Nokia PC Suite 6.7.21
Thảo luận trong 'Điện Thoại Phổ Thông' bắt đầu bởi Gus, 15 Tháng mười hai 2005.
  1. Gus Ex-Mod
    New Features:
    Get Connected wizard:
    New step-by-step wizard required for setting up a Bluetooth connection between your phone and a compatible PC. Also assists with infrared and cable connections.
    One Touch Access to Internet:
    Use your phone as a quick and easy Internet modem for your compatible PC. Requires GPRS or 3G-enabled phone.
    Image Store:
    Automatically retrieve new images and videos from your phone when you connect to your compatible PC. Improvements - USB driver installation is now Microsoft-certified - Improved synchronization for the Nokia 9300 device and Nokia 9500 Communicator - Improved stability for the Nokia Audio Manager application - Improved connection handling and status information - Improved contacts backup - Improved usability for multimedia format conversion - Easier setup of Bluetooth connection
    Download: Nokia PC Suite 6.7.21
  2. anhbida
    anhbida Thành viên
    N6630 dùng được không vậy bạn ?
  3. Gus
    Gus Ex-Mod
