If you like it go to cydia and BUY IT ! iAluminum[HD] is a unique theme that overhauls your entire device with a sleek, brushed aluminum look for iPhones and iPod touches. This theme supports both HD and non-HD devices with a smooth appearance on both. Fully compatible with iOS 4.0 and up. THEME SBSETTINGS How to set up the theme: 1) Make sure WinterBoard and this theme are downloaded of course . 2) Select the desired parts of the theme in WinterBoard (select all of them for best experience) and respring. Summerboard mode can be disabled for this theme, giving extra speed. 3) Open Settings.app > Wallpaper > Wallpaper and set the wallpaper as labeled on the thumbnails. 4) If you are on 4.1 or above, use SSH or iFile to delete /var/mobile/Library/Caches/com.apple.SpringBoard.folderSwitcherLinen. There may be multiple files with numbers appended to the end – delete them all. Don't worry, they're only caches; it is only keeping iAluminum[HD] folder/multitasking background from working right. Res pring again to regenerate the cache with the themed background. 5) If you have SBSettings, bring it up and tap “more”. Navigate to “SBSettings Theme” and Select iAluminum[HD]. Exit the app and allow it to automatically respring. 6) Done! credit: arkham
