NetQin Mobile Guard - mọi thứ về hệ thống trong 1 phần mềm
Thảo luận trong 'ỨNG DỤNG HỆ THỐNG' bắt đầu bởi Khỉ Con, 4 Tháng một 2011.
  1. Khỉ Con interista
    NetQin Mobile Guard v3.00 S60v3/^1/^3 SymbianOS9.x Signed {AIO System Utilities}
    As mobile devices adopt more and more PC capabilities, performance speed and power consumption become critical issues. NetQin Mobile Guard is designed to improve your mobile phone performance by removing junk, minimizing power consumption, blocking harmful sites and protecting your mobile phone against malware. This product also helps manage internet usage with monthly limits, a connection log, and even a real-time traffic bar that shows the amount of traffic ************.com being transferred.
    Features:
    System Optimization:
    · OS Scan identifies the system problem and helps you fix it to improve the device performance.
    · System management functions help you manage the applications, clean trash to free memory and accelerate start-up speed.
    Proactive Protection:
    · Anti-Malware detects and deletes existing Malware to protect your device from security threats.
    · Safe Mode is a crash protection feature, which provides safe environment for solving device problems and prevent the loss of data.
    Internet Usage Management:
    · Traffic limit: Control how much you spend on the internet by putting a limit on it
    · Connection log: See how much you've used traffic has been transferred in the month
    · Traffic bar: See the amount of traffic coming in or going out in real-time.
    new in 3.0 version Change-Log
    1.NEW!! Call manager and spam SMS filter;
    2.NEW!! Contacts backup;
    3.NEW!! Outgoing call connection prompt;
    4.NEW!! Switch skins;
    5.NEW!! Document search;
    6.Optimized program manager;
    7.Optimized spam cleaning;
    8.Enhanced traffic monitor;
    9.Optimized file manager;
    10.More comprehensive scan;
    11.NEW!! Settings of connection;
    12.Optimized system settings;​
    [URL="http://www.mediafire.com/?tn811jdqekr3hd1"]http://www.mediafire.com/?tn811jdqekr3hd1[/URL]
  2. bigboy126900
    bigboy126900 Thành viên
    sao không tải đượcvậy mấy bác
  3. Khỉ Con
    diễn đàn đang lỗi, mình fix lại link ở bài đầu rồi đấy bạn ^^
  4. nhieu92
    nhieu92 Thành viên
    Mấy bác post làm ơn dịch ra tiếng việt hộ cái coi. :D
  5. Khỉ Con
    google thôi nha bạn :D
    cukuise thích bài này.
  6. mr.kavil
    mr.kavil Thành viên
    vào trang chủ www.netqin.com.vn để tải về đi các pro, có hổ trợ đầy đủ cho cả android, symbian, window phone, blackberry nữa đó...
  7. vitxiem02
    vitxiem02 Thành viên
    up cho netqin nè, cái này xài tốt và nhiều tính năng ghê...all in one
