Key Lock Clock-Khóa phím đồng hồ giống E71
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 8 Tháng bảy 2009.
  1. lysamtanhaccs4
    lysamtanhaccs4 Thành viên
    cái này có j hơn so với bản 1.0 hở bác
  2. tichau
    tichau Guest
    DrJukka Key Lock Clock v1.0.4 S60v3v5 SymbianOS9.x Unsigned Freeware
    Key Lock Clock is a free Clock application that is shown while the device's key lock is on. The idea was inspired by the feature found from E71 & E66.
    Very simple to use, just click the application icon, set the "Clock screen" on, exit the application and lock the key lock normally. Note that the Clock screen runs in a separate background process, thus any changes made to the settings are effective only after you exit the UI application.
    The clock screen lights will not be set on when the keys are locked, since most of the time when device is locked it is not meant to be used, thus to get the lights on you need to press the switcher button (that is used for switching between menu and home screen), also with non-touch devices, the arrow keys can be used for this purpose.
    Note that by default the light will go out in 1 second, if longer timeout is needed, then you can set it with settings options between 1 sec and 3599 (1 hour) seconds.
    Additionally this application can be used as a Table clock when the charger is connected, to enable this feature just set the "Lights on" setting to "Time out + charging" on. There is also option now to keep the lights on until the keypad is unlocked.
    Also if you think that the screen lights are too bright, you can adjust it with the "Lights intensity" option. Lights intensity also has separate settings for light while it is in the charging, thus you can use different options for your night time clock.
    The font in the clock screen can be changed with settings option, please note that some fonts (that usually have word "digi" in them) might only include characters numbers, thus using 12-hour clock with them would cause am/pm to be shown as empty rectangles, not a bug, but a feature of some specific fonts really.
    The Clock screen can be customized, by default the currently active Theme is used as background, and its normal text font color used for showing the time. With the settings options you can also use 16 different colors for the background and for the clock.
    As additional feature this application also includes automated key locker, if this feature is needed, just set it on and set the timeout for idle time out(when user is not interacting with the device) for automatically locking the keyboard.
    This version was designed 5th edition touch devices such as 5800 & N97 in mind, but should work just as well with all Symbian S60 3rd edition non-touch devices.
    change log :
    Azerbaijan added and Farsi updates
  3. tichau
    tichau Guest
    DrJukka Key Lock Clock v1.0.8 S60v3v5 SymbianOS9.x Unsigned Freeware
  4. tichau
    tichau Guest
    DrJukka Key Lock Clock v1.01 S60v3 SymbianOS9.x Unsigned {UPDATE 14/02/2010}
    Changelog:
    Key lock Clock also updated with feature improvements targeting new firmware for 5800.
  5. minhtue
  6. myloveforyou
    myloveforyou Thành viên
  7. minhtue
  8. manbk401
    manbk401 Thành viên
    DrJukka Key Lock Clock v1.01 S60v3 SymbianOS9.x Unsigned Datecode 23.04.10
    Change log not available
    peter 1 and quangmax like this.
  9. Khỉ Con
    DrJukka Key Lock Clock v1.12(0) S60v3v5 SymbianOS9.x DateCode 29.01.2011 Unsigned
    no changelog​
    DaU_TrOc_LoC, quangmax and lanh1510 like this.
  10. dokhoasg
    dokhoasg Thành viên
    Để em cài thử xem, thanks bác
