Hướng dẫn Update Firmware Nokia Symbian^3 bằng Phoenix 2011
Thảo luận trong 'SYMBIAN^3: FIRMWARE - SIGN - HACK PHONE' bắt đầu bởi caoquy8x, 13 Tháng tư 2010.
  1. caoquy8x Thành viên
    Hướng dẫn Update Firmware Offline bằng Phoenix
    (Khuyên Dùng Vì Độ An Toàn Cao Đến 99,99%)
    Phoenix Service Software 2011.14.004.45945 Cr@cked & Original (Update 27.05.2011)
    [​IMG][​IMG][​IMG]
    CHANGE HISTORY Version 1: 09.05.2011 Initial version for v 2011.14.3.45843 Vesrion 2: 24.5.2011. RM 701 support added, package version number updated to 2011.14.4.45945. Otherwise same as earlier 2011.14.3.45843
    INTRODUCTION Main component versions in the release: * DK2 Driver Version 07.14.0.25 * Nokia Connectivity Cable USB Driver Version 7.1.40.0 * Flash Update Package 2011.16.000 * FLS-x Drivers Version 2.09.28 * FUSE Connection Manager v 2011.13
    MAIN CHANGES & ERROR CORRECTIONS FROM PREVIOUS VERSION 2011.8.5.45529
    New Products added
    * RM-776, RM-775, RM-763, RM-773, RM-670, RM-765, RM-774
    New features
    * New version of FUSE connection Manager
    * New version of Flash Update Package
    * New version of Autotuning components
    * New version of Product API
    * New version of Connectivity Cable Driver
    * Torque Information - menu implemented. Information concerning screw tightening torques can be shown if product specific data package contains pictures / information files
    * Simple Multi Software Updater UI added
    Error Corrections & changes
    * Improvements to Smart Card Activator: User is now asked to wait during the delay when smart card data is being read
    * Crash file upload server correction
    * Tucson support for RM-733, RM-732 and 713 implemented. Please note that for these products only Tucson functions can be done with Phoenix, Care Suite must be used for all other activities.
    Please note:
    * New common data package location in use. Please see document SR1315 in KICS Information Center for further information.
    * All Nokia Service Software Applications will use following location for product specific data: - Windows XP: C:\Documents and Settings\All Users\Application Data\Nokia\Packages - Windows 7: C:\Program Data\Nokia\Packages
    * During installation, Data Packages should be installed in these directories, if they install to any other location by default. target folder for local data packages can be changed in the installation wizard manually
    * This version contains the latest Tucson components. Therefore it is not necessary to use Tucson Add-On Installation Packages
    * Before you start Phoenix or Care Suite installation to Windows 7 the User Account Control (UAC) should be turned off from Windows Control Panel settings.
    * For more information concerning new options in "Firmware Update" - menu and their use, Please see documents SR1313 and SR1659 in KICS Information Center.
    * Tucson operations combined with "flash" - option are now handled in the same way as "refurbishment", which requires Mass Memory Content File to be available.
    * Do not use Flash option simultaneously with product code change for USB Only phones, flash phone separately with Firmware Update
    * It is recommended to use FPS-21 flash prommer with TCPIP connection when refurbishing USB Only - phones (RM-596 etc) due to mandatory optional MMC file size.
    * Connection media to FLS-5 must be configured to be "USB_FBUS", after FLS-4 support has been removed FBUS does not work anymore with FLS-5
    KNOWN ERRORS & LIMITATIONS
    * Software downgrade with Tucson system is only possible for BB 5.0 products supporting the Data Package 2 concept.
    * Flashing with setup FLS-5, SS-46 and product specific adapter is not supported anymore. FLS-5 can be used with other product specific cables and adapters, but not with SS-46 Interface Adapter.
    * If you install old DCT-4 data packages, Flash Update Package File installation path may be wrong. This is caused by very old DCT-4 data packages which contain Flash Update Package and overwrite current information during installation. If you experience problems when updating FPS-x prommers, please check that Phoenix “Prommer maintenance” is looking for the files from the correct location which is “C:\Program Files\Common Files\Nokia\Tss\Flash”. If not, Phoenix will show error “Update via ini – file failed”. In this case, select “Update” from that Phoenix “Prommer maintenance” – UI, browse to correct directory and select “fpsxupd.ini” for all other prommers except the FPS-8.
    * Refurbishment flashing and product code change for RX-51 product requires SX-4 card to be available.
    * FPS-21 flashing for RX-51 works only with TCPIP connection. FPS-21 prommer with new HW version 11 has been released to correct this. Sales pack code is 0089J83 , old HW version is not delivered anymore
    * Please refer to product specific documents and instructions concerning the limitations of the RX-51 product
    * RX-51 flashing does not work when CU-4 is used
    * RX-51 Product Code changes work only without FLASH option, please flash phone separately
    * When version 2010_12_8_42304 or newer with FUSE connection manager is installed on top of older Phoenix versions, there may be an additional delay of several minutes when you start Phoenix for the first time. Please wait patiently; Phoenix will start after configuration is finished.
    * When using Data Package download functions with online connection, download times may occasionally be long. This is not caused by Phoenix (or Care Suite). The download speed from online servers is occasionally is known to be slow, depending on how data is buffered on caching servers.
    * After you close Phoenix, it may not restart. To rectify this: - Use Windows Task Manager to manually shut down phoenix.exe and FuseService.exe processes, or optionally restart your PC
    * It is not possible to program Mass Media Content file to some devices over direct USB cable connection, due to the large size of the file. For these models a feature called “Media Check” has been implemented. When this type of product is connected to service software / PC via direct USB cable the refurbishment option will be disabled. Please use a flash prommer.
    * To be able to use the help files in Windows 7 you need to install Windows Help program (WinHlp32.exe) for Windows 7. Ways to locate WinHlp32.exe: - Start Phoenix with online connection to Internet, select "Help" and "Phoenix help". Click the "Microsoft Help and Support" website link. Download WinHlp32 and install it.- Go to http://www.microsoft.com. Type "WinHlp32" to "Search Microsoft.com" - field. Locate Windows Help program (WinHlp32.exe) for Windows 7 and install it
    * When using flash prommers, only one connection type to one prommer is allowed. Please use either NFPD USB or NFPD TCPIP connection to one prommer, not both connections to same prommer
    INSTALLATION
    * If you have Phoenix External 2007.4.6.170 or older you must uninstall it before installing this release.
    * Download Phoenix_Service_Software_2011_14_3_45843.exe application file to your computer (e.g. C:\TEMP).
    * Close all other programs.
    * Disconnect all flash prommers and phones which may be connected to PC via USB connection (reconnect them only after Phoenix installation has been completed)
    * Run Phoenix_Service_Software_2011_14_3_45843.exe and follow instructions on the screen to install Phoenix Service Software
    * Connect a dongle (PK-1, PKD-1, FLS-4S, FLS-5) when message appears on the screen
    * If you are prompted to update any existing driver or file versions, select “yes”.
    * Depending on the operating system, the PC may require rebooting.
    * Allow Windows to register the Phoenix components.
    * Open Phoenix, use FUSE Connection Manager to configure connections depending on the tools you use
    * If you use CU-4, please pair the connection with service adapter by selecting “pair with service adapter” - option
    * Update your prommer with the latest software included in this installation package.
    * Install and use the latest available product specific data packages or flash bundles
    Supported operating systems and user rights
    * Windows XP Service Pack 1 or higher
    * When installing Phoenix into Win XP you must have local admin rights.
    * When using in Win XP, user must have power user rights.
    * Windows 7 32 Bit version
    1. Đầu tiên các bạn cần phải load FW điện thoại của mình về PC.
    * Load FW bằng navifirm
    - Copy thư mục RM-346 (đối với E71 RM-346) vào C:\Program Files\Common Files\Nokia\DataPackage\Products\ (Nếu không có thì các bạn tạo có thể tự tạo ra) Hoặc C:\Program Files\Nokia\Phoenix\Products\ Hoặc C:\Program Files (x86)\Nokia\Phoenix\Products\ (Đối với windows 64bit)
    - Copy thư mục RM-346 (đối với E71 RM-346) vào C:\Program Files\Common Files\Nokia\DataPackage\Products (Nếu không có thì các bạn tạo có thể tự tạo ra)
    * Load FW có dạng .exe
    - Phân biệt các bản FirmWare dành cho các khu vực.
    - Thông thường các máy Nokia chính hãng được phân phối tại Việt Nam thì các bạn load FW: APAC - Asia PacificSEAP - Sout East Asia Pacific
    - Sau khi load FW về các bạn chạy file setup bình thường (đối với FW dạng .exe thì các bạn không phải tạo đường dẫn "C:\Program Files\Common Files\Nokia\DataPackage\Products")
    2. Download Pheonix 2011 ở dưới về, cài trên PC
    3. Cắm điện thoại vào PC thông qua cáp và chọn kết nối PC Suite
    4. Chạy Phoenix đã được cài sẵn trên PC
    5. Chọn File / Scan Product
    6. Sau khi Scan Product xong Phoenix sẽ nhận ra thiết bị được gắn vào thông qua cáp.
    7. Chọn Flashing / Firmware Update
    8. Thông thường sau khi chọn Firmware Update thì Phoenix sẽ tự nhận ra FW đúng với thông số của điện thoại.
    Chọn Refurbish để Update Firmware.
    - Nếu Phoenix không tự nhận ra FW của máy thì click và biểu tượng hình tròn sẽ hiện ra bảng FW tương ứng với Product Code của từng loại máy. Ở đây bạn có thể chọn thủ công hoặc click vào "Detect Product Automatically" để Phoenix tự động gán FW theo đúng thông số điện thoại.
    - Chọn Ok và chọn Refurbish để Update Firmware.
    9. Sau khi chọn Refurbish để Update Firmware thì các bạn chỉ cần đợi từ 3 - 7 phút là xong.
    [URL="http://azsharing.com/khoqy4339wvu/Phoenix-Service-Software-2011.14.004.45945-_ed.rar.html"]http://azsharing.com/khoqy4339wvu/Phoenix-Service-Software-2011.14.004.45945-_ed.rar.html[/URL]
  2. lỏngenzy
    lỏngenzy Thành viên
    giúp mình với lúc đang upfirmware thì bị cái này làm thế nào nữa hả các bạn
  3. Be Yeu
    Nguyên văn cái cảnh báo trên màn hình của bạn :
    Tiến trình Flash khởi động không đúng . Để khắc phục , hãylàm theo các bước sau :
    1.Rút cáp kết nối USB.
    2. Nhấn và giữ nút “ Nguồn “ ( không quá 8 giây ).
    3. Khởi động lại điện thoại và chờ nó hoạt động .
    4. Kết nối cáp USB .
    5. Kích chuột vào nút “ Retry “.
  4. Khỉ Con
    cập nhật bản Phoenix Service Software 2011.14.004.45945 (27/5/2011) ở bài đầu
  5. bonykhai
    bonykhai Thành viên
    Mình đã thành công trên C6.thật tuyệt vời,thanks.
  6. khamvaphaonline
    khamvaphaonline Thành viên
    Mình chạy nó cứ báo lỗi như hình dưới thì là sao nhỉ:[​IMG]
  7. Trunghuy90
    Trunghuy90 Staff Member
  8. dhnguyen89
    dhnguyen89 Thành viên
    có ai biết truờng hợp này là thế nào?
    mình update firm bằng phoenix 2011.02.000.44842, đang up thì nó cho thông báo này và điện thoại tắt ngấm. làm theo thông báo nhưng nó cứ lặp đi lặp lại.
    Thông báo như sau: thất bại.. để khôi phục điện thoại làm theo chỉ dẫn sau: 1) rút cáp ra. 2) cắm cáp vào. 3) ấn OK.
    trông có vẻ giống trường hợp ở trên nhưng ko có bước "ấn vào nút nguồn"
    và đây là log của nó ạ" response: 24
    Waiting for communication response: 23
    Waiting for communication response: 22
    Waiting for communication response: 21
    Waiting for communication response: 20
    Waiting for communication response: 19
    Waiting for communication response: 18
    Waiting for communication response: 17
    Waiting for communication response: 16
    Waiting for communication response: 15
    Waiting for communication response: 14
    Waiting for communication response: 13
    Waiting for communication response: 12
    Waiting for communication response: 11
    Waiting for communication response: 10
    Waiting for communication response: 9
    Waiting for communication response: 8
    Waiting for communication response: 7
    Waiting for communication response: 6
    Waiting for communication response: 5
    Waiting for communication response: 4
    Waiting for communication response: 3
    Error 0x8401F121 communicating to phone. Unable to verify comm.
    Warning: Unable to communicate to product after flashing
    Starting to recover the phone
    Recoverying phone
    Initializing
    Scanning image files...
    ERROR: Unable to detect device 0x8401F145. Check USB connection
    ERROR: Product recovery failed
    Unable to set the phone to flash mode. Unable to flash.
    Recoverying phone
    Initializing
    Recoverying phone
    Initializing
    Recoverying phone
    Initializing
    Recoverying phone
    Initializing
    All operations completed
    Product flashing aborted "
    nên em đành ấn cacel và kết thúc
    Ai biết trường hợp thế nào ko ạ? khôi phục kiểu gì ạ?
  9. hoangduonghvtc
    hoangduonghvtc Thành viên
    cái này ngày trước mình Flash con E5 gặp nhiều rồi. Đó là do bạn cập nhật trên Navi bản thấp hơn bản bạn đang dùng. Hãy cập nhật bản mới nhất ấy. Sẽ không bị lỗi đó nữa đâu. Okie
