MyProfiles 2.2.1 - quản lý, thiết đặt lịch trình cho cấu hình máy
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 13 Tháng chín 2011.
  1. Khỉ Con interista
    Tính năng:
    - Support various of settings, sound volume, ringtone, car mode, wifi, wifi hotspot, bluetooth, gps, auto-sync, mobile network, APN, WiMAX(4G), brightness, screen timeout, auto-rotate, auto lock, auto answer, launch application ...
    - Location events are supported, automatically activate profiles in differnt locations
    - Timer events are supported, automatically activate profiles in differnt time periods
    - One click to apply all the settings you need
    - Event-triggered system, extremely power saving
    - Desktop widget is supported (Several styles)
    - Long-press search key is supported
    - Notification icon is supported
    - Lots of profile icons are provided
    - Keep improving...
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Xem thêm:
    https://market.android.com/details?id=com.fancy01.myprofiles&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/25
