LMaxi Anti Theft Pro 2.4.1- phần mềm chống trộm
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 16 Tháng chín 2011.
  1. Khỉ Con interista
    Tính năng chính của LMaxi Anti Theft Installer:
    • Khóa điện thoại từ xa qua SMS
    • Định vị vị trí điện thoại bị mất qua bản đồ
    • Lấy số điện thoại của tên trộm từ xa
    • Xóa dữ liệu từ xa
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    LMaxi Anti Theft is the easiest way to get your lost or stolen phone back
    LMaxi Anti Theft Pro is a security software that help you protect and get your lost or stolen phone back.
    - Imitate the siren at maximum volume - send Alarm SMS.
    - Remotely lock the phone - send Lock SMS.
    - Hidden call from lost phone.
    - Get link to an online map service to look at the position of the phone on a map, last calls, thief phone number, IMEI and network operator name when send Info SMS.
    - Get last calls,thief phone number, IMEI and network operator name when new SIM card detected;
    - Get contacts from the phone via email
    - Remotely wipe data by SMS(Remove contacts, SMS and MMS messages, call history and all files on SD card)
    - Uninstall Protection
    For Android 2.2 and above. To remove go into Settings then Location & Security then Select Device Administrators and then uncheck LMaxi Anti Theft. Then you can uninstall LMaxi Anti Theft.
    - Hard Reset protection (Need root)
    - Automatically send SMS with information about phone when battery low and inserted new SIM card.
    - Stealth mode during GPS queries
    - Integrated Debugging
    - Hidden from application launcher
    - Lock selected applications on the phone
    Xem thêm:
    https://market.android.com/details?id=com.lmaxi.antitheftinstaller&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/452
  2. Khỉ Con
    2.4.0
    What's in this version:
    -Added pattern lock
    -Fix some bugs
  3. Khỉ Con
    Cập nhật 2.4.1 !!!!!!!
