Panecal Scientific calculator 2.2.4 - máy tính khoa học cho Android
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 16 Tháng chín 2011.
  1. Khỉ Con interista
    Scientific calculator with multi-line formula view.
    A multiline scientific calculator which can input a numerical formula.
    [Features]
    * Re-edit the numerical formula by △ key.
    * A vibration and orange color key input confirmation. You can modify the vibration length in ALT+Setup.
    * Arithmetic, trigonometric, inverse trigonometric, exponential, logarithmic function, power, power root function, factorial, and corresponds to the absolute value operations.
    * DEG, RAD, GRAD mode.
    * FloatPt, Fix, Sci, Eng mode.
    * BS key, DEL key, INS key.
    [adjustment of the key location]
    In the case of new installation, the Panecal adjusts key location suitable for the resolution of the smartphone automatically. When it doesn't fit keys in the screen, you can adjust the key location automatically by changing parameter Margin function key=0, Margin ten key=0. In addition, you can set keys location inputting any number into these parameters.
    [system environment]
    More than Android OS 2.1
    More than resolution HVGA(480 *320)
    [Prohibited]
    Panecal is distributed on Android market only.
    Prohibited to redistribute the APK file that is obtained illegally.
    [Disclaimer]
    Damage caused by the use of this software, the author also claims lost profits or any third party not assume any responsibility, Please note.
    [​IMG][​IMG][​IMG]
    Xem thêm:
    https://market.android.com/details?id=jp.ne.kutu.Panecal&feature=search_result
    Tải về:
    http://appstore.vn/a/index.php/home/app/1440
  2. Khỉ Con
    Cập nhật 1.9.0 !!!!!!!!!!!!!!
  3. Khỉ Con
    Cập nhật 1.9.1 !!!!!!!!!
  4. Khỉ Con
    Cập nhật 2.2.4 !!!!!!!!!!!
  5. myha1002
    myha1002 Thành viên
    Máy tính có sẵn trên Android cùi quá, phải thay thôi.
  6. haigomgsm
    haigomgsm Thành viên
    thank you bạn đã chia sẻ!!!
