KeepItOn - giữ cho đèn màn hình luôn sáng
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi Khỉ Con, 29 Tháng một 2011.
  1. Khỉ Con interista
    KeepItOn v2.03 S60v3/v5/S^3 SymbianOS9.x Signed Retail-drAdeLante
    KeepItOn keeps the display backlight active as long as KeepItOn is running which is e.g. useful while reading a website, navigation or messaging. KeepItOn supports autostart functionality, it can run in background, display light can be on for infinite time, or for a predefined time period, and screen brightness can be controlled. KeepItOn's energy saving options can be setup so that light is only active when the phone is connected to a charger or if battery level is above a certain rate.
    The latest version of KeepItOn supports two new modi: timeout extension, and application specific light on. "Timeout extension" extends the system timeout by a given amount of seconds, while the "application mode" keeps the backlight on as long as one or multiple user-defined applications are running.
    List of Features :
    * Turn backlight on for infinite or user-defined time
    * Extend system backlight deactivation/keylock time to more than 60 seconds
    * Change screen brightness/intensity
    * Autostart when phone is turned on
    * Charger mode: light keeps running infinitely when charger is connected
    Help and Usage Instructions for KeepItOn :
    The start view of KeepItOn offers the following operations which are activated when the icon is colored and deactivated if the icon is grey:
    * Keep light on: Keeps the backlight on for an infinite periode of time.
    * Keep light on (for a selected time)
    * Hide: hides KeepItOn in the background.
    * Charger mode: If activated then the backlight stays only on if the phone is connected to a charger.
    * Extended timeout: Extends the systems timeout (usually between 5 to 60 seconds) by a user defined timeout. This function works only properly, if the "System timeout" is set under "Options" - "Settings" to the devices System timeout (which can be found in the phone's preferences).
    * Application mode: If on, then the backlight stays on as long as one of the specified applications is running.
    [url=http://www.mediafire.com/?cza179b4bp4n43a]KeepItOn_203_Retail-drAdeLante.sis[/url]
