Thông tin ROM: System details: Android 4.1.1 (Jelly Bean) - latest official Samsung N7100XXALJ1 firmware This is improved version of stock ROM - no visual changes! Very fast, clean & stable! Multi-language (WWE) Full Arabic and Hebrew languages support! (ICS feature) For Samsung Galaxy Note 2 Thanks to Samsung for the base firmware ROM details: Removed software (CPU) rendering - full Exynos 4 Quad (GPU) rendering Fully optimized and tweaked ROOT (su + SuperSu Permissions - Thanks to chainfire) Unsecured boot.img Newest BusyBox RAM optimizations System signatures check enabled for system security and safety Improved virtual memory management Speed optimizations Enabled GPU UI rendering Data, cache and system partitions mounting tweaks Bloatware applications removed All /system applications updated to latest available All /data applications updated to latest available Improved camera performance Improved CPU governors performance Most optimal system scheduler Disabled kernel debugging for better performance Zipaligned (Improved RAM management) Zipalign on boot (for user applications on data partition) Fully de-odexed init.d scripts (BusyBox run-parts) support Auto init.d permissions set on boot sysro/sysrw commands support Excellent battery life! Improved EXT4 performance You can replace Samsung boot animation with any custom one (or use ICS default) OpenVPN support Most up-to-date system files permissions Adobe Flash Player support for Jelly Bean Support almost 24h a day ...and many more! Hướng dẫn cài đặt: Tải ROM, cop vào bộ nhớ máy Reboot recovery, wipe all Chọn install from sd card, tìm đến đường dẫn ROM và cài Khởi động lại máy và enjoy
