Joikusoft JoikuSpot Premium - biến điện thoại thành máy phát Wifi
Thảo luận trong 'ỨNG DỤNG CÓ KẾT NỐI WIFI, GPRS, 3G' bắt đầu bởi ChiêuTrúc, 25 Tháng ba 2006.
  1. hdt042244
    hdt042244 Thành viên
    eo ơi kết nối kiểu đó nạp card như uống coca lun, đắt đỏ lắm bạn...
  2. dragonvip
    dragonvip Thành viên
    đăng ký chọn gói 1 ngày,hay 1tháng thi ko cần phải lo :112:
  3. takeda
    takeda PC Top Contributor
    Joikusoft JoikuSpot Premium v2.60.907 S60v3/v5 SymbianOS9.x Unsigned *******-FoXPDA
    There are millions and millions of WiFi (WLAN) internet sessions made by "JoikuSpotting". JoikuSpotting is the fastest, easiest, most reliable and cost effective way to establish WiFi Internet anywhere, by simply connecting a laptop to the internet via WiFi using mobile phone's 3G. JoikuSpot is a software product that installs to a mobile phone allowing you to turn your mobile phone into a secured WiFi HotSpot!
    [​IMG] [​IMG]
    JoikuSpot enables "1-click internet". 1 click to turn a phone to a WiFi internet gateway, and another click in the laptop to connect to the web via JoikuSpot WiFi access point. (Scan available WiFi networks, discover JoikuSpot, and click "connect".)
    JoikuSpot allows you to connect multiple devices in parallel to the internet.
    You can easily secure your internet connection, and also use VPN to access secured corporate intrawebs. You can access your Outlook and Gmail and other email clients via your JoikuSpot connection.
    All settings (like WiFi network naming, security settings and default access point) are adjustable in JoikuSpot. There is no forced default landing page in Premium Edition. Premium has the best performance and connection quality, and auto-reconnects to 3G if the connection is dropped to e.g. 2G temporarily.
    You can effectively replace Bluetooth, MiFi, cable, USB modems and external WiFi HotSpots with JoikuSpot and save money, time and hassle. After all, you always have your phone with you = Where ever you may be, you will have WiFi internet. ​
  4. khongan
    khongan Thành viên
    Phần mềm này chạy ngon phết, nhưng tốn pin thật em toàn phải cắm sạc khi chạy nó cho đảm bảo
  5. Be Yeu
    Joikusoft JoikuSpot Premium v3.0.921 S60v3/v5 SymbianOS9.x Unsigned *******-******
    There are millions and millions of WiFi (WLAN) internet sessions made by "JoikuSpotting". JoikuSpotting is the fastest, easiest, most reliable and cost effective way to establish WiFi Internet anywhere, by simply connecting a laptop to the internet via WiFi using mobile phone's 3G. JoikuSpot is a software product that installs to a mobile phone allowing you to turn your mobile phone into a secured WiFi HotSpot!​
    JoikuSpot enables "1-click internet". 1 click to turn a phone to a WiFi internet gateway, and another click in the laptop to connect to the web via JoikuSpot WiFi access point. (Scan available WiFi networks, discover JoikuSpot, and click "connect".)​
    JoikuSpot allows you to connect multiple devices in parallel to the internet.​
    You can easily secure your internet connection, and also use VPN to access secured corporate intrawebs. You can access your Outlook and Gmail and other email clients via your JoikuSpot connection. ​
    All settings (like WiFi network naming, security settings and default access point) are adjustable in JoikuSpot. There is no forced default landing page in Premium Edition. Premium has the best performance and connection quality, and auto-reconnects to 3G if the connection is dropped to e.g. 2G temporarily.​
    You can effectively replace Bluetooth, MiFi, cable, USB modems and external WiFi HotSpots with JoikuSpot and save money, time and hassle. After all, you always have your phone with you = Where ever you may be, you will have WiFi internet.​
    haingoai1004 thích bài này.
  6. erhard
    erhard Thành viên
    cho em hỏi chút, wifi máy nokia có hỗ trợ ad-hoc ko ạ? hay chỉ dùng ifrastructor thôi? em có cái psp, tính thử chuyển file qua lại mà hình như wifi đt ko dùng được ad-hoc
  7. xuanmanh2407
    xuanmanh2407 Thành viên
    anh ơi, em dùng con nokia 5630 sử dụng joikuspot phat wifi,mà laptop thi nhận vào net bình thường. còn con dell axim của em nhận được mà không vào nét được, toàn báo lỗi thôi ak
  8. hoangcung1939
    hoangcung1939 Ex-Mod
    Bị báo lỗi gì vậy bạn, vui lòng ghi rõ lỗi ra ha.
  9. trungchinh
    trungchinh Thành viên
    mấy bác này cứ spam...ai chả biết dùng enternet qua gprs của dt thì chậm và ngốn tiền.nhưng lỡ các bác đang ở trong một hoàn cảnh thiếu thốn như đang trong rừng mà cần gửi mail hay đọc tin thì dùng gì?****************? pm joikuspot chính là những gì cần thiết lúc ấy đáy
    nếu các bác dùng lâu thì ko tốt đâu nếu thực sự cần thì dùng chứ dế yêu cũng dễ đi viện lắm hì.....
  10. masterghost
    masterghost Thành viên
    thế thì dùng luôn gprs của điện thoại
