Yêu cầu phiên bản Android từ: 2.0 Ảnh chụp màn hình: Tips To achieve the best effect, click Menu>Preferences>Advanced settings>High quality drawing, then you’ll get better experience. Brief Introduction Mage GO Launcher EX Theme, specially designed for GO Launcher EX, provides delicate app icons, wallpapers, folder and app drawer interface. Get it right now and have a completely new makeover of your Android smartphone. Notice: GO launcher theme is only available for phones with GO Launcher EX installed. Search “GO Launcher EX” on Google Play Shop and install it for free. ***How to Apply the Theme 1. Directly open the theme after successful installation. 2. or back to Menu>Theme, choose a theme you like and apply it to your phone. ***How to Change Wallpaper Click Menu>Wallpaper, and select the wallpaper you like. ***How to Change App Icons (Some devices might not automatically apply the icons) Long press some app icon>Replace>Theme’s icon, and then choose the icon you like. Thank you for your continued support. Feel free to contact us if you have any problems or suggestions. Xem thêm trên Play Store: Mã: [url]https://play.google.com/store/apps/details?id=com.gau.go.launcherex.theme.mage [/url] Tải về: Mã: [url]http://appstore.vn/android/home/app/9749 [/url]
