Jelly Bean HD GO Theme v2.1
Thảo luận trong 'Android: Giao Diện, Trang Trí' bắt đầu bởi Khỉ Con, 13 Tháng chín 2012.
  1. Khỉ Con interista
    Yêu cầu phiên bản Android từ: 2.0
    Ảnh chụp màn hình:
    [​IMG][​IMG]
    [​IMG] [​IMG]
    The most faithful Jelly Bean theme and especially made with all graphics in HD!
    Have both the best launcher in the market and the most modern look in your phone and HD graphics by combining GO Launcher EX and the most faithful Jelly Bean Android 4.1 theme with HD Wallpapers and over 600 HD icons!
    _________________________________
    THIS THEME REQUIRES NO PERMISSIONS TO RUN. AND NO ADDS.
    This Jelly Bean GO Launcher theme is compatible will all phone screen resolutions, and all android versions from 2.0 upwards.
    Characteristics of this Jelly Bean Android 4.1 HD GO Launcher Theme:
    ** HD Graphics! All the artwork has been done in the highest resolution allowed in Go Launcher, with the original Jelly Bean icons and over 600 common app icons done all in large 96x96 HD resolution from scratch, instead of the normal 72x72 standard icons commonly used in the themes. The wallpapers are also in higher than standard GO Theme resolution, the appdrawer, dock, etc.
    This is specially important in the higher screen resolution phones and or if we like to use the "large icons" setting in GO Launcher. Makes your screen look very sharp and detailed.
    ** Special care has been taken to be the most faithful GO Launcher Theme reproduction of Android 4.1 Jelly Bean's launcher. From the custom Jelly Bean icons and wallpapers to the details like exact matching color codes used, menu icons, the folder interface, the indicators, the appdrawer, etc.
    ** Includes all 10 original Jelly Bean wallpapers in HD resolution.
    ** All images optimized while conserving maximum quality to achieve the smallest app package size possible in the phone's memory.
    ** This theme will be regularly updated should new official wallpapers or artwork be released for Android 4.1 Jelly Bean.
    ** This theme asks of no unsafe permissions to install. No adds. No risk of hidden malaware.
    For a step by step installation guide and other guides with pictures go to:
    http://rennlab.blogspot.com.es/p/antique-theme.html
    IMPORTANT! This theme has close to 600 autoreplaceable icons in 96x96 resolution, but in some devices some icons may not change automatically to the theme's own icons. If an icon has not been replaced to the HD version of this theme, check to see if its included in the theme and change it manually if so:
    -> Tap and hold the icon while on the desk screen (will not work inside the AppDrawer) -> Select "Replace" -> search and select the desired icon.
    ==== CONFIGURATION FOR BEST RESULTS ====
    (The following instructions are available with pictures at:
    http://rennlab.blogspot.com.es/p/faqs.html )
    ****** Apply Jelly Bean's Roboto font to GO Launcher
    -> Preferences -> Visual settings -> Fonts -> Scan Fonts -> Select font -> select "Roboto-normal"
    * If Roboto font is not present in phone then simply download and copy to GOLauncher font folder first:
    -> Download fonts from http://forum.xda-developers.com/attachment.php?attachmentid=753937&d=1318996825
    -> Extract and Copy font .ttf files to /sdcard/GOLauncherEX/fonts folder
    (* this will not change your system's font or cause any conflicts, it will only change your launcher's font.)
    ****** To take advantage of the over 600 large 96x96 icons included in this theme, you can display the icons in large size on your screen instead of 72x72.
    -> Preferences -> Visual settings -> Icons -> Icon size -> Large size
    ****** Auto hide screen page indicators so that they only show when you are actually scrolling to another screen page
    -> Preferences -> Visual settings -> Indicator -> Screen indicator -> Auto-hide indicator
    Thanks for your support!
    Problems and Suggestions to: rennlab[MENTION=134938]Gmail.Com[/MENTION]
    Xem thêm trên Play Store:
    [url]https://play.google.com/store/apps/details?id=com.gau.go.launcherex.theme.rennlab.jellybean [/url]
    Tải về:
    [url]http://appstore.vn/android/home/app/8906 [/url]
