MobileWitch Bluetooth Remote Control 2.1.0 {Control your computer from your mobile} Mobilewitch BT Remote Control is a free of charge application that can be used to control your computer from distance. The main purpose of this software is to turn your mobile phone into a universal PC remote control. The application is perfect for business as well as for your own enjoyment. Now you can easily remote control your PowerPoint presentations, Mouse Cursor or simply explore the content of your computer directly from your mobile phone. Tones of handy features will be available after installing the software. You will be able to change the tracks and videos played on Media Player or Winamp, browse for artists, albums or adjust the volume. The application will also give you remote access to programs such as Windows Explorer, Internet Explorer or Firefox. In the same time you will be able to Run commands on your computer or send text messages to your desktop. The program consists of two parts - the client and the server (both being written in Java). The former is located into a J2ME capable mobile phone with Bluetooth capabilities while the latter is placed in the computer you wish to remotely control. So, all you need for this software to run is a mobile phone with Bluetooth support and a Bluetooth dongle installed on your computer. In order to start using the Mobilewitch Bluetooth Remote Control you first need to download and install both Mobile Application and PC Server. In case of Nokia mobile phones, the Nokia PC Suite will automatically recognize and prompt you to install the application on your handset. Here are some key features of MobileWitch Bluetooth Remote Control: · Remotely control Mouse, Keyboard, PowerPoint, Winamp, Windows Media Player and much more · Get access to your desktop from your phone · Bluetooth setup free! Simply connect from your phone · Customize your applications through Keymaps or VB and JScripts · Supports all PC Bluetooth solutions Toshiba, Windows, BlueSoleil and Widcomm/Brodacom Link tải trọn bộ dành cho những bạn không muốn tải từng phần Mã: [CENTER][URL="http://www.mediafire.com/?m5ynmyzyywt"]http://www.mediafire.com/?m5ynmyzyywt[/URL][/CENTER]
cho bon minh bai viết cụ thể bằng tiếng việt đc không ban ơi.... mình thích phàn mềm này lắm... cảm ơn nhiều nhé
Mobilewitch BT Remote Control là một ứng dụng miễn phí có thể được sử dụng để điều khiển máy tính từ xa. Mục đích chính của phần mềm này là để biến điện thoại di động của bạn thành một máy tính phổ quát điều khiển từ xa. Việc áp dụng là hoàn hảo cho doanh nghiệp cũng như để hưởng của riêng bạn. Bây giờ bạn có thể dễ dàng điều khiển từ xa của bạn thuyết trình PowerPoint, Mouse Cursor hoặc đơn giản là khám phá những nội dung của máy tính của bạn trực tiếp từ điện thoại di động của bạn. Tấn tính năng tiện dụng sẽ có sẵn sau khi cài đặt phần mềm. Bạn sẽ có thể thay đổi các bài nhạc và video chơi trên Media Player hoặc Winamp, duyệt cho các nghệ sĩ, album hoặc điều chỉnh âm lượng. Ứng dụng này cũng sẽ cho bạn truy cập từ xa để chương trình như Windows Explorer, Internet Explorer hoặc Firefox. Trong cùng thời gian bạn sẽ có thể chạy lệnh trên máy tính của bạn hoặc gửi tin nhắn văn bản để bàn của bạn. Chương trình bao gồm hai phần - máy khách và máy chủ (cả hai đều được viết bằng Java). Các cựu có vị thành một điện thoại di động có khả năng J2ME với các khả năng Bluetooth trong khi sau này được đặt trong máy tính mà bạn muốn điều khiển từ xa. Vì vậy, tất cả các bạn cần cho phần mềm này để chạy được một điện thoại di động có hỗ trợ Bluetooth và dongle Bluetooth được cài đặt trên máy tính của bạn. Để bắt đầu sử dụng Mobilewitch Bluetooth Remote Control trước tiên bạn cần tải về và cài đặt cả hai ứng dụng di động và máy PC Server. Trong trường hợp của điện thoại di động Nokia, Nokia PC Suite sẽ tự động nhận biết và nhắc bạn cài đặt ứng dụng trên thiết bị cầm tay của bạn. Đây là một số tính năng chính của MobileWitch Bluetooth Remote Control: · Từ xa điều khiển chuột, bàn phím, PowerPoint, Winamp, Windows Media Player và nhiều hơn nữa · Hãy truy cập vào máy tính của bạn từ điện thoại của bạn · Bluetooth cài đặt miễn phí! Đơn giản chỉ cần kết nối từ điện thoại của bạn · Tùy chỉnh các ứng dụng của bạn thông qua Keymaps hoặc VB và JScripts Supports all PC Bluetooth giải pháp Toshiba, Windows, BlueSoleil and Widcomm / Brodacom
Đã update lại nguyên bộ cài đặt cho bạn. Sau khi tải về và giải nén, bạn cài soft mobile-witch-remote-control-free vô PC, còn file MWRemoteCtrl - Mobile Client thì cài vô phone ha.
phần mềm này rất hay đặc biệt dùng với laptop thì tuyệt. đặc biệt mình thấy chức năng mouse mode rất hay có thể nhìn thấy trên màn hình điện thoại là desktop của máy tính Thanks chủ topic nhé.
