Nokia OVI Browser - trình duyệt web của Nokia
Thảo luận trong 'ỨNG DỤNG CÓ KẾT NỐI WIFI, GPRS, 3G' bắt đầu bởi Khỉ Con, 5 Tháng một 2011.
  1. Khỉ Con interista
    Nokia OVI Browser v1.4 Beta Build0580 S60v3/5 SymbianOS9.x English Hargovind
    [​IMG][​IMG]
    Ovi Browser brings rich web browsing that's fast, easy, and saves on data charges. The browser is powered by patented cloud-based Internet compression technology that delivers advanced web pages to your phone. As a result, pages show up quicker than ever and over the air data usage is reduced up to 90%. Beyond performance, the browser includes an innovative user interface that makes it easy to access your favorite content directly from the start page without having to hunt through menus.
    Were in the process of building up our global infrastructure to provide the best possible speed, performance, and reliability for millions of users. The team is working hard on the next beta version that includes new features and incorporates updates based on your feedback. Also, there will be more localized versions coming that are better customized for where you live. Check back often to see what's new.
    Go to browser.ovi.com from your mobile phone to download. Find the browser in your Apps or Games folder after download.
    If you run into problems, check out the More Info page for troubleshooting tips.
    * This content is solely for your non-commercial private use. Standard operator data transfer charges apply
    Supported Phones
    Key Features
    Fast page load times
    Over the air data usage reduced up to 90%
    Three view modes - Full Page View, Zoomed-in View, Column View
    Integrated search on start page with selectable list of search engines
    Favourites
    Browsing and Search history
    URL and Form auto completion
    Snap to text during scrolling
    Speed scrolling using numeric keypad
    Automatically jumps to the main content on a page to reduce scrolling
    One click jump to login and search in Column View
    Page segmentation in Column View to simplify navigation​
  2. huuthanhk5
    huuthanhk5 Thành viên
    Không có phần mềm tiếng việt à tải về
    Toàn ô vuông ,chán wá
