NEC's "N906iL" is a wireless LAN capability FOMA handsets. "Onefone (von One)" is the nickname given. DoCoMo's wireless LAN-enabled cell phone with NEC's as is the first model that can also purchase individual users. The basic function is "N906i" is close, "N906iL" will feature non-compliant DESUKUTOPPUINFO blog posts and other features, SUMAIRUFEISUSHATTA, Panorama Rec is not available. The "N906i" of the 5.2 million-pixel camera, but, "N906iL", with 2 million pixels. One-segment functions that are not. A major feature of the wireless LAN capability. IEEE802.11a/b/g conform to the maximum down to 54 Mbps communication is possible. Wireless LAN security, WEP or WPA, WPA2-PSK and corresponding. Key decisions right direction down the channel i hold the button in the menu mode switch to call. The function of the "wireless LAN priority" "FOMA network priority", N906iL use of the network which allows it to override. Home wireless LAN service to allow for "Home U" (1,029 yen per month) is available. Home wireless LAN communications in the area U if the contract is FURUBURAUZA HODAI packet is available free of charge. The U Home VoIP is possible through the home between the U and calls are usually free. VoIP VoIP services for No. 050 was issued. Home use of the access point will be dedicated broadband line and the corresponding antenna is required. Line, multi-session support Flet's line (ADSL / FTTH) only available. The packet, or packets HODAI HODAIFURU also required in the contract. You can also purchase individual terminals, but DoCoMo's corporate IP telephony solutions "PASSAGE DUPLE" "Centrex business moperaIP" corresponding said. Flash Lite 3.0 compliant, you accept the FURUBURAUZA Flash Video (Flash 8 equivalent) is played. HSDPA, a disaster, map-enabled applications, and play music (WMA, SD-Audio) is available. The new service is not compatible with DEKOMEANIME. Also, 2 MB of video still images of Web SAITOAPPURODO FURUBURAUZA is only available. The main display is approximately 3.0 inches wide full-VGA, 0.9-inch display is about black and white organic E Two-million-pixel cameras. Body size is 109 × 49 × 19.6mm, weighs about 127 g. Receives approximately 600 hours of continuous standby time, GSM is about 290 hours, about 220 minutes of talk time, GSM is about 190 minutes. 2GB microSD card to respond. Body colors are BROWN, SILVER two colors.
lần này con N906iL đã là em quên đi iPhone thực sự, k biết khả năng luớt web của "cu này" thế nào đây ??!!!:whew: -nhưng lần này ở Nec có 2 models , dòng N906i là camera 5,2MP, nhưng N906iL (dòng có wireless ) thì camera chỉ có 2MP
hình như các dòng 906 lần này của DOCOMO giống như là một cuộc đại nâng cấp từ 905 lên,khắc phục các điềm hạn chế của 905 và hoàn thiện các chức năng cũ. như hoangpham75 nói thì đúng là chưa thấy gì nổi bật,như 905 đã từng làm với dòng 904.
Mình đọc đi đọc lại các thông số thuộc họ 905i vì mình cũng đang nghiên kứu đầu tư 1 chú! Mình nhận thấy họ 905i nổi bật nhất vẫn là họ P (P905i)và họ N (N905i). Giờ 906i ra mắt cũng là một cơ hội tốt để đầu tư 905i rồi. Mình thích nhất là N90Xi vì cơ chế xoay gập rất tiện, P90Xi xoay gập hơi cồng kềnh ! Điểm yếu nhất của các họ này là đèn Flash còn kém !
