backup-recovery.tar roi tat may vao che do recovery xong
    - Up file M110S_EFSBackupTool.zip qua CMW
    - Reboot
    -Dung odin up m110s-installation-recovery.tar
    - tat may vao che do Recovery roi
    - Up m110s-format-system.zip qua CMW
    - Up m110s-format-data.zip tiep qua CMW
    - Up Resurrection_Remix_KK_v5.0.2.1-CoreGapps-i9000.zip hoac Resurrection_Remix_KK_v5.0.4-CoreGapps-i9000qua CMW
    - Up M110S_PatchTool.zip qua CMW
    - Reboot ( Máy vẫn bị lỗi nhạc chuông)
    * Cách fix nhạc chuông :
    - Extract file Fix Ringtone.zip ra roi copy vao bo nho trong
    - Cai file (+¦¦t-s+·apk)
    - xong làm theo hướng dẫn như hình trong file Fix Ringtone ay ( Nên đổi ngôn ngữ đt của các bạn sang tiếng trung để nó dễ )
    ** Cach xoa man hinh ao : vao Setting> Resurrection tools> use interface> size> 0dp
    - Enjoy ........ :gach:
    ( Tiếng việt mình chua thanh thao nen minh huong dan dc the nay thoi..... hihih)
    Like Sharing !!!!!
    Hinh :
    http://s37.photobucket.com/user/Han...[user]=139306888&filters[recent]=1&sort=1&o=0
    Chỉnh sửa cuối: 18 Tháng ba 2014
    Chauvn, yugj, load11 and 3 others like this.
  2. vohinhlangtu
    vohinhlangtu Thành viên
    Oke rùi khoản chuông đã thành công :)) đã ghe có nhạc chuông thấy đỡ buồn hơn
    duc4789 thích bài này.
  3. duc4789
    duc4789 Thành viên
    mình úp r toàn bị mất sóng. và khi khởi động lại nó vào thẳng CWM và ấn reboot trong CWN cũng vẫn cứ thế.
  4. vohinhlangtu
    Chú ý nhìn hướng dẫn kỹ làm từng bước sẽ k bị như thế đâu, chỉ vì sai 1 bước thì nó sẽ bị như thế đó. trước mình cũng bị như vậy :D còn về khoản sóng thì khởi đông lại máy mấy lần là được ý mà
  5. duc4789
    duc4789 Thành viên
    mình làm lại 2 lần r mà huhu :((. sao nó cứ fê lòi vậy. lần đầu thỳ chạy ngon lành nhưng khi reboot là dính chưởng. bh thỳ dính hẳn luôn
  6. vohinhlangtu
    Phục hồi lại movinand rùi up từng bước cẩn thận là được thui. Nghe thấy nhạc chuông mà thấy vui tai ghê :)
  7. duc4789
    duc4789 Thành viên
    thật sự thỳ mình là newbie nên cũng k rõ về cách phục hồi movinand lắm. b giúp mình đc k
  8. vohinhlangtu
  9. duc4789
    duc4789 Thành viên
  10. itdvdung
    itdvdung Thành viên
    cón bị lỗi mic zalo hay viber nữa không các bác
