Jelly Bean Extreme CM10 AOKP v2.3
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 9 Tháng mười 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.3
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    ✩✩ATTENTION✩✩
    This theme is NOT for launchers. This theme for for devices that are ROOTED and running a CUSTOM ROM. For more info about rooting see this link
    http://www.androidcentral.com/root
    ✩✩ATTENTION✩✩
    When applying theme in theme chooser you might get a error saying "This theme was improperly compiled and cannot be applied"
    ✮✮To FIX this just apply System Theme, Reboot, and apply this theme again✮✮
    If that doesn't work please contact me at bignadad[MENTION=134938]Gmail.Com[/MENTION]
    ✚✚WHATS INCLUDED✚✚
    Custom, Original Design Work
    Custom Wallpaper
    3100 Custom Images!!
    I LOVE the Jelly Bean / Ice Cream Sandwich look, but there were some things i didn't like and some things I thought I could improve. That is what this theme is all about. Taking JB & ICS to another level!
    I have many different colors of this theme
    --Find them here > http://bit.ly/JellyBeanExtremeColors
    ✚✚WHATS REQUIRED✚✚
    ROOT is needed and a custom ROM that supports the Theme Engine
    ★This Theme will work for the following ROM's★
    - CM9
    - CM10
    - AOKP ICS
    - AOKP JB
    - BAMF
    - Slim
    ★★This theme is designed for mdpi, hdpi, and xhdpi devices★★
    ✚✚WHATS COMING✚✚
    More packages to be skinned. Camera, Gallery, Etc...
    More icons to be themed.
    ✚✚ABOUT BIGDX✚✚
    All my work is created by me, bignadad
    I spend a lot of time getting things just right. Expect many updates and new creations from BigDX
    I have many different ADW/GoEX/Nova/Apex themes on Google Play to match this theme. Check them out by searching BigDX
    Please take a moment to rate and comment on my themes
    It does make a big difference and kind comments are greatly appreciated.
    Visit me at http://www.bigdxmarket.com with any questions/comments
    What are users saying about BigDX Themes?
    http://www.bigdxmarket.com/Comments.html
    I have been on Google Play for over a year now and know what i'm doing. Expect many updates in the future and many more themes to come :)
    ✚✚HOW TO USE WITH THEME CHOOSER✚✚
    -Download Theme
    -Go to Settings -> Themes
    -Select JB Extreme and press apply
    ★★You may get an error: 'Sorry, this theme is missing assets for your device's screen size'★★
    -Ignore that and press apply anyway
    -A message will display saying SystemUI has crashed, press OK
    -SystemUI will restore after about 5-10 seconds and theme will be applied
    -If you coming from another theme, you may need to reboot
    ✚✚ What i have themed so far ✚✚
    Most all popup menus (Light and Dark)
    Switches are angled on JB Devices (like ICS)
    Power control and genie widget have semi trans background
    Nova Folder backgrounds (platform, circle)
    All icons on pull down to blue
    All navigation buttons
    Added some blue accents on pull down menu borders
    Changed the "working" circle
    Bottom menu background
    Battery with and without percentages
    Cellular and Wifi Signals
    Animated notification icons for Gmail and Gtalk
    Status bar close bar
    Notification background on pull down
    All AOKP/CM toggle icons
    SMS/MMS Notification icons
    Phone/Dialer Images
    MDPI support for tablets and phones with tablet UI
    Support for sw600dp and sw720dp (mdpi/hdpi/xhdpi)
    All Settings icons (CM/AOKP/Stock)
    Stock keyboard
    Analog clock/desk clock
    Market notification icons
    Complete lockscreen handle icons (aokp only)
    On/off buttons under aokp toggles on pull down
    Google now notification icons (traffic, sports, etc)
    Google search widget
    Google now misc icons/images
    Skinned & Blacked out Gmail/Email & Widgets
    Skinned Google Ears & Play Music Widgets
    AOKP Nav Rings
    Swype
    60 app icons
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=bigdx.jbextreme.com [/url]
    Tải về:
    [url]http://appstore.vn/a/index.php/home/app/8845 [/url]
