Thảo luận NokiaCooker - tất cả cho cook firmware
Thảo luận trong 'S60 3rd: FIRMWARE - SIGN - HACKPHONE & HACK APP' bắt đầu bởi Khỉ Con, 4 Tháng một 2011.
  1. Khỉ Con interista
    Nokia Cooker
    Nokia Cooker is a PC software reserved to the Cookers, which allows to modify the files containing the phone's firmware to create customized firmwares versions named Cooked-Firmware.
    Nokia Cooker can modify data which is located in:
    - UDA
    - ROFS
    - ROFx
    It can't modify data located in the CORE yet.
    Not all the ROFS/ROFx can be modded!
    Modding a protected ROFS/ROFx you'll risk to brick the phone.
    If you aren't sure that your ROFS/ROFx can be modded, don't do it.
    The modding of the UDA, instead, is always a safe operation.
    NokiaCooker 1.0 Change-Log:
    - New: Shows the maximum ROFS partition size and the ROFS extimated size.
    - Improved: NaviFirm plugin updated to 0.9 version
    - Improved: the "Allow ROFS Resize" option is not needed anymore and it has been removed.
    - Fixed: the "Allow ROFS Resize" option sometimes corrupted the ROFS rebuild process, causing strange issues in the Cooked Fw.
    *** Informations for Developers about Plugins ***
    When NokiaCooker launches your application it will pass the 4 command-line parameters below:
    1) the file currently selected in the window on the right side
    2) the path where the fw files have been extracted (eg: c:\nokiacooker\files\n8fw_extracted\)
    3) firmware filename (eg: RM-596_011.012_U01.01_79.92_prd.uda.fpsx)
    4) firmware type (UDA, ROFS, CORE, UNKNOWN)
    How to read the arguments depends on the programming language you're using:
    - for Delphi you should use ParamStr() ParamCount()
    - for C# you can find the source code of a skeleton Plugin inside \NokiaCooker\TestPlugins\​
  2. 350nha
    350nha Thành viên
    Cái này có phải tạo File hack cho điện thoại ko, bạn có thể cho hướng dẫn sử dụng được không ........ thank
  3. Be Yeu
    Chính xác là dùng để chỉnh sửa FirmWare ( Cook FW ). Tạm dịch :
    Là một phần mềm máy tính dành cho các Cooker , cho phép chỉnh sửa các tập tin có chứa phần mềm của điện thoại để tạo ra các phiên bản firmware có tên là Cook-Firmware.
    Nokia Cooker có thể sửa đổi dữ liệu được đặt tại:
    - UDA
    - ROFS
    - ROFx
    Nó không thể sửa đổi dữ liệu nằm trong CORE được nêu ra.
    Không phải tất cả các ROFS / ROFx có thể được chỉnh sửa !
    Chỉnh sửa một ROFS bảo vệ / ROFx sẽ có nguy cơ để gây hại cho điện thoại.
    Nếu bạn không chắc chắn rằng ROFS của bạn / ROFx có thể được chỉnh sửa , không nên làm điều đó.
    Các chỉnh sửa của UDA, thay vào đó, luôn luôn là một hoạt động an toàn hơn .
    Thay đổi NokiaCooker 1,0-Đăng nhập:
    - New: Hiển thị các kích thước ROFS phân vùng tối đa và các ROFS extimated kích thước.
    - Cải thiện: NaviFirm plugin cập nhật cho phiên bản 0,9
    - Cải thiện: những "Cho phép ROFS Thay đổi kích thước tùy chọn là không cần thiết nữa và nó đã được gỡ bỏ.
    - Sửa lỗi: "Cho phép ROFS Thay đổi kích cỡ tùy chọn đôi khi bị hỏng trong quá trình xây dựng lại ROFS, gây ra các vấn đề lạ trong Fw chín.
    *** Thông tin cho các nhà phát triển về Plugins ***
    Khi NokiaCooker ra mắt ứng dụng của bạn nó sẽ vượt qua được 4 dòng lệnh thông số dưới đây:
    1) tập tin đang được chọn trong cửa sổ bên phải
    2) đường dẫn nơi các tập tin fw được trích ra (ví dụ: c: \ nokiacooker \ file \ n8fw_extracted \)
    3) tên tập tin firmware (ví dụ như: RM-596_011.012_U01.01_79.92_prd.uda.fpsx)
    4) firmware loại (UDA, ROFS, CORE, KHÔNG RÕ)
    Làm thế nào để đọc các đối số phụ thuộc vào ngôn ngữ lập trình bạn đang sử dụng:
    - cho Delphi bạn nên sử dụng ParamStr () ParamCount ()
    - cho C # bạn có thể tìm mã nguồn bên trong một Plugin \ NokiaCooker \ TestPlugins \
    vanvu, Khỉ Con, 350nha and 2 others like this.
  4. debor_vn2000
    debor_vn2000 Thành viên
    Có khả năng đúng thứ mình đang cần đây. Để mình test thử nhé. Có gì sẽ port
    ---------- Post added at 10:05 PM ---------- Previous post was at 09:52 PM ----------
    Sử dụng phiên bản mới rùi. Nói chung là rất dễ sử dụng.
    linl down nằm ở đây http://www.symbian-toys.com/download.aspx?file=nokiacooker_1.1.zip
    Nếu ai đã từng hack qua thì sẽ làm đc thôi. Cái này dùng để bung rofs2 hoặc là uda tùy theo từng dòng máy. thông thường dòng 3rd thì bung file UAD còn dòng 5th thì rofs2.
    Dù sao cũng thank chủ thớt vì đã port bài này.
    thuandiennang thích bài này.
  5. behu1986
    behu1986 Thành viên
    hay quá !
    cảm ơn chủ thớt nhiều !
  6. yaiba
    yaiba Thành viên
    mình chạy Win7 home Premium, đã chỉnh compatility cho cái này chạy như WinXP nhưng vẫn nó ko chịu chạy. có cách nào để cái nokiacooker 1.1 này chịu chạy trên win7 ko nhỉ :(
  7. Khỉ Con
    Bạn chỉnh ngày về trước 1-8-2011 nhé :-?
    yaiba thích bài này.
  8. yaiba
    yaiba Thành viên
    cảm ơn bạn, lúc nãy cũng đã được 1 bạn trên GSM ntin chỉ ^^
