MobiFun Soft AgendaSaver - screen saver đa chức năng
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 19 Tháng hai 2010.
  1. tichau Guest
    MobiFun Soft AgendaSaver v2.0 S60v3 S60v5 SymbianOS9.x -Symbian
    [​IMG][​IMG]
    AgendaSaver là một đa chức năng screen saver. Nó sẽ hiển thị email mới, hẹn của bạn và To Do's. AgendaSaver cũng sẽ cho bạn biết nếu bạn có một cuộc gọi nhỡ, một tin nhắn mới hoặc voice mail. Chọn chế độ màn hình bảo mật trong trường hợp bạn không muốn hiển thị các thông tin này.
    AgendaSaver is a multi-functional screen saver. It will show you your new Emails, Appointments and To Do's. AgendaSaver will also let you know if you have a missed call, a new SMS or a new voice mail. Choose the privacy screen mode in case you don't want to show this information to anyone in the room.
    Main features:
    * Shows sender and subject of the last new emails on the chosen email accounts.
    * Shows your appointments and to do's.
    * Missed Calls, New Emails, New Voice Mails, Unread SMS and Locked Keypad indicator.
    * Shows Time and Date.
    * Shows your phone's battery level.
    * Privacy Screen Mode (available only in case the keypad is locked). The normal screen will show you only the Time, Date and the number of Missed Calls, new SMSs, new Voice Mails and Mails. In case you want to see the details of the new emails, appointments and to do's just press the center d-pad key.
    * Inverted Colors Mode. Choose this mode to see the AgendaSaver information with white text on black background instead of black text on white background.
    Settings and Registration :
    Settings > Personalisation > Themes > Power Saver
    viet1812 and gsm2 like this.
  2. tichau
    tichau Guest
    MobiFun Soft AgendaSaver v2.0 S60v3 S60v5 SymbianOS9.x Unsigned -FoXPDA
    [​IMG][​IMG]
    Main features
    Settings
    Register With
    55555
  3. minhtue
    MobiFun Soft AgendaSaver v2.0 S60v3/S60v5 SymbianOS9.x Unsigned Repack Cr*cked-FoXPDA
    [​IMG][​IMG]
    Main features
    Settings
    Register With
    55555
    Restart your cellphone after installation!
  4. tichau
    tichau Guest
