mới lượm được
Thảo luận trong 'Điện Thoại Phổ Thông' bắt đầu bởi namdat, 7 Tháng mười hai 2004.
  1. namdat Thành viên
    Mình mới lượm được mấy cái soft cho SE =Java này trên mạng nè, có bác nào biết qua chưa?
    WorldCam Viewer
    WorldCam Viewer is the original webcam viewer for mobile devices. WorldCam now comes with over 100 preset webcams available for your viewing pleasure.
    Possible to add you favorite web cams!
    Amark
    Benchmarking for you Java mobile devices, should run on most mobiles that support Java, tested on a K700i.
    First Aid Guide
    A basic guide to first aid on you phone.
    Please beawre that this is a guide and I have nothing to do with its contents
    Periodic Table
    Ain't Sience great... the whole Periodic table on you phone in glorious colour!
    sheet
    found an app. for the K700i - sheet (mobile excel)
    mcbpro
    Mobile Checkbook from vstuff
    Voice Middlet
    Interesting display of midp 2.0 capabilities in k700i, this middlet is designed to use the camera and sound to recognize different colours.
    Battery Rebuild And Maintenance
    Run this program just before recharging your battery. Program will help your battery keep a long lasting charge. "It''s important to stretch the legs of your battery." -Qwest engineer. This program stretches the legs of your battery by de-charging it before your re-charge your battery. We suggest
    running Battery Rebuild and Maintenance at least once a month
    EZBmi_R1_0_1
    EZBmi is a mobile application helping you to calculate your BMI value. It can run on any Java enabled handset.
    EZDice_R1_0_2
    EZDice is a mobile application helping you to generate random numbers for gambling, decision making etc. It can run on any Java enabled handset.
    Sony Ericsson Unit Converter
    (the one that comes in S700)
    hiep_nguyenhoang thích bài này.
  2. zhouyumin
    zhouyumin Thành viên
    K700i có xài được các soft trên ko
  3. linh_sky
    linh_sky Guest
    ui doi ,cai nay la thu tre con thoi
  4. vanhh
    vanhh Thành viên
    Đã là ứng dụng Java thì loại máy nào có hỗ trợ Java là xài được hết các bác à!
  5. minhchinh
    minhchinh Thành viên
    Cảm ơn namdat nhé, mình vừa dùng N6630 và chuyển qua dùng SE S700i nhưng mà cái này ít application cho nó quá, may có vài cái của namdat cài vào chạy rất tốt cho cả S700i và cả K700i,
    Cảm ơn,....=D>
