Nokia.Ovi.Maps.v3.01.2602.S60v3.SymbianOS9.1.Unsig ned.Read.NFO-CODePDA Ovi Maps is always with you on your mobile. Take free maps worldwide, explore places you need nearby, and let Maps show you the way. On foot or in the car, Maps can direct you to your destination turn-by-turn, starting from right where you are.
Hình như mọi người không có hứng thú với cái Ovi Maps này lắm thì phải. Ở Việt Nam bây giờ chỉ có Vietmap là xài ok thôi.
Cái này sai số chóng mặt luôn .Định vị giữa 3 chế độ bản đồ,vệ tinh và địa hình là hoàn toàn khác hẳn .Chỉ hỗ trợ bản đồ vệ tinh của TPHCM thôi.Bản đồ này nó lấy của google add vào
[FONT=Arial, Helvetica, sans-serif]Maps for Ovi Maps (Nokia Maps) 3.0[/FONT] [FONT=Arial, Helvetica, sans-serif]These maps also work on Ovi Maps 3.0 beta[/FONT] [FONT=Arial, Helvetica, sans-serif]Make sure to choose the right type of map. To check your version of Ovi Maps or Nokia Maps select "options" and choose "about" in Nokia Maps or Ovi Maps on your phone.[/FONT] [FONT=Arial, Helvetica, sans-serif]Find your version of Nokia Maps [/FONT] [FONT=Arial, Helvetica, sans-serif]If this is not the right version for you choose another version here.[/FONT] [FONT=Arial, Helvetica, sans-serif]Update: someone on the Nokia forum managed to fix a "map layers out of sync" problem by allowing the maps application to go online once. Should you face the same problem, this solution may work for you too.[/FONT] [FONT=Arial, Helvetica, sans-serif]Instructions[/FONT] [FONT=Arial, Helvetica, sans-serif]Run Ovi Maps on your phone once before you add any maps or voices. This will create the required folder structure on your memory card.[/FONT] [FONT=Arial, Helvetica, sans-serif]Unzip the downloaded map files and drop them into the appropriate folders on your memory card.[/FONT] [FONT=Arial, Helvetica, sans-serif]On my Nokia the folder structure is [FONT=Courier New, Courier, mono]cities[/FONT] with a subfolder called [FONT=Courier New, Courier, mono]diskcache[/FONT], filled with 16 subfolders called [FONT=Courier New, Courier, mono]0[/FONT] to [FONT=Courier New, Courier, mono]9[/FONT] and [FONT=Courier New, Courier, mono]a[/FONT] to[FONT=Courier New, Courier, mono] f[/FONT], and each of these folders have another 16 subfolders [FONT=Courier New, Courier, mono]0[/FONT] to [FONT=Courier New, Courier, mono]9[/FONT] and [FONT=Courier New, Courier, mono]a[/FONT] to[FONT=Courier New, Courier, mono] f[/FONT].[/FONT] [FONT=Arial, Helvetica, sans-serif]Map files have the extension .cdt. Example:[/FONT] [FONT=Arial, Helvetica, sans-serif][FONT=Courier New, Courier, mono][memory card]\cities\diskcache\[0-9, a-f]\[0-9, a-f]\filename.cdt[/FONT] • On some Nokia phones (like the N95) maps are stored in: [FONT=Courier New, Courier, mono]\Private\20001f63\diskcache\[/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Courier New, Courier, mono][0-9, a-f][/FONT][/FONT][FONT=Courier New, Courier, mono]\[/FONT][FONT=Arial, Helvetica, sans-serif][FONT=Courier New, Courier, mono][0-9, a-f][/FONT][/FONT][FONT=Courier New, Courier, mono]\filename.cdt[/FONT] • To install, just drop the 16 folders called 0-9 and a-f into the diskcache folder. • If your phone has both folders, get a small map (for a single country) and try both folders to see which one works. Even Nokia's own map loader doesn't always get it right. Details on the Nokia discussion board. • You may need to tell your computer to show hidden files and folders.[/FONT] [FONT=Arial, Helvetica, sans-serif]Nokia Maps folder structure:[/FONT] DOWNLOAD LINKS : [FONT=Arial, Helvetica, sans-serif]The links below point to the map files on Nokia's own server.[/FONT] Mã: [URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"]Africa[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] (entire continent) country maps: [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1130.zip"]Algeria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1137.zip"]Botswana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1131.zip"]Egypt[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1139.zip"]Lesotho[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1132.zip"]Libya[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1133.zip"]Morocco[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1136.zip"]Namibia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1134.zip"]South Africa[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1138.zip"]Swaziland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1135.zip"]Tunisia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/111.zip"]America[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] (all continents) country maps: [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1114.zip"]Argentina[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1113.zip"]Brasil[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111.zip"]Canada[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1115.zip"]Chile[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1112.zip"]Mexico[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110.zip"]USA[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1116.zip"]Venezuela[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (Canada): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111000.zip"]Alberta[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111001.zip"]British Columbia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111002.zip"]Manitoba[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111003.zip"]New Brunswick[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111004.zip"]Newfoundland & Labrador[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111005.zip"]Nova Scotia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111006.zip"]Ontario[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111007.zip"]Prince Edward Island[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111008.zip"]Quebec[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1111009.zip"]Saskatchewan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (USA): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110000.zip"]Alabama[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110001.zip"]Alaska[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110003.zip"]Arizona[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110002.zip"]Arkansas[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110004.zip"]California[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110005.zip"]Colorado[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110006.zip"]Connecticut[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110007.zip"]Delaware[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110008.zip"]Florida[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110009.zip"]Georgia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110010.zip"]Hawaii[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110011.zip"]Idaho[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110012.zip"]Illinois[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110013.zip"]Indiana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110014.zip"]Iowa[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110015.zip"]Kansas[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110016.zip"]Kentucky[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110017.zip"]Louisiana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110018.zip"]Maine[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110019.zip"]Maryland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110020.zip"]Massachusetts[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110021.zip"]Michigan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110022.zip"]Minnesota[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110023.zip"]Mississippi[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110024.zip"]Missouri[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110025.zip"]Montana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110026.zip"]Nebraska[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110027.zip"]Nevada[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110028.zip"]New Hampshire[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110029.zip"]New Jersey[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110030.zip"]New Mexico[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110031.zip"]New York[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110032.zip"]North Carolina[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110033.zip"]North Dakota[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110034.zip"]Ohio[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110035.zip"]Oklahoma[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110036.zip"]Oregon[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110037.zip"]Pennsylvania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110050.zip"]Puerto Rico[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110038.zip"]Rhode Island[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110039.zip"]South Carolina[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110040.zip"]South Dakota[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110041.zip"]Tennessee[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110042.zip"]Texas[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110043.zip"]Utah[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"]| [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110044.zip"]Vermont[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110045.zip"]Virginia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110046.zip"]Washington[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110047.zip"]West Virginia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110048.zip"]Wisconsin[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1110049.zip"]Wyoming[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/114.zip"]Asia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] (entire continent) country maps: [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1140.zip"]Armenia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1141.zip"]Azerbaijan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1142.zip"]Bahrain[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414.zip"]China[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1143.zip"]Hong Kong + Macau[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11415.zip"]India[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11416.zip"]Indonesia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1144.zip"]Japan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11417.zip"]Jordan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1145.zip"]Kuwait[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1146.zip"]Malaysia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1147.zip"]Oman[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11419.zip"]Philippines[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1148.zip"]Qatar[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1149.zip"]Saudi Arabia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11410.zip"]Singapore[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11420.zip"]South Korea[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11411.zip"]Taiwan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11412.zip"]Thailand[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11413.zip"]United Arab Emirates[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11418.zip"]Vietnam[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (China): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414000.zip"]Anhui[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414001.zip"]Beijing/Peking[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414003.zip"]Chongqing[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414004.zip"]Fujian[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414005.zip"]Gansu[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414006.zip"]Guangdong[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414007.zip"]Guangxi[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414008.zip"]Guizhou[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414009.zip"]Hainan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414010.zip"]Hebei[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414011.zip"]Heilongjiang[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414012.zip"]Henan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414013.zip"]Hubei[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414014.zip"]Hunan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414015.zip"]Jiangsu[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414016.zip"]Jiangxi[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414017.zip"]Jilin[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414018.zip"]Liaoning[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414019.zip"]Neimenggu[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414020.zip"]Ningxia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414021.zip"]Quinghai[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414022.zip"]Shaanxi[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414023.zip"]Shandong[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414024.zip"]Shanghai[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414025.zip"]Shanxi[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414026.zip"]Sichuan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414027.zip"]Tianjin[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414028.zip"]Xinjiang[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414031.zip"]Xizang[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414029.zip"]Yunnan[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11414030.zip"]Zhejiang[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/115.zip"]Australia & Oceania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] (entire region) country maps: [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1150.zip"]Australia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1151.zip"]New Zealand[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/112.zip"]Europe[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] (entire continent) country maps [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11239.zip"]Albania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1126.zip"]Andorra[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11215.zip"]Austria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11233.zip"]Belarus[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11213.zip"]Belgium[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11241.zip"]Bosnia & Herzegovina[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11235.zip"]Bulgaria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11242.zip"]Croatia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11237.zip"]Cyprus[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11225.zip"]Czech Republic[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11218.zip"]Denmark[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11230.zip"]Estonia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11221.zip"]Finland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121.zip"]France[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11245.zip"]Georgia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120.zip"]Germany[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1125.zip"]Gibraltar[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11223.zip"]Greece[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11227.zip"]Hungary[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11211.zip"]Ireland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123.zip"]Italia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11229.zip"]Latvia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11217.zip"]Liechtenstein[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11228.zip"]Lithuania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11214.zip"]Luxembourg[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11238.zip"]Macedonia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11236.zip"]Malta[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11232.zip"]Moldova[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1127.zip"]Monaco[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11212.zip"]Netherlands[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11219.zip"]Norway[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11224.zip"]Poland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1124.zip"]Portugal[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11234.zip"]Romania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11244.zip"]Russia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1129.zip"]San Marino[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11240.zip"]Serbia & Montenegro[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11226.zip"]Slovakia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11243.zip"]Slovenia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122.zip"]Spain[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11220.zip"]Sweden[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11216.zip"]Switzerland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11222.zip"]Turkey[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11231.zip"]Ukraine[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11210.zip"]UK[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1128.zip"]Vatican City[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (France): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121000.zip"]Alsace[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121001.zip"]Aquitaine[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121002.zip"]Auvergne[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121003.zip"]Bretagne[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121004.zip"]Bourgogne[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121005.zip"]Centre[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121006.zip"]Champagne-Ardenne[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121007.zip"]Corsica[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121008.zip"]Franche-Comté[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121009.zip"]Langedoc-Roussillon[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121010.zip"]Limousin[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121011.zip"]Lorraine[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121013.zip"]Midi-Pyrénées[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121012.zip"]Normandie[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121014.zip"]Nord-Pas-de-Calais[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121016.zip"]Paris-Ile-de-France/Picardie[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121015.zip"]Pays-de-la-Loire[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121017.zip"]Poitou-Charentes[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121018.zip"]Provence-Alpes-Côte-d'Azur[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1121019.zip"]Rhône-Alpes[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (Germany): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120000.zip"]Baden-Württemberg[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120001.zip"]Bayern[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120002.zip"]Berlin/Brandenburg[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120003.zip"]Hessen[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120004.zip"]Mecklenburg-Vorpommern[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120005.zip"]Niedersachsen/Bremen[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120006.zip"]Nordrhein-Westfalen[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120007.zip"]Rheinland-Pfalz/Saarland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120009.zip"]Sachsen[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120008.zip"]Sachsen-Anhalt[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120010.zip"]Schleswig-Holstein/Hamburg[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1120011.zip"]Thüringen[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (Italia): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123012.zip"]Abruzzo[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123016.zip"]Basilicata[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123017.zip"]Calabria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123014.zip"]Campania[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123007.zip"]Emilia-Romagna[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123005.zip"]Friuli-Venezia Giulia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123011.zip"]Lazio[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123006.zip"]Liguria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123002.zip"]Lombardia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123010.zip"]Marche[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123013.zip"]Molise[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123000.zip"]Piemonte[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123015.zip"]Puglia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123019.zip"]Sardegna[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123018.zip"]Sicilia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123008.zip"]Toscana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123003.zip"]Trentino-Alto Adige[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123009.zip"]Umbria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123001.zip"]Valle d'Aosta[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1123004.zip"]Veneto[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (Spain): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122014.zip"]Andalucía[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122007.zip"]Aragón[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122001.zip"]Asturias[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122016.zip"]Islas Canarias[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122002.zip"]Cantabria[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122005.zip"]Castilla y Léon[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122011.zip"]Castilla la Mancha[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122008.zip"]Catalunya[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122017.zip"]Ceuta[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122012.zip"]Communidad Valénciana[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122010.zip"]Extremadura[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122000.zip"]Galicia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122013.zip"]Islas Baleares[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122006.zip"]La Rioja[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122009.zip"]Madrid[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122018.zip"]Melilla[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122015.zip"]Murcia[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122004.zip"]Navarre[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/1122003.zip"]País Vasco[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] regional maps (UK): [/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11210000.zip"]England[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11210003.zip"]Northern Ireland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11210001.zip"]Scotland[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] | [/URL][URL="http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/11210002.zip"]Wales[/URL][URL="http://www.anonym.to/?http://static.s2g.gate5.de/map5/maploaderzip-00.01.22.103/113.zip"] [/URL]
Voicesfor all versions of Nokia Maps Instructions Run Nokia Maps on your phone once before you add any maps or voices. This will create the required folder structure on your memory card. If you unzip the voices, you'll get a folder with a name of the language. This folder contains an .xml file and a subfolder full of files without any extension. This folder should go into the cities folder. For example, if you download english.zip, the unzipped folder (called english) goes into the cities folder on your memory card so you'll get: [memory card]\cities\english\etc. • On some Nokia phones (like the N95) voices are stored in: [memory card]\Private\20001f63\english\etc. • If your phone has both folders, try both folders to see which one works. Even Nokia's own map loader doesn't always get it right. Details on the Nokia discussion board. • You may need to tell your computer to show hidden files and folders. [FONT=Arial, Helvetica, sans-serif]The links below point to the voice files on Nokia's own server.[/FONT] Mã: DOWNLOAD LINKS Voices • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/afrikaans.zip"]Afrikaans[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/arabic.zip"]Arabic[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/basque.zip"]Basque[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/bulgarian.zip"]Bulgarian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/cantonese.zip"]Cantonese[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/catalan.zip"]Catalan[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/croatian.zip"]Croatian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/czech.zip"]Czech[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/danish.zip"]Danish[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/dutch.zip"]Dutch[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/english.zip"]English[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/english_us.zip"]English (US)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/estonian.zip"]Estonian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/farsi.zip"]Farsi[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/finnish.zip"]Finnish[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/french.zip"]French[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/french_ca.zip"]French (Canada)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/galician.zip"]Galician[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/german.zip"]German[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/greek.zip"]Greek[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/hindi.zip"]Hindi[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/hungarian.zip"]Hungarian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/indonesian.zip"]Indonesian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/italian.zip"]Italian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/korean.zip"]Korean (South Korea)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/latvian.zip"]Latvian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/lithuanian.zip"]Lithuanian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/malay.zip"]Malay[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/mandarin_chinese.zip"]Mandarin (China)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/taiwanese_chinese.zip"]Mandarin (Taiwan)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/norwegian.zip"]Norwegian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/polish.zip"]Polish[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/brazilian.zip"]Portuguese (Brasil)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/portuguese.zip"]Portuguese (Portugal)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/romanian.zip"]Romanian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/russian.zip"]Russian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/slovak.zip"]Slovak[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/slovenian.zip"]Slovenian[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/spanish.zip"]Spanish (España)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/mexican.zip"]Spanish (Mexico)[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/swedish.zip"]Swedish[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/tamil.zip"]Tamil[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/thai.zip"]Thai[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/turkish.zip"]Turkish[/URL] • [URL="http://www.anonym.to/?http://static.s2g.gate5.de/maploadervoice/urdu.zip"]Urdu[/URL]
