Ip4 clock : Ff 5.0.1 , bb 04.11.08 đang đắp chăn seri : 83035qr7a4t imei : 012426001191868 model : Mc610ll nhờ ace trên diển đàn kiểm tra xem ip4 của tôi đã hết hạn bảo hành chưa.nếu hết hạn bảo hành mình mua code để chuyển sang máy world có được không ? Cám ơn ace nhiều
Serial Number: 83035QR7A4T Model and build information Model: - iPhone 4 (32 GB Black) Codename: - N90 Build Country: - Most likely China. Build Year: - Your Mac was built in 2010. Build Week - Your device was built in week 35 of that year (August). Production Nr.: - Your device was number 2489 to be built that week. Source: AppleSerialNumberInfo.com Processor Storage and Memory Display Processor speed: - 1 GHz Processor Type: - Apple A4 CPU Cores: - 1 Installed RAM: - 512 MB Capacity: - 32 GB Display Size: - 3.5 Inch (326ppi Retina) BLU / Coating: - LED Backlit Resolution: - 960 x 640 Networking Power Repair and Support WiFi: - 802.11 b/g/n Bluetooth: - 2.1 + EDR Networks: - UMTS/HSDPA/HSUPA (850, 900, 1900 & 2100 MHz) GSM/EDGE (850, 900, 1800 & 1900 MHz) Adapter: - Charge through USB Battery: - Rechargeable lithium-ion Battery Life: - Up to 6 hours on 3G. Support Status: - Supported Apple Programs: - Check here to see if this unit is eligible. Warranty Ends: - The default warranty ends around Sep 2011 Verify Warranty: - Check warranty status here Requirements Size and Weight Mac: - OS 10.5.8 or later PC: - XP, Vista or 7 with SP3 or later iTunes: - iTunes 10.1 or later Height: - 4.5 inches (115.2 mm) Width: - 2.31 inches (58.6 mm) Depth: - 0.37 inch (9.3 mm) Weight: - 4.8 ounces (137 grams) Misc information Misc information Current value // Powered by SellYourMac.com Original OS: - iOS4 Recommended OS: - Current iOS Introduction: - June 2010 Discontinued: - This model is still in production. USB: - Dock connector Color: - - Model ID: - iPhone 3,1 Part Number: - (MC319LL/A) Camera front: - 0.3 (VGA) Megapixel Camera rear: - 5 Megapixel (720p recording) Carrier: - - New price: - Coming Soon SellYourMac will pay you $ 220.00 KIỂM TRA THẤY HẾT BẢO HÀNH RỒI .GIỜ MUA CODE NTN VẬY CÁC BÁC ? GIUP E VỚI.
