MyBackup Pro - sao lưu, phục hồi dữ liệu chỉ với 1 lần chạm
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 17 Tháng chín 2011.
  1. Khỉ Con interista
    Khác với Titanium, MyBackup Pro có giao diện khá đơn giản nhưng vô cùng hiệu quả. Bạn có thể sao lưu/phục hồi dữ liệu của ứng dụng (apk+data), danh bạ, tin nhắn đến/từ thẻ nhớ hoặc dữ liệu trên mạng.
    [​IMG][​IMG][​IMG][​IMG]
    The easiest backup for Android
    Supporting the most content and the most devices
    MyBackup Pro is the easiest backup for Android. Supporting the most content, and the most Android devices.
    Backup (with schedule option) to our online secure servers, or SD card, your Applications, Photos, Contacts, Call log, Browser Bookmarks, SMS (text messages), MMS (message attachments), Calendar, System Settings, Home Screens (including shortcut positions), Alarms, Dictionary, Music Playlists, and more...
    Restore your backups on your existing or new phone.
    View your data and application backups online, by logging into the Web Viewer at www.RerWare.com
    MyBackup Pro will work on all Android mobile devices, regardless if they have root access or not.
    Users who have a rooted phone: You can backup apk+data as well as market links!
    NOTE: Data/setting of applications can only be supported if you have a rooted phone, or if the application integrates with us.
    __ ROOT ONLY PHONE FEATURES BELOW __
    MyBackup Pro now comes with all MyToolbox features for Free.
    This application will allow Root users to multi-select applications and perform the following functions with 0-click batch operations!
    - Freeze bloatware, system apps
    - UnFreeze frozen applications
    - Wipe Cache of applications
    - Wipe Data of applications
    - Uninstall applications
    - Break the Android Market Link to Apps
    - Link Apps to the Android Market
    - Force Close applications
    Xem thêm:
    https://market.android.com/details?id=com.rerware.android.MyBackupPro&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/856
    namfat thích bài này.
  2. Medo1
    Medo1 Thành viên
  3. Khỉ Con
    What's in this version:
    1. IN BETA: Ability to trigger a Remote Backup (Android 2.2+ only) by logging into the Web Viewer at www.rerware.com
    2. New 3.0 Interface.
    3. Re-translation of languages: German, Japanese, French, Spanish, and Italian.
    4. Added languages: Korean, and Finnish.
    5. Fixed sort order for device viewing the contacts data type.
    6. MyToolbox now shows apps that are frozen (only on Android OS 2.3.3+).
    7. Honeycomb 3.2 support.
    8. Misc. minor bug fixes.
  4. Khỉ Con
    3.0.1
    1. RESTART YOUR DEVICE AFTER UPDATING THE APP
    2. Fixed calendar restore issue with null error.
    3. French language fix.
    4. Slight changes to German and Korean translations.
    5. Fixed some bugs in remote backup.
    6. Misc. minor bug fixes.
  5. khangminh
    khangminh Thành viên
    Phiên bản: MyBackup Pro 3.0.6 ($4.99. SALE: $2.99)
    Dung lượng: 1.55MB
    Yêu cầu thiết bị: Android 1.5+
    Cách dễ dàng nhất để sao lưu cho Android
    Hỗ trợ hầu hết nội dung và hầu hết thiết bị
    GIÁ KHUYẾN MÃI
    Mua ứng dụng ngay hôm nay chỉ với $2.99, giá gốc là $4.99
    Giá này sẽ không được bán lâu dài, đặt hàng ngay để chắc chắn bạn mua được bản sao với giá thấp
    MyBackup Pro là một phần mềm sao lưu dễ dàng nhất cho Android. Hỗ Hỗ trợ hầu hết nội dung và hầu hết thiết bị
    Sao lưu (với tùy chọn lịch biểu) lên máy chủ bảo mật của chúng tôi hoặc lên thẻ nhớ SD, Ứng dụng của bạn, Hình ảnh, Danh bạ, Nhật ký cuộc gọi, Tin nhắn văn bản, Tin nhắn đa phương tiện (tập tin đính kèm), Lịch, Cài đặt hệ thống, Màn hình chính (hỗ trợ cả vị trí của shortcut), Báo thức, Từ điển, Danh sách bài hát, và nhiều hơn nữa...
    TRONG BẢN BETA: Khởi động một bản sao lưu trên điện thoại của bạn (Chỉ dành cho Android 2.2) từ bất cứ nơi nào trên thế giới bằng cách đăng nhập vào Web Viewer từ website Android Backup - MyBackup Pro
    Khôi phục những bản sao lưu lên điện thoại cũ hoặc điện thoại mới.
    Xem dữ liệu và những ứng dụng sao lưu trực tuyến, bằng cách đăng nhập vào Web Viewer tại Android Backup - MyBackup Pro
    MyBackup Pro sẽ hoạt động trên tất cả các thiết bị Android, kể cả họ đã root hay chưa
    Điện thoại đã root: Bạn có thể sao lưu tập tin APK + Dữ liệu (DATA) giống như là Market links!
    LƯU Ý: Dữ liệu/Cài đặt của ứng dụng có thể chỉ hỗ trợ khi bạn đã root điện thoại, hoăc nếu ứng dụng tích hợp tương thích với ứng dụng này
    __ CHỈ NHỮNG ĐIỆN THOẠI ĐÃ ROOT SẼ CÓ TÍNH NĂNG SAU __
    MyBackup Pro đã đến với tất cả tính năng của MyToolbox miễn phí
    Ứng dụng này cho phép root users chọn nhiều mục và thực thi những chức năng bên dưới
    • Đóng băng bloatware, những ứng dụng hệ thống
    • Hủy đóng băng những ứng dụng
    • Xóa bộ nhớ đệm của những ứng dụng
    • Xóa dữ liệu của những ứng dụng
    • Gỡ bỏ ứng dụng
    • Bẻ gãy liên kết từ Android Market đến những ứng dụng
    • Liên kết ứng dụng đến Android Market
    • Bắt buộc đóng những ứng dụng
    Bản diễn thử
    tranminhthanh009 thích bài này.
