Mobisophy Phone Alone - chống trộm cắp và giải pháp bảo vệ dữ liệu từ xa.
Thảo luận trong 'ỨNG DỤNG TIỆN ÍCH' bắt đầu bởi tichau, 29 Tháng mười hai 2009.
  1. tichau Guest
    Mobisophy Phone Alone v2.10.3570 S60v3/v5 SymbianOS9.x Unsigned-FoXPDA
    Phone Alone is an innovative remote control, anti-theft and data protection solution. It helps you to access your phone when it is not available. Like set up it as a auto answering & call forwarding machine, get back contacts, protect private data on the phone, locate where is your phone or lock/unlock your phone. Remotely!
    How to remote control your phone?
    By voice call
    Call to your phone from one of your pre-set managing numbers. Phone Alone will answer your call and prompt you with interactive voice menus. Then you can press keys according to voice menus to control your phone.
    By silent text message (SMS)
    Send a text message only containing your pee-set remote control code to your phone. Phone Alone will prompt you with interactive text menus by SMS. Then you can reply text messages according to instructions of text menus. SMS can be normal or silent and this setting is configurable.
    What you can do in remote control mode?
    Set up your phone as an auto answering and call forwarding machine: You can set your phone as an auto answering and call forwarding machine so you won't miss any calls. And also can assign the forwarded number or record the greeting of answering machine remotely.
    Get back contacts: Get back contacts by interactive voice or SMS menus. Matched contacts will be sent to you by text messages (SMS).
    Listen to local voicemails on your phone: You can call to your phone to listen voicemails that generated by Phone Alone's answering machine. Like operator's voicemail system.
    Protect or recover data: Protect or recover private data on your phone like contacts, messages, images, videos and sounds remotely. Protected data can be recovered later if you know the remote control code.
    Lock or unlock your phone to prevent from unwanted checks.
    Activate anti-theft mode: More details please see "How anti-theft function works".
    Notice: All these operations are also available for local operations, not only limited to remote controls!
    Anti-theft mode will be triggered when your SIM card was changed. Once anti-theft mode is activated, Phone Alone will call or send text messages to three pre-set notification numbers so you can begin to remote control your lost phone. If notification calls or text messages are not responded within certain time (default is 5 minutes), all data will be protected automatically.
    Notice: Whether to enable anti-theft feature is configurable. And protected data can be recovered later if you know the remote control code.
    Change Log :
    * Now compatible with Nokia touch screen phones like 5800 XpressMusic, N97 and N97 mini (S60 5th devices). Also compatible with S60 3rd FP2 devices.
    * Now can run with IVCM and PhonePilot at the same time to handle incoming and outgoing calls.
    * Set the maximum duration of a voice message created by answering machine to three minutes.
    namnghinruoi thích bài này.
  2. kuteo
    kuteo Thành viên
    cho em đóng góp bản dịch nha!!
    Điện thoại Alone là một điều khiển từ xa sáng tạo, chống trộm cắp và giải pháp bảo vệ dữ liệu. Nó giúp bạn truy cập vào điện thoại của bạn khi nó không có sẵn. Giống như thiết lập nó như là một máy trả lời tự động & chuyển tiếp cuộc gọi, nhận lại địa chỉ liên lạc, bảo vệ dữ liệu cá nhân trên điện thoại, xác định vị trí nơi mà là điện thoại của bạn hoặc khóa / mở khóa điện thoại của bạn. Từ xa!
    Làm thế nào để điều khiển từ xa điện thoại của bạn?
    Bởi thoại gọi
    Gọi đến điện thoại của bạn từ một trong những trước của bạn thiết lập số quản lý. Điện thoại Alone sẽ trả lời cuộc gọi của bạn và nhắc bạn với các menu thoại tương tác. Sau đó, bạn có thể nhấn phím theo thực đơn giọng nói để điều khiển điện thoại của bạn.
    Bởi im lặng tin nhắn văn bản (SMS)
    Soạn tin nhắn văn bản chỉ chứa Pee của bạn đặt mã điều khiển từ xa đến điện thoại của bạn. Điện thoại Alone sẽ nhắc bạn với các menu văn bản tương tác bằng tin nhắn SMS. Sau đó, bạn có thể trả lời tin nhắn văn bản theo hướng dẫn của các menu văn bản. Tin nhắn SMS có thể được bình thường hoặc im lặng và thiết lập này là cấu hình.
    Những gì bạn có thể làm trong chế độ điều khiển từ xa?
    Cài đặt điện thoại của bạn như là một trả lời tự động và máy chuyển tiếp cuộc gọi: Bạn có thể đặt điện thoại như một trả lời tự động và máy chuyển tiếp cuộc gọi, do đó bạn sẽ không bỏ lỡ bất cứ cuộc gọi. Và cũng có thể ấn định số lượng chuyển tiếp hoặc ghi lời chào trả lời của máy từ xa.
    Nhận lại địa chỉ liên hệ: Hãy trở lại địa chỉ liên lạc bằng giọng nói tương tác hoặc tin nhắn SMS menu. Địa chỉ liên hệ đối sánh sẽ được gửi đến bạn bởi tin nhắn văn bản (SMS).
    Nghe thư thoại của địa phương trên điện thoại của bạn: Bạn có thể gọi đến điện thoại của bạn để nghe thư thoại đó được tạo ra bởi máy trả lời điện thoại của Alone. Cũng giống như hệ thống thư thoại của nhà điều hành.
    Bảo vệ hoặc phục hồi dữ liệu: Bảo vệ hoặc phục hồi dữ liệu cá nhân trên điện thoại của bạn như địa chỉ liên lạc, tin nhắn, hình ảnh, video và âm thanh từ xa. Được bảo vệ dữ liệu có thể được phục hồi sau này nếu bạn biết mã điều khiển từ xa.
    Khóa hay mở khóa điện thoại của bạn để ngăn chặn từ kiểm tra không mong muốn.
    Kích hoạt chế độ chống trộm cắp: Chi tiết xin vui lòng xem "Làm thế nào chống trộm cắp tác phẩm chức năng".
    Thông báo: Tất cả các hoạt động này cũng có sẵn cho các hoạt động địa phương, không chỉ giới hạn trong điều khiển từ xa!
    Chế độ chống trộm sẽ được kích hoạt khi thẻ SIM của bạn đã được thay đổi. Sau khi chế độ chống trộm cắp được kích hoạt, Điện thoại Alone sẽ gọi điện hoặc gửi tin nhắn văn bản đến ba đặt trước số thông báo, do đó bạn có thể bắt đầu điều khiển từ xa bị mất điện thoại của bạn. Nếu thông báo cuộc gọi hoặc tin nhắn văn bản không được trả lời trong thời gian nhất định (mặc định là 5 phút), tất cả dữ liệu sẽ được bảo vệ tự động.
    Thông báo: Cho dù để kích hoạt tính năng chống trộm được cấu hình. Và bảo vệ dữ liệu có thể được phục hồi sau này nếu bạn biết mã điều khiển từ xa.
    Change Log:
    * Now tương thích với Nokia điện thoại màn hình cảm ứng giống như 5800 XpressMusic, N97 và N97 mini (S60 thiết bị thứ 5). Cũng tương thích với các thiết bị S60 3rd FP2.
    * Hàng có thể chạy với IVCM và PhonePilot tại cùng một thời gian để xử lý cuộc gọi và gửi đi.
    * Đặt thời hạn tối đa của một tin nhắn bằng giọng nói được tạo ra bằng cách trả lời máy đến ba phút.
  3. Alias2110
    Alias2110 Thành viên
    Khó hiểu quá ta :030:
  4. namnghinruoi
    namnghinruoi Thành viên
    cái này tôi có nghe nhắc đến nhưng chưa rõ lắm! Có Pro nào đã check chưa thì hd cho AE với! Nhân đây cho hỏi E72 có dùng đc không?
  5. namnghinruoi
    Mình cài vô Nokia E72 thì báo pm hết hạn gì gì nữa đó, liên hệ nhà cung cấp?****?
  6. ZzhoanghungzZ
    ZzhoanghungzZ Thành viên
    bác này chắc chưa hack phone rồi nên mới n.thế đó
  7. namnghinruoi
    Cảm ơn bạn!
    Mình vừa mò và hackphone con E72 xong. Nhưng riêng pm này mình chưa dám cài vì không hiểu nò cho lắm, thứ nữa là đã mất đt rồi thì mất công tìm vàng dưới biển thôi!
