iDisplay v2.0.1 - điều khiển PC bằng Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 7 Tháng mười một 2011.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.1
    Ảnh chụp màn hình:
    Turn your phone into the second monitor for Mac or PC! From developer of IM+.
    Add a second monitor to your Mac or PC! iDisplay is designed to increase your productivity by maximizing the viewable area on your main monitor.
    "That's: brilliant. I mean, I can think of about a billion uses for this."
    MobileCrunch
    Ideal for multi-taskers who want to increase their efficiency, iDisplay expands the viewable area of a user's main monitor by moving other needed programs such as IM, Twitter and news gadgets to an external display using their Android tablet or mobile device. This frees up your main monitor to only display programs for which more view space is needed.
    KEY FEATURES:
    ★ Extend the display – spread the desktop over both displays and drag items between the two screens as per your convenience.
    ★ 100% Compatible – works with the Samsung Galaxy Tab, Motorola Xoom, Google Nexus One, or any other Android tablet or smartphone on the market.
    ★ Works in portrait or landscape device orientations.
    NOTE:
    In order to use iDisplay please download the free desktop part to your computer (PC or Mac) from www.shapeservices.com/idisplay
    REQUIREMENTS:
    Android OS 2.1 or later.
    Intel-based Mac, Mac OS X 10.5 Leopard or later or Windows XP 32-bit, Windows Vista, or Windows 7.
    Non-Intel Macs are not supported.
    Xem thêm trên Android Market:
    [url]https://market.android.com/details?id=com.idisplay.virtualscreen&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5pZGlzcGxheS52aXJ0dWFsc2NyZWVuIl0. [/url]
    Tải về:
    [url]http://appstore.vn/a/index.php/home/app/3191 [/url]
    nguyenducdungtq and nhh.hoang like this.
  2. nqadta1406
    nqadta1406 Thành viên
    Bạn ơi! Chỉ có APK của Android mà không có soft cho PC àh? Cho mình cái link down với
