Mình đã thử flash bằng Phoenix bản 2009 và JAF nhưng vẫn ko hiệu quả. Firmware update là bản V40 tiếng Việt tải bằng navifirm. Khi thử bằng JAF thì báo lỗi sau: Mã: Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 90009698 P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 009.012.005 Elf2flash 09.11.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ....................Loader Sent! Stage 2 starting..................PUBKEYS already sent... PUBKEYS already sent... PUBKEYS already sent... PUBKEYS already sent... PUBKEYS already sent... ...........Phone prepared OK! Waiting for the phone to boot... Searching for phone... Status byte: 8000 Selecting CMT flash... Result: 0000 Phone is in flash mode... CMT blocks: 582, APE blocks: 0 Erasing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.core.C00... Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000 Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000 Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000 Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000 Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000 Partition result: 0014 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.rofs2.V20... Erasing cmt zone 07060000 - 0915FFFF ... Erase result: 0000 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_C01_prd.rofs3.fpsx... Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM356_40.0.005_023_xxx_U01.uda.fpsx... Erasing cmt zone 09E60000 - 0F71FFFF ... Erase result: 0000 Send CMT CFG... Writing cmt... Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.core.C00... Sending CMT HASH for ADA Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for RAP3NAND Sending CMT HASH for PASUBTOC cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... cmt->PAPUB keys already sent... Sending CMT HASH for SOS*UPDAPP Sending CMT HASH for SOS*ENO Sending CMT HASH for SOS*DSP0 Sending CMT HASH for SOS*ISASW Sending CMT HASH for SOS+CORE Sending CMT HASH for SOS+ROFS1 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_prd.rofs2.V20... Sending CMT HASH for SOS+ROFS2 Write result 27: 1701 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_40.0.005_C01_prd.rofs3.fpsx... Sending CMT HASH for SOS+ROFS3 Write result 27: 1701 Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM356_40.0.005_023_xxx_U01.uda.fpsx... Rebooting... Finishing CMT session... Restarting CMT... Pooling phone... Phone not found... Second try... Phone not found... Done! Xin hãy giúp đỡ!
từ đầu khi bắt đầu flash thì màn hình máy có sáng lên nhưng toàn màu trắng nhưng đến đoạn Pooling phone... Phone not found... thì nó tắt ngúm ròi chớp tắt vài lần sau đó im luôn. mình làm trên 20 lần rồi, đều thử qua Phoenix bản 2009 và JAF, làm mọi cách hết rồi. khi flash đều chọn dead usb nhưng vẫn ko ăn thua. Cao nhân nào am hiểu xin hãy giúp đỡ, hiện tại ko có DT để dùng
hiện giờ bạn khởi động còn lên hay k , khi Flash gần xong nó co báo bạn là k nhận dc driver k , nếu có thì bạn cứ chọn " NO" và rút cáp ra , khởi động lại và format máy , vì quá trình như trên là bạn đã Flash xong rùi , nó chỉ kiểm tra lại nữa thôi
hehe cái này hình như máy bị hết pin nên thông báo kiểu đó. Hôm trước tưởng dead phone ai ngờ... máy hết pin.
ko phải hết pin đâu bạn ah mình cũng bị như vậy giờko biết phải làm thế́́ nào đây: Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Scanning image files... Waiting for USB device... Loading secondary boot code: 15232 bytes Secondary boot loaded Loading update server code: 2910927 bytes Update server loaded Asic CMT: Verifying communication to device... Asic CMT: Verifying communication to device... Asic CMT: Start programming 133884 KB... Asic CMT: Partitioning RM-356_52.0.007_prd.core.C00 Asic CMT: Partitioning area 1... Asic CMT: Erasing RM-356_52.0.007_prd.core.C00 Asic CMT: Erasing area 1... Asic CMT: Erasing area 2... Asic CMT: Erasing area 3... Asic CMT: Erasing area 4... Asic CMT: Erasing area 5... Asic CMT: Erasing partition 0x0000000A... Asic CMT: Erasing RM-356_52.0.007_prd.rofs2.V20 Asic CMT: Erasing area 1... Asic CMT: Erasing RM-356_52.0.007_C04_prd.rofs3.fpsx Asic CMT: Erasing area 1... Asic CMT: Erasing RM-356_52.0.007_026_000_U01.uda.fpsx Asic CMT: Erasing area 1... Asic CMT: Programming RM-356_52.0.007_prd.core.C00 Asic CMT: Programming 0% Asic CMT: Programming 2% Asic CMT: Programming 4% Asic CMT: Programming 6% Asic CMT: Programming 8% Asic CMT: Programming 10% Asic CMT: Programming 12% Asic CMT: Programming 14% Asic CMT: Programming 16% Asic CMT: Programming 18% Asic CMT: Programming 20% Asic CMT: Programming 22% Asic CMT: Programming 24% Asic CMT: Programming 26% Asic CMT: Programming 28% Asic CMT: Programming 30% Asic CMT: Programming 32% Asic CMT: Programming 34% Asic CMT: Programming 36% Asic CMT: Programming 38% Asic CMT: Programming 40% Asic CMT: Programming 42% Asic CMT: Programming 44% Asic CMT: Programming 46% Asic CMT: Programming 48% Asic CMT: Programming 50% Asic CMT: Programming 52% Asic CMT: Programming 54% Asic CMT: Programming 56% Asic CMT: Programming 58% Asic CMT: Programming 60% Asic CMT: Programming 62% Asic CMT: Programming 64% Asic CMT: Programming 66% Asic CMT: Programming 68% Asic CMT: Programming 70% Asic CMT: Programming 72% Asic CMT: Programming 74% Asic CMT: Programming 76% Asic CMT: Programming 78% Asic CMT: Programming 80% Asic CMT: Programming RM-356_52.0.007_prd.rofs2.V20 Asic CMT: Programming 82% Asic CMT: Programming 84% Asic CMT: Programming 86% Asic CMT: Programming 88% Asic CMT: Programming 90% Asic CMT: Programming 92% Asic CMT: Programming RM-356_52.0.007_C04_prd.rofs3.fpsx Asic CMT: Programming 94% Asic CMT: Programming RM-356_52.0.007_026_000_U01.uda.fpsx Asic CMT: Programming 96% Asic CMT: Programming 98% Asic CMT: Programming 100% Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 Waiting for communication response: 17 Waiting for communication response: 16 Waiting for communication response: 15 Waiting for communication response: 14 Waiting for communication response: 13 Waiting for communication response: 12 Waiting for communication response: 11 Waiting for communication response: 10 Waiting for communication response: 9 Waiting for communication response: 8 Waiting for communication response: 7 Waiting for communication response: 6 Waiting for communication response: 5 Waiting for communication response: 4 Waiting for communication response: 3 Waiting for communication response: 2 Starting to recover the phone Recoverying phone Initializing Waiting for communication response: 1 Error 0x8401F121 communicating to phone. Unable to verify comm. Warning: Unable to communicate to product after flashing Scanning image files... Phone recovery completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verifiedFlashing finalization failed. Do you like to retry the finalizing? HRESULT 0x8421001f (-2078212065) Firmware: Failed to switch phone to correct mode for fartorysettings using USB. helppp!!!!
Em cũng bị đoạn pooling phone này nên dead cái phone, khi flash lại ở chế độ dead usb, cứ tưởng cứu được ai ngờ lại đến cái đoạn pooling phone lại die chưa biết khắc phục sao nữa
Hình như lỗi này là chưa có driver trong máy thì phải bạn à. Bạn kiểm tra lại tất cả rồi làm lại thử xem.thân
