Killer Mobile Total Recall Chương trình ghi âm cuộc gọi
Thảo luận trong 'ỨNG DỤNG QUẢN LÝ CUỘC GỌI, TIN NHẮN' bắt đầu bởi tichau, 9 Tháng tư 2009.
  1. tichau Guest
    Killer Mobile Total Recall v3.2.1 S60v3 SymbianOS 9.x Unsigned -BiNPDA
    Total Recall is the Market Leading Call Recorder / Mobile Dictaphone for Symbian Series 60 2nd & 3rd Edition Devices. In classic Killer Mobile Software Style, we've created an application that is super easy to use, while retaining all of the features you'll ever need. Total Recall allows you to easily record all or just some of your calls. We use super memory light AMR format, so you can literally record thousands of hours of calls on today's modern memory cards. And best of all, no pesky beep while recording*!
    Core Features Include: (Note: Not all features available in all versions)
    • Extremely small footprint - consumes very little memory
    • No Beep Recording **
    • AMR & WAV* Support
    • AutoSend Clips via MMS, HTTP* & Email
    • Unlimited Recording Time
    • Add notes to your clips
    • Record to Internal Memory or Memory Card
    • Intuitively Named Clips
    • Transfer Clips to your PC with Ease
    • Password Protection Available
    • Auto Record All Calls or Be Prompted to Record
    • Manual Start/Stop via Hot Keys
    • Dictaphone (While not on a call)
    • Upload Clips via HTTP* (3rd edition only) (*Requires a free KM web user account for registered Total Recall users)
    • Autostart at reboot
    • FREE Updates for the Life of your device!
    • Ask about our FREE web based user account
    danght, haiptplc, hihihi and 26 others like this.
  2. tichau
    tichau Guest
    Killer Mobile TotalRecall v3.30 S60v3 SymbianOS9.x Unsigned-mEnPDA/iNSPECTOR/BinPDA
    Total Recall is the Market Leading Call Recorder / Mobile Dictaphone for Symbian 2nd & 3rd Edition Devices. In classic Killer Mobile Software Style, we've created an application that is super easy to use, while retaining all of the features you'll ever need. Total Recall allows you to easily record all or just some of your calls. We use super memory light AMR format, so you can literally record thousands of hours of calls on today's modern memory card. And best of all, no pesky beep while recording*!
    Total Recall, the most popular, user friendly Call Recorder Utility for S60 devices has been updated to version 3.3.0 for S60 3rd/5th edition devices.
    5/25/2009 -- NEW!!- S60 3rd and 5th updated to v3.3.0. Updates includes a new Beep tuning slider (for dynamic beep control), System App setting (to prevent app shut down during low memory situations) and an improved web/email over web sending module for registered users!
    Nokia 3250, 5500, 5700, 6110, 6120, 6121, 6210, 6220, 6290, E50, E51, E60, E61, E61i, E62, E63, E65, E66, E70, E71, E90, N71, N73, N75, N76, N77, N78, N80, N81, N81 8GB, N82, N91, N92, N93, N95, N95 8GB, 5800 Xpress Music
    Latest Devices**: Nokia N96, N79, 5320 xpress music, N69 & N85, E63, E75
  3. tichau
    tichau Guest
    Killer.Mobile.Total.Recall.v3.30.S60v3.S60v5.Symbi anOS9.x.Unsigned.Proper-iNSPECTOR
    Total Recall is the Market Leading Call Recorder / Mobile Dictaphone for Symbian series 2nd & 3rd Edition Devices. In classic Killer Mobile Software Style, we've created an application that is super easy to use, while retaining all of the features you'll ever need. Total Recall allows you to easily record all or just some of your calls. We use super memory light AMR format, so you can literally record thousands of hours of calls on today's modern memory card. And best of all, no pesky beep while recording*!
  4. huythai48
    huythai48 Thành viên
    cài vào máy N82 kho6ng chạy được, có ai bị như tôi không?:((
  5. 211068
    211068 Thành viên
    thanks..phần mềm này sài tốt không cần hack phone mà vẫn setup được
  6. huythai48
    Bạn có thể cho biết bạn cài vào máy nào không? Thanks.
  7. letunganh123
    letunganh123 Thành viên
    mình muốn cài vào máy n96 con này có tv rồi anh em hướng dẫn mình với?
    cho mình biết đó là phần mềm nào
  8. motsinhvien
    motsinhvien Thành viên
    phần mềm này chạy ngon nhưng phải chạy thường trú => tốn pin và tài nguyên. các bác ai có phần mềm ghi âm cuộc gọi mà ko chạy thường trú ko? vd như khi mình gọi hay nghe dt thì nó sẽ có menu hỏi mình có cần bật chương trình lên ko đó! thanks
  9. lienhong75
    lienhong75 Thành viên
    cài cho N86 ghi âm cuộc gọi cứ 6s lại có tiếng beep , không cách nào tắt được ,đành phải xoá đi. Anh có PM nào sử dụng cho 86 không ?
    xin cám ơn !
  10. ltdz320
    ltdz320 Thành viên
    Không thường trú thì làm sao nó " hỏi " được hả huynh?
    khongan thích bài này.
