DrJukka Key Lock Clock v0.5 S60v3 Symbian9.x Unsigned Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66. Wery simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on while charging" on. also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices.
DrJukka Key Lock Clock v0.55 S60v3/v5 SymbianOS9.x Unsigned Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66. Wery simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on while charging" on. also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices. Change Log : - Added Font selection, so all have nice font in the clock screen, - Fixed the issue with 12 hour clock, - Checked the settings re-freshing, should be fool proof now, - Added Light timeout setting, so the light wont go out when you lift you finger from the button, - Added a idle time resetting (nice technical term) when light are on, so in old devices the screensaver should stay out, - Added a automatic key locker, so you can set the keys to be locked after some idle time, - Added some Call handling code, just to make sure the clock screen is only there when there is no calls active.
DrJukka Key Lock Clock v0.60 S60v3/v5 SymbianOS9.x Unsigned Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66. Wery simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on while charging" on. also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices. This update fixes to all bugs I have been reported. Tested extensivly with 5800 and now the lights problem as well as crashing with full QWERTY should be fixed.
Setup thế nào để nó luôn hiện cái này thay vì hiện cái Pawer saver(screen saver) có sắn của mibile?(ví dụ như là: lịch hoặc ngày giờ) Hoặc có cách nào tắt hẳn cái Power saver đi ko? Mình dùng E63.
Dr Jukkas Key Lock Clock v.70.S60v3 Unsigned{Updated 09/08/09} Changes include - Fixes: 5800 QWERTY input and Light always on with 9.0 devices. - More setting: lights on always, separate light intensity for charging and show date + day name (the day name caused some problems with languages written from left to right) - More customization for the clock screen with color settings. Also themes can now be used with the clock.
Dr Jukkas Key Lock Clock v.75.S60v3 Unsigned Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66. Very simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Note that the Clock screen runs in a separate background process, thus any changes made to the settings are effective only after you exit the UI application. The clock screen lights will not be set on when the keys are locked, since most of the time when device is locked it is not meant to be used, thus to get the lights on you need to press the switcher button (that is used for switching between menu and home screen), also with non-touch devices, the arrow keys can be used for this purpose. Note that by default the light will go out in 1 second, if longer timeout is needed, then you can set it with settings options between 1 sec and 3599 (1 hour) seconds. Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on" setting to "Time out + charging" on. There is also option now to keep the lights on until the keypad is unlocked. Also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. Lights intensity also has separate settings for light while it is in the charging, thus you can use different options for your night time clock. The font in the clock screen can be changed with settings option, please note that some fonts (that usually have word "digi" in them) might only include characters numbers, thus using 12-hour clock with them would cause am/pm to be shown as empty rectangles, not a bug, but a feature of some specific fonts really. The Clock screen can be customized, by default the currently active Theme is used as background, and its normal text font color used for showing the time. With the settings options you can also use 16 different colors for the background and for the clock. As additional feature this application also includes automated key locker, if this feature is needed, just set it on and set the timeout for idle time out(when user is not interacting with the device) for automatically locking the keyboard. This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices. v0.75: - Now all three available in six languages: English, German, Spanish, Finnish, Thai and Catalan. - Key lock Clock also has small fix on the 5800 lights out.
Hic giá mà PM này có thêm vài mục hiện hình pin và các kết nối (wifi, bluetooth...) và mức pin thì tốt nhỉ thêm nữa: nếu đc thì nên có lựa chọn xoay ngang đồng hồ (landscape) sẽ tiện hơn cho người dùng (để đt trước mặt trên bàn làm việc chẳng hạn) ;)
Dr Jukkas Key Lock Clock v.77.S60v3 Unsigned Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66. Very simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Note that the Clock screen runs in a separate background process, thus any changes made to the settings are effective only after you exit the UI application. The clock screen lights will not be set on when the keys are locked, since most of the time when device is locked it is not meant to be used, thus to get the lights on you need to press the switcher button (that is used for switching between menu and home screen), also with non-touch devices, the arrow keys can be used for this purpose. Note that by default the light will go out in 1 second, if longer timeout is needed, then you can set it with settings options between 1 sec and 3599 (1 hour) seconds. Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on" setting to "Time out + charging" on. There is also option now to keep the lights on until the keypad is unlocked. Also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. Lights intensity also has separate settings for light while it is in the charging, thus you can use different options for your night time clock. The font in the clock screen can be changed with settings option, please note that some fonts (that usually have word "digi" in them) might only include characters numbers, thus using 12-hour clock with them would cause am/pm to be shown as empty rectangles, not a bug, but a feature of some specific fonts really. The Clock screen can be customized, by default the currently active Theme is used as background, and its normal text font color used for showing the time. With the settings options you can also use 16 different colors for the background and for the clock. As additional feature this application also includes automated key locker, if this feature is needed, just set it on and set the timeout for idle time out(when user is not interacting with the device) for automatically locking the keyboard. This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices. v0.77: - Updated with 6 new languages: French, Ukrainian, Russian, Hebrew, Swedish and Serbian.
