Ice Cream Sandwich Launcher 1.0.0.0-ICS
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 22 Tháng chín 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android: 2.1 - 2.3.3
    Tổng quan: Một launcher rất mới và đẹp, nhà phát triển cũng rất tâm huyết với cái này, anh em test nhé !
    Hình ảnh:
    Thông tin chi tiết:
    Get Ice Cream Sandwich 2.4 on any Android device running 2.1+ or higher!Get ice cream sandwich 2.4 on any Abdroid device by using Ice cream sandwich Launcher! Ice cream sandwich launcher is basically a guess of what ice cream sandwich will really look like when released. We built this launcher from a handful of leaked images of ice cream sandwich. But unfortunatly, we dont really know what ICS will really look like when released. That being said, we wil still do our best to update the launcher anyime more information is leaked about ice cream sandwich. Currently this is as close as you can get to the real thing!
    What is Ice Cream Sandwich 2.4? Ice cream sandwich is most likely th next Android update ater Honeycomb. Ice cream sandwich is currenty not officially availbale on any device at the moment. Bu Google does plan on rolling it out the doors and onto devices real soon. Ice cream sandwich is believed to be a modern mix of Gingerbread and Honeycomb.
    Ice Cream Sandwich Launcher Features
    ★Clones Ice Cream Sandwich 2.4
    ★Extremely Fast and Smooth Scrolling (When properly set up)
    ★ICS Wallpaper Chooser
    ★Hide Notification Bar (Gesture/Swipe up)
    ★ICS Settings
    ★ICS Quick-Menu
    ★ICS Google Search Bar
    ★Quick-Action Menu with Quick-Launch
    ★Hide Labels (Under Launcher Settings in ICS Settings)
    ★Tutorials and Help
    ★Supports all sources of wallpapers (e.g. Cyanogenmod, gallery)
    ★Supports Live Wallpapers (All sources)
    ★Scrollable Widgets (HTC)
    ★Re-Sizable Widgets
    ★Nightly Updates and Builds
    ★And much more to come!
    What is planned for future updates?
    ★New Running Apps Menu
    ★Dock Bar icon replacement
    ★Auto-Task Killer
    ★New App drawer
    ★Anything Google decides to release!
    Quick Tips and Help
    ★View the tutorial on start up
    ★Swipe up to hide the notification bar on any home screen. Swipe down to bring it back.
    ★For support, be sure to send us an email or contact us!
    Be sure to exclude and ignore ICS Launcher from any Task Killer. If you are using ICS Launcher and kill the app from any Task Killer, ICS Launcher will hang your apps and run slow!
    Please visit our website for more information about Ice Cream Sandwich Launcher or any of our products such as themes, apps, icons, games, and much more.
    Or send us an email at support@syndicateapps.com
    You can also view the official XDA thread for ICS 2.4 here --> http://forum.xda-developers.com/showthread.php?t=1268003
    ICS Launcher Release: 9/20/2011
    ICS Launcher Latest Update:
    Ice Cream Sandwich Launcher is a launcher/home replacement. It was mainly built of Honeycomb Launcher but it also has many features like Adw.launcher, Crazy Home, LiveHome, DxTop, aHome, Launcher Pro, and Go Launcher all have. Almost all home replacements are very similar. The home you will like the most depends on which home you feel comfortable with and the features it support as well. But the important thing to remember about ice cream sandwich Launcher is that it is a stock launcher and will not perform as much customization as other launchers, such as ADW. Ice cream sandwich Launcher is designed to bring any device the Android 2.4 UI!
    Personal Note:
    We can not reply to comments in the market! Please send us an email if you need help or something isn't working. We will reply as soon as possible!
    Sincerely,
    Syndicate Apps
    TechBamboo
    Xem thêm trên Android Market:
    [URL]https://market.android.com/details?id=mobi.SyndicateApps.ICS&feature=search_result[/URL]
    Tải về:
    [URL]http://appstore.vn/a/index.php/home/app/2457[/URL]
